mnynt121 发表于 2023-4-24 15:33
HK32F030M PWM
航顺的库。。
目前是 HK32F030Mxx_ExampleV1.0.5
PWM部分的demo还没做好,这里可以参照STM32F030的搞进去
这里输出 125K 定时器 就是 8us了
* @file         : main.c
* @brief          : Main program body
* @attention
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "hk32f030m.h"
#include "hk32f030m_gpio.h"
#include <stdio.h>
#include "stdarg.h"
uint16_t PrescalerValue = 0;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void TIM_Config(void);
int main(void)
/* Infinite loop */
    RCC_Configuration();
    GPIO_Configuration();
    TIM_Config();
while (1)
/*时钟配置*/
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE );
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE );
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOC, ENABLE );
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOD, ENABLE );
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
/*GPIO配置*/
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
    /*PD4 = TIM2 Channel 1*/
    //GPIOD Configuration: Channel 1
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_4);
    /*PD3 = TIM2 Channel 2*/
    //GPIOD Configuration: Channel 2
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    GPIO_PinAFConfig(GPIOD,GPIO_PinSource3,GPIO_AF_4);
       /*PC3 = TIM2 Channel 1*/
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_PinAFConfig(GPIOC,GPIO_PinSource3,GPIO_AF_4);
      //PA3,IO翻转输出
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/*TIMER配置*/
    TIM_TimeBaseInitTypeDefTIM_TimeBaseStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    TIM2 Configuration: Encoder mode1:
    In this example TIM2 input clock (TIM2CLK) is set to APB1 clock (PCLK1).
      TIM2CLK = PCLK1
      PCLK1 = HCLK
      => TIM2CLK = HCLK = SystemCoreClock
    To get TIM2 counter clock at 32 MHz, the prescaler is computed as follows:
       Prescaler = (TIM2CLK / TIM2 counter clock) - 1
       Prescaler = ((SystemCoreClock) /32 MHz) - 1
   TIM2 is configured to interface with an encoder:
   - The encoder mode is encoder mode1: Counter counts up/down on TI2 rising edge
   depending on TI1 level
   - The Autoreload value is set to 10, so the encoder round is 10 TIM counter clock.
    Note:
   SystemCoreClock variable holds HCLK frequency and is defined in system_stm32f0xx.c file.
   Each time the core clock (HCLK) changes, user had to call SystemCoreClockUpdate()
   function to update SystemCoreClock variable value. Otherwise, any configuration
   based on this variable will be incorrect.
/* Compute the prescaler value */
// PrescalerValue = (uint16_t) ((SystemCoreClock ) / 32000000) - 1;//配置频率为32M
PrescalerValue = 32-1; /* 和下面设置预分频一样 */
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 8-1;    /* 自动重装 数值*/
TIM_TimeBaseStructure.TIM_Prescaler = 0;/* 预分频 */
TIM_TimeBaseStructure.TIM_ClockDivision = 0;/* 不分频 */
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Prescaler configuration */
/* 先配好ARR ,再设置预分频,PSC有预重装功能只能等更新事件来弄,不像ARR CRR立即更新重载 */
TIM_PrescalerConfig(TIM2, PrescalerValue, TIM_PSCReloadMode_Immediate);//每次UPdate重新初始化计数器
    /*选择编码器模式1,根据TIFP1的电平,计数器在TI2FP2的边沿上下计数*/
//TIM_EncoderInterfaceConfig(TIM2, TIM_EncoderMode_TI1, TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);
/* TIM Interrupts enable */
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
/* TIM3 enable counter */
TIM_Cmd(TIM2, ENABLE);
/* Enable the TIM2 gloabal Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
    TIM_OCInitTypeDef TIM_OCInitStructure;
    /* 频道1,2,3,4的PWM 模式设置 */
    /* PWM1 Mode configuration: Channel1 */
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;                           //PWM模式
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
   // TIM_OCInitStructure.TIM_Pulse = 500;//使能频道1配置
   // TIM_OC1Init(TIM1, &TIM_OCInitStructure);
    /* 通道1 */
    TIM_OCInitStructure.TIM_Pulse = 4;//使能频道2配置
    TIM_OC1Init(TIM2, &TIM_OCInitStructure);
    /* 通道2 */
    TIM_OC2Init(TIM2, &TIM_OCInitStructure);
    /* TIM1 主输出使能 */
    TIM_CtrlPWMOutputs(TIM2, ENABLE);
/*配置IO翻转*/
void GPIO_TogglePin(GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin)
/* Check the parameters */
assert_param(IS_GPIO_PIN(GPIO_Pin));
GPIOx->ODR ^= GPIO_Pin;
#ifdefUSE_FULL_ASSERT
* @briefReports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @paramfile: pointer to the source file name
* @paramline: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
   tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
#endif /* USE_FULL_ASSERT */转自https://www.cnblogs.com/XZHDJH/articles/13523787.html
页: [1]
查看完整版本: HK32F030M PWM
