Cindy@wallys 发表于 2023-5-9 14:23
IPQ5018 with QCN6122/QCN6102 to achieve high-performance high-speed Wi-Fi connection.
Introduction of IPQ5018 and chip function advantages.IPQ5018/IPQ5010,802.11ax,wifi 6e,QCN9074,2X2 2.4G support 2x WiFi 6E Card support BT5.1/Dual-core ARM 64bit A53@1.0GHz Processor512MB DDRL3L System Memory4MB NOR Flash, 128MB NAND Flash2x2 On-board 2.4GHz radio,up to 573Mbps physical Data RateSupport BT5.1M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card IPQ5018 is a high-performance embedded processor launched by Qualcomm, which is specially used for Wi-Fi network applications. It integrates a quad-core ARM Cortex-A53 processor and high-speed network connection, supports multiple Wi-Fi standards, including 802.11ac and 802.11ax, and is also compatible with 802.11a/b/g/n. IPQ5018 also supports a variety of peripheral interfaces, such as USB, PCIe, etc., which can be easily connected and communicated with other devices.The main functions and advantages of the IPQ5018 chip are as follows:High performance: IPQ5018 is equipped with a quad-core ARM Cortex-A53 processor with a main frequency of up to 1.0GHz, which provides powerful computing and processing capabilities and can handle a variety of data and applications.High-speed network connection: IPQ5018 supports multiple Wi-Fi standards, including 802.11ac and 802.11ax, and is also compatible with 802.11a/b/g/n, supports dual-band Wi-Fi, and provides high-speed network connection and transmission speed.Safe and reliable: The IPQ5018 chip integrates a variety of security functions and encryption algorithms, including WPA3 encryption, AES encryption, TLS/SSL, etc., which can ensure the safety and reliability of network data transmission.Flexibility: IPQ5018 supports a variety of peripheral interfaces, such as USB, PCIe, etc., which can be easily connected and communicated with other devices, and also supports a variety of operating systems, including Linux, Android, etc., with high flexibility and reliability scalability.Low power consumption: IPQ5018 adopts advanced manufacturing technology and energy-saving design, with low power consumption and heat, suitable for various embedded application scenarios, such as smart home, Internet of Things, smart manufacturing, etc.
页: [1]
查看完整版本: IPQ5018 with QCN6122/QCN6102 to achieve high-performance high-speed Wi-Fi connection.
