Cindy@wallys 发表于 2023-5-4 14:43
Wallys/QSDK/IPQ4019 and IPQ4029 chipsets support 20 km remote transmission
The IPQ4019 and IPQ4029 chipsets from Qualcomm are designed for high-performance Wi-Fi networks, providing advanced features such as MU-MIMO, beamforming, and enhanced spectral efficiency. These chipsets are suitable for a wide range of applications, including enterprise, industrial, and residential wireless networks. When combined with the Wallys WiFi5 Industrial Wireless AP DR-AP40X9-A, these chipsets can provide exceptional long-range connectivity. The DR-AP40X9-A is designed for outdoor use and is equipped with high-power radios and antennas, allowing it to cover a large area with a strong Wi-Fi signal. With the IPQ4019 or IPQ4029 chipset, the DR-AP40X9-A can deliver reliable and high-speed wireless connectivity over long distances, making it an ideal solution for industrial applications, remote locations, and outdoor environments.
Description DR-AP4029(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;1 x Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure. Panel Antenna ■2 x 5G Antenna■5G: 17dbi DRA25 AntennaElectricalProperties : Frequency Range:2.4~2.5&5.15~5.85GHz Impedance:50Ω VSWR:2.0 Max (≤2.0) Gain(peak):6±0.5dBiPolarization:Linear; VerticalPhysical Properties :Cable:RG-141 Cable Connector:N-type PLUG Antenna CAP:ABS OperatingTemp:-40℃~+65℃ Storage Temp:-40℃~+75℃CableTemp:<+250℃ Enclosure ■Dimension: 275x140x48mm■UV Protected and Durable ABS Radome■IP67 Waterproof Level■Support WallysDR4029
DR-AP4029(Outdoor) is a high-power radio AP router that operates on both 2.4GHz and 5GHz frequencies. It comes with a DR40X9 board, an Omni antenna, a POE adapter, and an enclosure. The panel antenna of DR-AP4029 includes 2x 5G antennas with a gain of 17dbi. Additionally, the DRA25 antenna has a frequency range of 2.42.5&5.155.85GHz, a peak gain of 6±0.5dBi, and a linear vertical polarization. The antenna is connected using RG-141 cable and N-type plug connectors. It can operate within a temperature range of -40℃~+65℃ and can withstand cable temperatures of less than +250℃. The enclosure of DR-AP4029 has dimensions of 275x140x48mm and is made of UV-protected and durable ABS Radome material. It has an IP67 waterproof level and supports Wallys DR4029.
页: [1]
查看完整版本: Wallys/QSDK/IPQ4019 and IPQ4029 chipsets support 20 km remote transmission
