中心对齐波形出不来
TIM1 PWM源代码:
TIM_TimeBaseInitTypeDefTIM_TimeBaseStructure; //基本结构体变量定义
TIM_OCInitTypeDefTIM_OCInitStructure; //输出结构体变量定义
TIM_BDTRInitTypeDefTIM_BDTRInitStructure; //死区刹车结构体变量定义
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
// PA8 9 10 PB 13 14 15 复用
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
__bic(BIT_16(8)|BIT_16(9)|BIT_16(10), GPIOA->ODR);//缺省输出
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_13 | GPIO_Pin_14| GPIO_Pin_15;
GPIO_Init(GPIOB,&GPIO_InitStructure);
__bis(BIT_16(13)|BIT_16(14)|BIT_16(15), GPIOB->ODR);//缺省输出
TIM_DeInit(TIM1);
TIM_TimeBaseStructure.TIM_Prescaler = 0; //TIM基本初始化
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned2;//中央对齐计数模式
TIM_TimeBaseStructure.TIM_Period = 128*2; //PWM 16K
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //TIM输出通道初始化
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse =128;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
TIM_OC1Init(TIM1,&TIM_OCInitStructure);
TIM_OCInitStructure.TIM_Pulse =128/2;
TIM_OC2Init(TIM1,&TIM_OCInitStructure);
TIM_OCInitStructure.TIM_Pulse =128/2*3;
TIM_OC3Init(TIM1,&TIM_OCInitStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //TIM输出通道4初始化,用来触发AD注入采样
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
TIM_OC4Init(TIM1,&TIM_OCInitStructure);
TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable; //死区刹车初始化
TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
TIM_BDTRInitStructure.TIM_DeadTime = 4;
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable; //如打开,开机无输出且状态紊乱????
TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;
TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;
TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);//使能捕获比较寄存器预装载(通道1)
TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable); //使能捕获比较寄存器预装载(通道2)
TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable); //使能捕获比较寄存器预装载(通道3)
TIM_SelectInputTrigger(TIM1, TIM_TS_ITR2); //输入触发源选择TIM3
//TIM_SelectSlaveMode(TIM1, TIM_SlaveMode_Trigger);//从模式选择 触发
TIM_CtrlPWMOutputs(TIM1,ENABLE);
TIM_Cmd(TIM1,ENABLE);
} 输出波形PA8,PA9
寄存器呢
TIM1寄存器状态
贴个对的代码出来看看。
ST各个系列固件库里都有例程,稍微改改计数器模式为中心对齐模式就可以自己验证了。
其他对齐方式就可以出波形吗
页:
[1]
