[STM32U5] 【NUCLEO-U575ZI-Q测评】HT1621显示热敏电阻值
816|2
 楼主| 比神乐 发表于 2023-3-8 20:19 | 显示全部楼层 |阅读模式
今天搞了一下热敏电阻采样,用HT1621显示,单位为mv。
原理图:
AD接口接PA4,PA4接新定义板子的热敏电阻。
HT1621:DA接PC10,WR接PD9,CS接PF7。
代码:
  1. #include "main.h"
  2. /* Private includes ----------------------------------------------------------*/
  3. /* USER CODE BEGIN Includes */
  4. /* USER CODE END Includes */
  5. /* Private typedef -----------------------------------------------------------*/
  6. /* USER CODE BEGIN PTD */
  7. /* USER CODE END PTD */
  8. /* Private define ------------------------------------------------------------*/
  9. /* USER CODE BEGIN PD */
  10. /* Definitions of environment analog values */
  11.   /* Value of analog reference voltage (Vref+), connected to analog voltage   */
  12.   /* supply Vdda (unit: mV).                                                  */
  13. #define VDDA_APPLI                       (3300UL)
  14.   /* Init variable out of expected ADC conversion data range */
  15. #define VAR_CONVERTED_DATA_INIT_VALUE    (__LL_ADC_DIGITAL_SCALE(ADC1, LL_ADC_RESOLUTION_12B) + 1)
  16. /* USER CODE END PD */
  17. #define uchar unsigned char
  18. #define uint unsigned int
  19. /** @addtogroup 425_GPIO_led_toggle GPIO_led_toggle
  20.   * @{
  21.   */
  22. #define DA_1 HAL_GPIO_WritePin(GPIOC,GPIO_PIN_10,1)
  23. #define DA_0 HAL_GPIO_WritePin(GPIOC,GPIO_PIN_10,0)
  24. #define WR_1 HAL_GPIO_WritePin(GPIOD,GPIO_PIN_9,1)
  25. #define WR_0 HAL_GPIO_WritePin(GPIOD,GPIO_PIN_9,0)
  26. #define CS_1 HAL_GPIO_WritePin(GPIOF,GPIO_PIN_7,1)
  27. #define CS_0 HAL_GPIO_WritePin(GPIOF,GPIO_PIN_7,0)
  28. #define Smg_a    0x80
  29. #define Smg_b    0x40
  30. #define Smg_c    0x20
  31. #define Smg_d    0x01
  32. #define Smg_e    0x02
  33. #define Smg_f    0x08
  34. #define Smg_g    0x04
  35. #define Smg_dp   0x10
  36. #define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
  37. #define Bmp1Map          Smg_b | Smg_c
  38. #define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
  39. #define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
  40. #define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
  41. #define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
  42. #define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  43. #define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  44. #define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
  45. #define Bmp7Map          Smg_a | Smg_b | Smg_c
  46. #define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
  47. #define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  48. #define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
  49. #define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
  50. #define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
  51. #define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
  52. /* Private macro -------------------------------------------------------------*/
  53. /* USER CODE BEGIN PM */
  54. /* USER CODE END PM */
  55. /* Private variables ---------------------------------------------------------*/
  56. ADC_HandleTypeDef hadc1;
  57. /* USER CODE BEGIN PV */
  58. /* Variables for ADC conversion data */
  59. __IO uint16_t uhADCxConvertedData = VAR_CONVERTED_DATA_INIT_VALUE; /* ADC group regular conversion data */
  60. /* Variables for ADC conversion data computation to physical values */
  61. uint16_t uhADCxConvertedData_Voltage_mVolt = 0;  /* Value of voltage calculated from ADC conversion data (unit: mV) */
  62. /* Variable to report status of ADC group regular unitary conversion          */
  63. /*  0: ADC group regular unitary conversion is not completed                  */
  64. /*  1: ADC group regular unitary conversion is completed                      */
  65. /*  2: ADC group regular unitary conversion has not been started yet          */
  66. /*     (initial state)                                                        */
  67. __IO uint8_t ubAdcGrpRegularUnitaryConvStatus = 2; /* Variable set into ADC interruption callback */
  68. /* USER CODE END PV */
  69. /* Private function prototypes -----------------------------------------------*/
  70. void SystemClock_Config(void);
  71. static void SystemPower_Config(void);
  72. static void MX_GPIO_Init(void);
  73. static void MX_ICACHE_Init(void);
  74. static void MX_ADC1_Init(void);
  75. /* USER CODE BEGIN PFP */
  76. /* USER CODE BEGIN PV */
  77. static GPIO_InitTypeDef  GPIO_InitStruct;
  78. /* USER CODE END PV */
  79. /* Private function prototypes -----------------------------------------------*/
  80. void SystemClock_Config(void);
  81. static void SystemPower_Config(void);
  82. static void MX_ICACHE_Init(void);
  83. /* USER CODE BEGIN PFP */
  84. const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
  85. unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //ÏÔʾ»º³åÇø
  86. unsigned int i;
  87. void COMMAND_HT1621(unsigned char comm)
  88. {
  89.     //unsigned char i;
  90.     CS_0;
  91.     WR_0;
  92.     for(i=0;i<3;i++)        //дÃüÁî
  93.     {
  94.         if((0x04<<i)&0x04)  DA_1;    //100
  95.         else                DA_0;
  96.         WR_0;
  97.         WR_1;
  98.     }
  99.     for(i=0;i<9;i++)        //дÃüÁîÊý¾Ý
  100.     {
  101.         if((comm<<i)&0x80)  DA_1;    //100
  102.         else                DA_0;
  103.         WR_0;
  104.         WR_1;
  105.     }
  106.     CS_1;
  107. }
  108. void HT1621_Display(void)
  109. {
  110.     //unsigned char i;
  111.     CS_0;                        //ƬѡCS
  112.     WR_0;
  113.     for(i=0;i<3;i++)                   //дÃüÁî
  114.     {
  115.         if((0x05<<i)&0x04)  DA_1;
  116.         else                DA_0;
  117.         WR_0;
  118.         WR_1;
  119.     }
  120.     for(i=0;i<6;i++)                   //дµØÖ·
  121.     {
  122.         if((20<<i)&0x20)    DA_1;  //20¶ÔÓ¦ SEGµØÖ·
  123.         else                DA_0;
  124.         WR_0;
  125.         WR_1;
  126.     }
  127.     for(i=0;i<8;i++)                   //дÊý¾Ý
  128.     {
  129.         if((DpyNum[5]<<i)&0x80)   DA_1;
  130.         else                      DA_0;
  131.         WR_0;
  132.         WR_1;
  133.     }
  134.     for(i=0;i<8;i++)                   //дÊý¾Ý
  135.     {
  136.         if((DpyNum[4]<<i)&0x80)   DA_1;
  137.         else                      DA_0;
  138.         WR_0;
  139.         WR_1;
  140.     }
  141.     for(i=0;i<8;i++)                   //дÊý¾Ý
  142.     {
  143.         if((DpyNum[3]<<i)&0x80)   DA_1;
  144.         else                      DA_0;
  145.         WR_0;
  146.         WR_1;
  147.     }
  148.     for(i=0;i<8;i++)                   //дÊý¾Ý
  149.     {
  150.         if((DpyNum[2]<<i)&0x80)   DA_1;
  151.         else                      DA_0;
  152.         WR_0;
  153.         WR_1;
  154.     }
  155.     for(i=0;i<8;i++)                   //дÊý¾Ý
  156.     {
  157.         if((DpyNum[1]<<i)&0x80)   DA_1;
  158.         else                      DA_0;
  159.         WR_0;
  160.         WR_1;
  161.     }
  162.     for(i=0;i<8;i++)                   //дÊý¾Ý
  163.     {
  164.         if((DpyNum[0]<<i)&0x80)   DA_1;
  165.         else                      DA_0;
  166.         WR_0;
  167.         WR_1;
  168.     }
  169.     CS_1;                          //ÊÍ·ÅCS
  170. }
  171. void LCD_Init(void)
  172. {
  173.     COMMAND_HT1621(0x01);         //SYS EN
  174.     COMMAND_HT1621(0x03);         //LCD ON
  175.     COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
  176.     HT1621_Display();             //clear screen
  177. }
  178. /* USER CODE END 0 */
  179. /**
  180.   * [url=home.php?mod=space&uid=247401]@brief[/url]  The application entry point.
  181.   * @retval int
  182.   */
  183. int main(void)
  184. {
  185.   /* USER CODE BEGIN 1 */
  186.         uint8_t qian,bai,shi,ge;
  187.   /* USER CODE END 1 */
  188.   /* MCU Configuration--------------------------------------------------------*/
  189.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  190.   HAL_Init();
  191.   /* USER CODE BEGIN Init */
  192.   /* USER CODE END Init */
  193.   /* Configure the system clock */
  194.   SystemClock_Config();
  195.   /* Configure the System Power */
  196.   SystemPower_Config();
  197.   /* USER CODE BEGIN SysInit */
  198.   /* USER CODE END SysInit */
  199.   /* Initialize all configured peripherals */
  200.   MX_GPIO_Init();
  201.
  202.   MX_ICACHE_Init();
  203.
  204.         //MX_USART2_Init();
  205.   MX_ADC1_Init();
  206.   /* USER CODE BEGIN 2 */
  207.   /* Initialize LED on board */
  208.
  209.   /* -2- Configure IO in output push-pull mode to drive external LEDs */
  210.   GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  211.   GPIO_InitStruct.Pull  = GPIO_NOPULL;
  212.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  213.
  214.         GPIO_InitStruct.Pin = LED1_PIN;
  215.   HAL_GPIO_Init(LED1_GPIO_PORT, &GPIO_InitStruct);
  216.   GPIO_InitStruct.Pin = LED2_PIN;
  217.   HAL_GPIO_Init(LED2_GPIO_PORT, &GPIO_InitStruct);
  218.
  219.   /* Perform ADC calibration */
  220.   if (HAL_ADCEx_Calibration_Start(&hadc1, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED) != HAL_OK)
  221.   {
  222.     /* Calibration Error */
  223.     Error_Handler();
  224.   }
  225.
  226.   /* USER CODE END 2 */
  227.         LCD_Init();
  228.         DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"Èý"
  229.         DpyNum[1] = SegCode[0];
  230.         DpyNum[2] = SegCode[0];
  231.         DpyNum[3] = SegCode[0];
  232.         DpyNum[4] = SegCode[0];
  233.         DpyNum[5] = SegCode[0];
  234.         HT1621_Display();               //Ë¢ÐÂLCD
  235. //  /*##-2- Put UART peripheral in reception process ###########################*/
  236. //  if (HAL_UART_Receive(&huart2, (uint8_t *)aRxBuffer, RXBUFFERSIZE, 5000) != HAL_OK)
  237. //  {
  238. //    Error_Handler();
  239. //  }
  240.   /* Infinite loop */
  241.   /* USER CODE BEGIN WHILE */
  242.   while (1)
  243.   {
  244.     /* Start ADC group regular conversion */
  245.     if (HAL_ADC_Start_IT(&hadc1) != HAL_OK)
  246.     {
  247.       /* Error: ADC conversion start could not be performed */
  248.       Error_Handler();
  249.     }
  250.     /* For this example purpose, wait until conversion is done */
  251.     while (ubAdcGrpRegularUnitaryConvStatus != 1);
  252.     /* Reset status variable of ADC group regular unitary conversion */
  253.     ubAdcGrpRegularUnitaryConvStatus = 0;
  254.                 qian=uhADCxConvertedData_Voltage_mVolt/1000;
  255.                 bai=uhADCxConvertedData_Voltage_mVolt%1000/100;
  256.                 shi=uhADCxConvertedData_Voltage_mVolt%100/10;
  257.                 ge=uhADCxConvertedData_Voltage_mVolt%10;
  258.                 DpyNum[2] = SegCode[qian];
  259.                 DpyNum[3] = SegCode[bai];
  260.                 DpyNum[4] = SegCode[shi];
  261.                 DpyNum[5] = SegCode[ge];
  262.                 HT1621_Display();               //Ë¢ÐÂLCD
  263.
  264.     HAL_Delay(1000);
  265.     /* Note: ADC group regular conversions data are stored into array         */
  266.     /*       "uhADCxConvertedData"                                            */
  267.     /*       (for debug: see variable content into watch window).             */
  268.     /* Note: ADC conversion data are computed to physical values              */
  269.     /*       into array "uhADCxConvertedData_Voltage_mVolt" using             */
  270.     /*       ADC LL driver helper macro "__LL_ADC_CALC_DATA_TO_VOLTAGE()"     */
  271.     /*       (for debug: see variable content with debugger)                  */
  272.     /*       in IRQ handler callback function.                                */
  273.     /* USER CODE END WHILE */
  274.     /* USER CODE BEGIN 3 */
  275.   }
  276.   /* USER CODE END 3 */
  277. }
  278. /**
  279.   * @brief System Clock Configuration
  280.   * @retval None
  281.   */
  282. void SystemClock_Config(void)
  283. {
  284.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  285.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  286.   /** Configure the main internal regulator output voltage
  287.   */
  288.   if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
  289.   {
  290.     Error_Handler();
  291.   }
  292.   /** Initializes the CPU, AHB and APB busses clocks
  293.   */
  294.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_MSI;
  295.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  296.   RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  297.   RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  298.   RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  299.   RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_4;
  300.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  301.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  302.   RCC_OscInitStruct.PLL.PLLMBOOST = RCC_PLLMBOOST_DIV1;
  303.   RCC_OscInitStruct.PLL.PLLM = 1;
  304.   RCC_OscInitStruct.PLL.PLLN = 80;
  305.   RCC_OscInitStruct.PLL.PLLP = 2;
  306.   RCC_OscInitStruct.PLL.PLLQ = 2;
  307.   RCC_OscInitStruct.PLL.PLLR = 2;
  308.   RCC_OscInitStruct.PLL.PLLRGE = RCC_PLLVCIRANGE_0;
  309.   RCC_OscInitStruct.PLL.PLLFRACN = 0;
  310.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  311.   {
  312.     Error_Handler();
  313.   }
  314.   /** Initializes the CPU, AHB and APB busses clocks
  315.   */
  316.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  317.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
  318.                               |RCC_CLOCKTYPE_PCLK3;
  319.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  320.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  321.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  322.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  323.   RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
  324.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
  325.   {
  326.     Error_Handler();
  327.   }
  328. }
  329. /**
  330.   * @brief Power Configuration
  331.   * @retval None
  332.   */
  333. static void SystemPower_Config(void)
  334. {
  335.   /*
  336.    * Disable the internal Pull-Up in Dead Battery pins of UCPD peripheral
  337.    */
  338.   HAL_PWREx_DisableUCPDDeadBattery();
  339.   /*
  340.    * Switch to SMPS regulator instead of LDO
  341.    */
  342.   if (HAL_PWREx_ConfigSupply(PWR_SMPS_SUPPLY) != HAL_OK)
  343.   {
  344.     Error_Handler();
  345.   }
  346. }
  347. /**
  348.   * @brief ADC1 Initialization Function
  349.   * @param None
  350.   * @retval None
  351.   */
  352. static void MX_ADC1_Init(void)
  353. {
  354.   /* USER CODE BEGIN ADC1_Init 0 */
  355.   /* USER CODE END ADC1_Init 0 */
  356.   ADC_ChannelConfTypeDef sConfig = {0};
  357.   /* USER CODE BEGIN ADC1_Init 1 */
  358.   /* USER CODE END ADC1_Init 1 */
  359.   /** Common config
  360.   */
  361.   hadc1.Instance = ADC1;
  362.   hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV4;
  363.   hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  364.   hadc1.Init.GainCompensation = 0;
  365.   hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  366.   hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  367.   hadc1.Init.LowPowerAutoWait = DISABLE;
  368.   hadc1.Init.ContinuousConvMode = DISABLE;
  369.   hadc1.Init.NbrOfConversion = 1;
  370.   hadc1.Init.DiscontinuousConvMode = DISABLE;
  371.   hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  372.   hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  373.   hadc1.Init.DMAContinuousRequests = DISABLE;
  374.   hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
  375.   hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  376.   hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
  377.   hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
  378.   hadc1.Init.OversamplingMode = DISABLE;
  379.   if (HAL_ADC_Init(&hadc1) != HAL_OK)
  380.   {
  381.     Error_Handler();
  382.   }
  383.   /** Configure Regular Channel
  384.   */
  385.   sConfig.Channel = ADC_CHANNEL_9;
  386.   sConfig.Rank = ADC_REGULAR_RANK_1;
  387.   sConfig.SamplingTime = ADC_SAMPLETIME_391CYCLES_5;
  388.   sConfig.SingleDiff = ADC_SINGLE_ENDED;
  389.   sConfig.OffsetNumber = ADC_OFFSET_NONE;
  390.   sConfig.Offset = 0;
  391.   if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
  392.   {
  393.     Error_Handler();
  394.   }
  395.   /* USER CODE BEGIN ADC1_Init 2 */
  396.   /* USER CODE END ADC1_Init 2 */
  397. }
  398. /**
  399.   * @brief ICACHE Initialization Function
  400.   * @param None
  401.   * @retval None
  402.   */
  403. static void MX_ICACHE_Init(void)
  404. {
  405.   /* USER CODE BEGIN ICACHE_Init 0 */
  406.   /* USER CODE END ICACHE_Init 0 */
  407.   /* USER CODE BEGIN ICACHE_Init 1 */
  408.   /* USER CODE END ICACHE_Init 1 */
  409.   /** Enable instruction cache in 1-way (direct mapped cache)
  410.   */
  411.   if (HAL_ICACHE_ConfigAssociativityMode(ICACHE_1WAY) != HAL_OK)
  412.   {
  413.     Error_Handler();
  414.   }
  415.   if (HAL_ICACHE_Enable() != HAL_OK)
  416.   {
  417.     Error_Handler();
  418.   }
  419.   /* USER CODE BEGIN ICACHE_Init 2 */
  420.   /* USER CODE END ICACHE_Init 2 */
  421. }
  422. /**
  423.   * @brief GPIO Initialization Function
  424.   * @param None
  425.   * @retval None
  426.   */
  427. static void MX_GPIO_Init(void)
  428. {
  429.   //GPIO_InitTypeDef GPIO_InitStruct = {0};
  430.   /* GPIO Ports Clock Enable */
  431.   //__HAL_RCC_GPIOA_CLK_ENABLE();
  432.   __HAL_RCC_GPIOC_CLK_ENABLE();
  433.         __HAL_RCC_GPIOD_CLK_ENABLE();
  434.         __HAL_RCC_GPIOF_CLK_ENABLE();
  435.   /*Configure GPIO pin Output Level */
  436.
  437.   /*Configure GPIO pin : LED1_Pin */
  438.   GPIO_InitStruct.Pin = GPIO_PIN_10;
  439.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  440.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  441.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  442.   HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  443.
  444.         GPIO_InitStruct.Pin = GPIO_PIN_9;
  445.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  446.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  447.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  448.   HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  449.
  450.         GPIO_InitStruct.Pin = GPIO_PIN_7;
  451.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  452.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  453.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  454.   HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  455. }
  456. /* USER CODE BEGIN 4 */
  457. /******************************************************************************/
  458. /*   USER IRQ HANDLER TREATMENT                                               */
  459. /******************************************************************************/
  460. /**
  461.   * @brief  Conversion transfer complete callback
  462.   * [url=home.php?mod=space&uid=536309]@NOTE[/url]   This function is executed when the transfer complete interrupt
  463.   *         is generated
  464.   * @retval None
  465.   */
  466. void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef *hadc)
  467. {
  468.   /* Retrieve ADC conversion data */
  469.   uhADCxConvertedData = HAL_ADC_GetValue(hadc);
  470.   /* Computation of ADC conversions raw data to physical values           */
  471.   /* using helper macro.                                                  */
  472.   uhADCxConvertedData_Voltage_mVolt = __LL_ADC_CALC_DATA_TO_VOLTAGE(ADC1, VDDA_APPLI, uhADCxConvertedData, LL_ADC_RESOLUTION_12B);
  473.   /* Update status variable of ADC unitary conversion                     */
  474.   ubAdcGrpRegularUnitaryConvStatus = 1;
  475. }
  476. /**
  477.   * @brief  ADC error interruption callback
  478.   * @retval None
  479.   */
  480. void HAL_ADC_ErrorCallback(ADC_HandleTypeDef *hadc)
  481. {
  482.   /* Note: Disable ADC interruption that caused this error before entering in
  483.            infinite loop below. */
  484.   /* In case of error due to overrun: Disable ADC group regular overrun interruption */
  485.   LL_ADC_DisableIT_OVR(ADC1);
  486.   /* Error reporting */
  487.   Error_Handler();
  488. }
  489. /* USER CODE END 4 */
  490. /**
  491.   * @brief  This function is executed in case of error occurrence.
  492.   * @retval None
  493.   */
  494. void Error_Handler(void)
  495. {
  496.   /* USER CODE BEGIN Error_Handler_Debug */
  497.   /* User can add his own implementation to report the HAL error return state */
  498.   /* Turn on LED and remain in infinite loop */
  499.   while (1)
  500.   {
  501.     BSP_LED_On(LED1);
  502.   }
  503.   /* USER CODE END Error_Handler_Debug */
  504. }
  505. #ifdef  USE_FULL_ASSERT
  506. /**
  507.   * @brief  Reports the name of the source file and the source line number
  508.   *         where the assert_param error has occurred.
  509.   * @param  file: pointer to the source file name
  510.   * @param  line: assert_param error line source number
  511.   * @retval None
  512.   */
  513. void assert_failed(uint8_t *file, uint32_t line)
  514. {
  515.   /* USER CODE BEGIN 6 */
  516.   /* User can add his own implementation to report the file name and line number,
  517.      ex: printf("Wrong parameters value: file %s on line %d", file, line) */
  518.   /* Infinite loop */
  519.   while (1)
  520.   {
  521.   }
  522.   /* USER CODE END 6 */
  523. }
  524. #endif /* USE_FULL_ASSERT */
效果图:
Stahan 发表于 2024-1-12 16:25 | 显示全部楼层
这个屏是spi的吗
 楼主| 比神乐 发表于 2024-9-21 17:06 | 显示全部楼层
