gaoyang9992006 发表于 2023-4-26 14:49
SSD1306的OLED上实现数字正反显示操作
有朋友看了我的贴问我,接下来分享一下。
例如我定义一个函数,可以显示带框框的数字
unsigned char code num[]={
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},/*"0",0*/
{0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00},/*"1",1*/
{0x00,0x70,0x08,0x08,0x08,0x08,0xF0,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},/*"2",2*/
{0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x18,0x20,0x21,0x21,0x22,0x1C,0x00},/*"3",3*/
{0x00,0x00,0x80,0x40,0x30,0xF8,0x00,0x00,0x00,0x06,0x05,0x24,0x24,0x3F,0x24,0x24},/*"4",4*/
{0x00,0xF8,0x88,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x20,0x20,0x20,0x11,0x0E,0x00},/*"5",5*/
{0x00,0xE0,0x10,0x88,0x88,0x90,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x20,0x1F,0x00},/*"6",6*/
{0x00,0x18,0x08,0x08,0x88,0x68,0x18,0x00,0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x00},/*"7",7*/
{0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},/*"8",8*/
{0x00,0xF0,0x08,0x08,0x08,0x10,0xE0,0x00,0x00,0x01,0x12,0x22,0x22,0x11,0x0F,0x00},/*"9",9*/
void number_not(unsigned char numb,unsigned char x,unsigned char y)
        unsigned char i;
        for(i=0;i<16;i++)
                if(i==0||i==15)
                        OLED_Set_Pos(x+i,y+0);
                        OLED_WR_Byte(~0xFF,OLED_DATA);
                        OLED_Set_Pos(x+i,y+1);
                else if((i>0&&i<4)||(i>12&&i<16))
                        OLED_WR_Byte(~0x01,OLED_DATA);
                        OLED_WR_Byte(~0x80,OLED_DATA);
                else
                        OLED_WR_Byte(~(0x01|num),OLED_DATA);
                        OLED_WR_Byte(~(0x80|num),OLED_DATA);
}这个大家好理解吧。
如何反色显示呢?就是让最终屏幕上要显示的1变成0,让要实现的0变成1即可
如下
        unsigned char i;
        for(i=0;i<16;i++)
                if(i==0||i==15)
                else
}另外还可以合并这两个函数为一个函数
下面通过三目运算符合并这两个功能的函数为一个函数
void numberx(unsigned char numb, unsigned char x, unsigned char y, unsigned char flag) {
    unsigned char i;
    for (i = 0; i < 16; i++) {
      if (i == 0 || i == 15) {
            OLED_Set_Pos(x + i, y + 0);
            OLED_WR_Byte(flag ? ~0xFF : 0xFF, OLED_DATA);
            OLED_Set_Pos(x + i, y + 1);
      } else if ((i > 0 && i < 4) || (i > 12 && i < 16)) {
            OLED_WR_Byte(flag ? ~0x01 : 0x01, OLED_DATA);
            OLED_WR_Byte(flag ? ~0x80 : 0x80, OLED_DATA);
      } else {
            OLED_WR_Byte(flag ? ~(0x01 | num) : (0x01 | num), OLED_DATA);
            OLED_WR_Byte(flag ? ~(0x80 | num) : (0x80 | num), OLED_DATA);
gaoyang9992006 发表于 2023-4-26 14:50
最后上效果。
小灵通2018 发表于 2023-4-26 14:58
大佬无私奉献。
页: [1]
查看完整版本: SSD1306的OLED上实现数字正反显示操作
