Hkk233 发表于 2023-4-1 13:48
有关F460JETA的定时器输出pwm的问题
使用F460JETA的过程中发现,在更改比较值的时候,在比较值达到设定值最大的后返回零,pwm端口会输出一段高电平,请问有大佬知道怎么回事吗?
Hkk233 发表于 2023-4-1 13:49
        /* ÈýÏàPWMÒý½Å¶¨Òå */
#define PHASE_U_GPIO                PortA
#define PHASE_U_Pin                        Pin08
#define PHASE_U_CHANEL                Timer4OcoOuh
#define PHASE_AN_GPIO                PortB
#define PHASE_AN_PIN                Pin13
#define PHASE_AN_CHANEL                Timer4OcoOul
#define PHASE_V_GPIO                PortA
#define PHASE_V_Pin                        Pin09
#define PHASE_V_CHANEL                Timer4OcoOvh
#define PHASE_BN_GPIO                PortB
#define PHASE_BN_PIN                Pin14
#define PHASE_BN_CHANEL                Timer4OcoOvl
#define PHASE_W_GPIO                PortA
#define PHASE_W_Pin                        Pin10
#define PHASE_W_CHANEL                Timer4OcoOwh
#define PHASE_CN_GPIO                PortB
#define PHASE_CN_PIN                Pin15
#define PHASE_CN_CHANEL                Timer4OcoOwl
/* ¶¨Ê±Æ÷Ïà¹Ø¶¨Òå */
#define PWM_TIMx        (M4_TMR41)
#define MOTOR_TIM4_PERIOD(2000u)
int main(void)
        SysClkConfig();
        bsp_InitDWT();
stc_port_init_t stcPortInit;
        stc_timer4_cnt_init_t stcCntInit;
        stc_timer4_oco_init_t stcOcoInit;
        stc_oco_high_ch_compare_mode_t stcHighChCmpMode;
        stc_timer4_pwm_init_t stcPwmInit;
        MEM_ZERO_STRUCT (stcPortInit);
        MEM_ZERO_STRUCT (stcCntInit);
        MEM_ZERO_STRUCT (stcOcoInit);
        MEM_ZERO_STRUCT (stcHighChCmpMode);
        MEM_ZERO_STRUCT (stcPwmInit);
        /*¿ªÆôʱÖÓ*/
        PWC_Fcg2PeriphClockCmd(PWC_FCG2_PERIPH_TIM41,Enable);//´ò¿ªtimer4¶¨Ê±Æ÷µÄʱÖÓpclk1 84mhz
//        stcPortInit.enPinMode = Pin_Mode_Out;
//        stcPortInit.enPinDrv= Pin_Drv_H;
//        stcPortInit.enPullUp= Enable;
//        PORT_Init(PHASE_UN_PORT,PHASE_UN_PIN,&stcPortInit);
//        PORT_Init(PHASE_VN_PORT,PHASE_VN_PIN,&stcPortInit);
//        PORT_Init(PHASE_WN_PORT,PHASE_WN_PIN,&stcPortInit);
//        PORT_ResetBits(PHASE_UN_PORT,PHASE_UN_PIN);
//        PORT_ResetBits(PHASE_VN_PORT,PHASE_VN_PIN);
//        PORT_ResetBits(PHASE_WN_PORT,PHASE_WN_PIN);
        /*ÅäÖÃGPIO*/
        PORT_SetFunc(PHASE_U_GPIO,PHASE_U_Pin,Func_Tim4,Disable);
        PORT_SetFunc(PHASE_V_GPIO,PHASE_V_Pin,Func_Tim4,Disable);
        PORT_SetFunc(PHASE_W_GPIO,PHASE_W_Pin,Func_Tim4,Disable);
        /*ÅäÖÃʱ»ù   ¼ÆÊýÆ÷Òç³ö = PSCÔ¤·ÖƵʱÖÓ£¬Ò»°ãÔÚ72mhz/PSC+1/ARR+1*/
        stcCntInit.enBufferCmd= Disable;                     //ʧÄÜCPSR»º´æ
        stcCntInit.enClk      = Timer4CntPclk;               //ʹÓÃpclk×÷Ϊtimer4µÄ¼ÆÊýʱÖÓ
        stcCntInit.enClkDiv   = Timer4CntPclkDiv1;         //¶Ô¼ÆÊýʱÖÓ½øÐУ¨0+1£©·ÖƵ
        stcCntInit.u16Cycle   = MOTOR_TIM4_PERIOD;         //¼ÆÊýÑ­»·Öµ£¬cpsr£¬ARR¼ÆÊý·åÖµ   84Mhz/10Khz = 8400
        stcCntInit.enCntMode    = Timer4CntTriangularWave;   //¼ÆÊýģʽΪÈý½Ç²¨Ä£Ê½
        stcCntInit.enZeroIntMsk = Timer4CntIntMask0;         //¼ÆÊýÁãµãÖÐ¶ÏÆÁ±Î ÏÂÒçÖжϸöÊý
        stcCntInit.enPeakIntMsk = Timer4CntIntMask0;          //¼ÆÊý·åÖµÖÐ¶ÏÆÁ±ÎÉÏÒçÖжϸöÊý
        TIMER4_CNT_Init(PWM_TIMx,&stcCntInit);               //³õʼ»¯¼ÆÊýµ¥Ôªtimer4
        /*ÅäÖÃÖØ×°ÔØÖµ&±È½ÏÖµ*/
        stcOcoInit.enOccrBufMode =OccrBufTrsfByCntZero;             //ÏÂÒçʱдÈëOCCRµÄÖµ
        stcOcoInit.enOcmrBufMode =OcmrBufTrsfByCntZero;            //ÏÂÒçʱдÈëOCMRµÄÖµ
        stcOcoInit.enPortLevel   =OcPortLevelLow;            //¶Ë¿ÚÊä³öÎÞЧʱ£¬Êä³öµÍµçƽ
        stcOcoInit.enOcoIntCmd   =Disable;                     //¼ÆÊýÆ¥ÅäÖжÏʧÄÜ
        TIMER4_OCO_Init(PWM_TIMx,PHASE_U_CHANEL,&stcOcoInit);
        TIMER4_OCO_Init(PWM_TIMx,PHASE_V_CHANEL,&stcOcoInit);
        TIMER4_OCO_Init(PWM_TIMx,PHASE_W_CHANEL,&stcOcoInit);
/*ÅäÖøßͨµÀ±È½ÏÊä³ö¼Ä´æÆ÷¼´ÉÏÇű۵ÄÅäÖà Ï൱ÓÚÅäÖÃÁËpwm1ģʽ*/
        stcHighChCmpMode.enCntZeroMatchOpState   =OcoOpOutputHold;    //b10~b11   occrxh = 0xoooo
        stcHighChCmpMode.enCntZeroNotMatchOpState=OcoOpOutputHold;    //b14~b15   ¹ÈÖµ£¬ÇÒ0x0000²»Îªccrʱ
        stcHighChCmpMode.enCntUpCntMatchOpState    =OcoOpOutputLow;       //b8~b9       ÏòÉϼÆÊýµ½´ïccr
        stcHighChCmpMode.enCntPeakMatchOpState   =OcoOpOutputHold;   //b6~b7   ·åÖµÇÒoccrxh = 0xffff
        stcHighChCmpMode.enCntPeakNotMatchOpState=OcoOpOutputHold;   //b12~b13·åÖµÇÒoccrxh £¡=0xffff
        stcHighChCmpMode.enCntDownCntMatchOpState=OcoOpOutputHigh;//b4~b5       ÏòϼÆÊýµ½´ïccr
        stcHighChCmpMode.enCntZeroMatchOcfState    =OcoOcfHold;         //b3ÏÂÒçµã¼ÆÊýÖµ²»Æ¥Åä   ¸ßͨµÀOCF״̬   holdΪ0 setΪ1
        stcHighChCmpMode.enCntUpCntMatchOcfState   =OcoOcfSet;         //b2ÏòÉϼÆÊý¼ÆÊýֵƥÅä
        stcHighChCmpMode.enCntPeakMatchOcfState    =OcoOcfHold;         //b1 ÉÏÒçµã    ¼ÆÊýÖµ²»Æ¥Åä
        stcHighChCmpMode.enCntDownCntMatchOcfState =OcoOcfSet;         //b0ÏòϼÆÊý¼ÆÊýֵƥÅä
        stcHighChCmpMode.enMatchConditionExtendCmd =Disable;             //²»À©Õ¹ÆäËû¼ÆÊýÌõ¼þ
        TIMER4_OCO_SetHighChCompareMode(PWM_TIMx,PHASE_U_CHANEL,&stcHighChCmpMode);
        TIMER4_OCO_SetHighChCompareMode(PWM_TIMx,PHASE_V_CHANEL,&stcHighChCmpMode);
        TIMER4_OCO_SetHighChCompareMode(PWM_TIMx,PHASE_W_CHANEL,&stcHighChCmpMode);
        TIMER4_OCO_WriteOccr(PWM_TIMx,PHASE_U_CHANEL,0);
        TIMER4_OCO_WriteOccr(PWM_TIMx,PHASE_V_CHANEL,0);
        TIMER4_OCO_WriteOccr(PWM_TIMx,PHASE_W_CHANEL,0);
        TIMER4_OCO_OutputCompareCmd(PWM_TIMx,PHASE_U_CHANEL,Enable);
        TIMER4_OCO_OutputCompareCmd(PWM_TIMx,PHASE_V_CHANEL,Enable);
        TIMER4_OCO_OutputCompareCmd(PWM_TIMx,PHASE_W_CHANEL,Enable);
        /*PWMÅäÖö˿ÚÊä³ö*/
        stcPwmInit.enRtIntMaskCmd =Enable;          //ÖØÔØ¹¦ÄÜÓÐЧʱ£¬ÖØÔØÖжÏWÊä³öÎÞЧ
        stcPwmInit.enClkDiv       =PwmPlckDiv1;   //¼ÆÊýʱÖÓ·ÖÆµ
        stcPwmInit.enOutputState=PwmHPwmLHold;    //Êä³ö¼«ÐÔ°´ÕÕÉ趨µÄÀ´£¬²»·¢Éú¸Ä±ä
        stcPwmInit.enMode         =PwmThroughMode;    //pwmËÀÇøÄ£Ê½
        TIMER4_PWM_Init(PWM_TIMx,Timer4PwmU,&stcPwmInit);
        TIMER4_PWM_Init(PWM_TIMx,Timer4PwmV,&stcPwmInit);
        TIMER4_PWM_Init(PWM_TIMx,Timer4PwmW,&stcPwmInit);
        /*Êä³ö*/
        TIMER4_CNT_ClearCountVal(PWM_TIMx);
        TIMER4_CNT_Start(PWM_TIMx);
        while(1)
        int i,j,k;
//        for(i = 0;i <= 1500;i += 200)
//                TIMER4_OCO_WriteOccr(PWM_TIMx,PHASE_U_CHANEL,i);
//                TIMER4_OCO_OutputCompareCmd(PWM_TIMx,PHASE_U_CHANEL,Enable);
//                bsp_DelayMS(500);
//        i = 0;
        for(j = 0;j <= 1500;j += 300)
                TIMER4_OCO_WriteOccr(PWM_TIMx,PHASE_V_CHANEL,j);
                bsp_DelayMS(500);
        j = 0;
//        for(k = 0;k <= 1500;k += 400)
//                TIMER4_OCO_WriteOccr(PWM_TIMx,PHASE_W_CHANEL,k);
//                TIMER4_OCO_OutputCompareCmd(PWM_TIMx,PHASE_W_CHANEL,Enable);
//        k = 0;
页: [1]
查看完整版本: 有关F460JETA的定时器输出pwm的问题
