CH32F205R_DIY测试板3_emwin6.16移植
LCD硬件规格:1.3寸,分辨率:240*240,接口:单线SPI,显示IC:ST7789;EMwin移植版本为6.16,在自带的显示驱动文件"LCDConf_FlexColor_Template.c"中更改LCD的水平分辨率和垂直分辨率.1.更改显示分辨率
#define XSIZE_PHYS240 // To be adapted to x-screen size
#define YSIZE_PHYS240 // To be adapted to y-screen size
2.添加写寄存器
static void LcdWriteReg(U8 Data)
// ... TBD by user
LCD_Write_Cmd(Data);
3.添加写数据
static void LcdWriteData(U8 Data)
// ... TBD by user
LCD_Write_Data(Data);
4.添加写多个数据
static void LcdWriteDataMultiple(U8 * pData, int NumItems)
while (NumItems--)
// ... TBD by user
LCD_Write_Data(*pData++);
5.LCD配置
void LCD_X_Config(void)
GUI_DEVICE * pDevice;
CONFIG_FLEXCOLOR Config = {0};
GUI_PORT_API PortAPI = {0};
// Set display driver and color conversion
pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_M565, 0, 0);
// Display driver configuration, required for Lin-driver
LCD_SetSizeEx (0, XSIZE_PHYS, YSIZE_PHYS);
LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
// Orientation
//Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
Config.Orientation = 0 ;
Config.NumDummyReads = 2;
GUIDRV_FlexColor_Config(pDevice, &Config);
// Set controller and operation mode
PortAPI.pfWrite8_A0= LcdWriteReg;
PortAPI.pfWrite8_A1= LcdWriteData;
PortAPI.pfWriteM8_A1 = LcdWriteDataMultiple;
PortAPI.pfReadM8_A1= LcdReadDataMultiple;
//ST7789ΪGUIDRV_FLEXCOLOR_F66709
GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66709, GUIDRV_FLEXCOLOR_M16C0B8);
6.LCD初始化
int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData)
int r;
(void) LayerIndex;
(void) pData;
switch (Cmd)
case LCD_X_INITCONTROLLER:
// Called during the initialization process in order to set up the
// display controller and put it into operation. If the display
// controller is not initialized by any external routine this needs
// to be adapted by the customer...
//调用LCD初始化
Lcd_Init();
return 0;
default:
r = -1;
return r;
7.在systemtick中添加GUI 1毫秒时基
void SysTick_Handler( void )
#include "GUI.h"
extern volatile GUI_TIMER_TIME OS_TimeMS;
++OS_TimeMS ;
8.main主程序中添加
GUI_Init();
WM_SetCreateFlags(WM_CF_MEMDEV); //使用内存设备进行重绘
GUI_UC_SetEncodeUTF8();
CreateWindow();
while( 1 )
GUI_Delay(10);
最终画面
如果更改显示分辨率了的话 那么实际显示的时候会自适应吗 qcliu 发表于 2023-5-5 16:11
感觉没有那么智能的 pc端还得适应一下呢 一般我们在配置LCD的时候都需要配置哪些参数呢 coshi 发表于 2023-5-5 17:14
垂直同步信号的后肩
垂直同步信号的前肩
垂直同步信号的脉宽
水平同步信号的后肩
水平同步信号的前肩
水平同步信号的脉宽
等等吧 水平分辨率和垂直分辨率可以随意更改的吗 kxsi 发表于 2023-5-6 08:13
水平分辨率和垂直分辨率可以随意更改的吗
感觉不能改成任意数值 得看屏幕支持不支持的吧
页:
[1]
