at32f413 DMA新手求助
使用DMA更新PWM脉宽数据,TIMR5输出两路PWM,频率相同,脉宽不同,以下代码PWM正常工作,DMA无法更新数据。感谢大佬们帮忙看看一下。void tmr5_configuration(void)
tmr_output_config_type tmr_output_struct;
/* Init TMR5 */
tmr_base_init(TMR5, 250-1, 0); //200MHz/250=800KHz
//tmr_base_init(TMR5, 300-1, 0); //240MHz/300=800KHz
tmr_cnt_dir_set(TMR5, TMR_COUNT_UP); //定时器计数器向上计数
/* TMR configuration as output mode */
tmr_output_default_para_init(&tmr_output_struct);
tmr_output_struct.oc_mode = TMR_OUTPUT_CONTROL_PWM_MODE_B;
tmr_output_struct.oc_output_state = TRUE;
tmr_output_struct.oc_polarity = TMR_OUTPUT_ACTIVE_LOW;
tmr_output_struct.oc_idle_state = TRUE;
tmr_output_struct.occ_output_state = TRUE;
tmr_output_struct.occ_polarity = TMR_OUTPUT_ACTIVE_LOW;
tmr_output_struct.occ_idle_state = FALSE;
/* TMR5 channel 1 configuration */
tmr_output_channel_config(TMR5, TMR_SELECT_CHANNEL_1, &tmr_output_struct);
tmr_output_channel_buffer_enable(TMR5, TMR_SELECT_CHANNEL_1, TRUE);
/* TMR5 channel 2 configuration */
tmr_output_channel_config(TMR5, TMR_SELECT_CHANNEL_2, &tmr_output_struct);
tmr_output_channel_buffer_enable(TMR5, TMR_SELECT_CHANNEL_2, TRUE);
void dma2_5_configuration(void)
dma_init_type dma_init_struct = {0};
dma_reset(DMA2_CHANNEL5);
dma_reset(DMA2_CHANNEL4);
/* dma1 channel7 configuration */
dma_default_para_init(&dma_init_struct);
dma_init_struct.buffer_size =ArgbPixelBuffNub+ArgbPixelResetNub; //设置 DMA 通道传输数据量
dma_init_struct.direction = DMA_DIR_MEMORY_TO_PERIPHERAL; //方向为存储器到外设
dma_init_struct.memory_base_addr = (uint32_t)temp_buffer_argb2; //设置 DMA 通道存储器地址
dma_init_struct.memory_data_width = DMA_MEMORY_DATA_WIDTH_BYTE; //存储器数据宽度为字节
dma_init_struct.memory_inc_enable = TRUE; //存储器地址递增
dma_init_struct.peripheral_base_addr = (uint32_t)0x40000C34; //TMR5_C1DT_ADDRESS; //设置 DMA 通道的外设地址
dma_init_struct.peripheral_data_width = DMA_PERIPHERAL_DATA_WIDTH_BYTE; //外设数据宽度为字节
dma_init_struct.peripheral_inc_enable = FALSE; //外设地址不递增
dma_init_struct.priority = DMA_PRIORITY_MEDIUM; //DMA 通道优先级为中
dma_init_struct.loop_mode_enable = TRUE; //DMA 通道为循环模式
dma_init(DMA2_CHANNEL5, &dma_init_struct);
dma_init_struct.memory_base_addr = (uint32_t)temp_buffer_argb1; //设置 DMA 通道存储器地址
dma_init_struct.peripheral_base_addr = (uint32_t)0x40000C38; //TMR5_C2DT_ADDRESS; //设置 DMA 通道的外设地址
dma_init(DMA2_CHANNEL4, &dma_init_struct);
void ARGB_configuration(void)
tmr5_configuration();
tmr_channel_value_set(TMR5, TMR_SELECT_CHANNEL_2, temp_buffer_argb1);
tmr_channel_value_set(TMR5, TMR_SELECT_CHANNEL_1, temp_buffer_argb2);
tmr_dma_request_enable(TMR5, TMR_OVERFLOW_DMA_REQUEST, TRUE);
dma2_5_configuration();
dma_flexible_config(DMA2, FLEX_CHANNEL4|FLEX_CHANNEL5, DMA_FLEXIBLE_TMR3_OVERFLOW);
dma_channel_enable(DMA2_CHANNEL4, TRUE);
dma_channel_enable(DMA2_CHANNEL5, TRUE);
tmr_output_enable(TMR5, TRUE);
tmr_counter_enable(TMR5, TRUE);
} 可参考如附件SC0069 AT32_TMR使用DMA动态更新PWM占空比
dma_flexible_config(DMA2, FLEX_CHANNEL4|FLEX_CHANNEL5, DMA_FLEXIBLE_TMR3_OVERFLOW); 这里的TMR3是干啥的? goodjob 发表于 2023-3-7 02:39
dma_flexible_config(DMA2, FLEX_CHANNEL4|FLEX_CHANNEL5, DMA_FLEXIBLE_TMR3_OVERFLOW); 这里的TMR3是干啥 ...
感谢指导,这里的TMR3是弄错了,应该是DMA_FLEXIBLE_TMR5_OVERFLOW,原来是用TMR5一个通道和TMR3一个通道,但是发现TMR3的复用口无法打开,所以全用了TMR5,这里忘记改过来。
现在给它改过来:
dma_flexible_config(DMA2, FLEX_CHANNEL4|FLEX_CHANNEL5, DMA_FLEXIBLE_TMR5_OVERFLOW);
但是DMA还是不起作用,其实注释掉这行也应该能正常工作,实际上我试过还是不行。 muyichuan2012 发表于 2023-3-6 19:52
谢谢你,我就是参考这个例程的,总感觉少了些啥的导致不启动 ryan39343551 发表于 2023-3-7 10:55
感谢指导,这里的TMR3是弄错了,应该是DMA_FLEXIBLE_TMR5_OVERFLOW,原来是用TMR5一个通道和TMR3一个通道 ...
dma_flexible_config()这个一次只能绑一条DMA通道啊 goodjob 发表于 2023-3-7 23:46
好的,谢谢提醒,我试试 仿真可以看到DMA的计数器在运行,但是无法将数据表的值赋给外设TMR5,TMR5的通道数据寄存器一直为0 你好,有解决没有,我现在是开通了是个通道,但是也是不能正常工作
页:
[1]
