wirelesswifi6 发表于 2023-5-15 16:54
IPQ9554 IIoT High Performance Network Processor Advanced Routing Function
Qualcomm (Qualcomm) IPQ9554 chip is a high-performance network processor for enterprise-class wireless routers and network equipment. The following are some functions and features of the IPQ9554 chip:
Processor performance: IPQ9554 uses a quad-core ARM Cortex-A53 processor with a maximum frequency of 2.2 GHz, providing powerful computing capabilities.
Network performance: The chip supports high-speed wired and wireless data transfers, with multiple Gigabit Ethernet ports, and integrated dual-band (2.4 GHz and 5 GHz) Wi-Fi 6 (802.11ax) wireless networking support. This enables the IPQ9554 to provide high-speed LAN and wireless connections, suitable for application scenarios that require large bandwidth and high throughput.
Security: The IPQ9554 chip has built-in powerful security functions, including hardware encryption engine, firewall, secure tunnel, etc. These features help protect the network from security threats and attacks.
QCA8075 network switch integration: The IPQ9554 chip integrates Qualcomm's QCA8075 network switch, which provides multiple Gigabit Ethernet ports and supports high-performance data forwarding and traffic management. This enables the IPQ9554 to provide high-speed, reliable wired connections in LANs.
Advanced routing function: The IPQ9554 chip supports advanced routing functions, such as multiple WAN (wide area network) connections, load balancing, virtual private network (***) and network address translation (NAT), etc. These features make the IPQ9554 chip suitable for complex network architectures and application scenarios.
Qualcomm IPQ9554 chip has a variety of applications in the industrial field, mainly focusing on the following aspects:
Industrial automation: The IPQ9554 chip can be used in industrial automation systems, including robot control, intelligent manufacturing, automated instrumentation, and equipment monitoring. Its powerful computing capability and high-speed network connection can support complex control algorithms and real-time data transmission.
Internet of Things (IoT): The IPQ9554 chip can be used to connect IoT devices and gateways to achieve high-performance wireless communication and data processing. It supports Wi-Fi 6 technology, providing faster data transmission speed and better network capacity, suitable for large-scale IoT deployment.
Network equipment: Because the IPQ9554 chip has a high-speed Ethernet interface and powerful network processing capabilities, it can be used in network equipment such as enterprise-level routers, switches, and firewalls. It supports complex network functions and security features, and is suitable for building high-performance, reliable and secure enterprise network infrastructure.
Video surveillance: The high-performance processing capability and multi-channel network interface of the IPQ9554 chip make it an ideal choice for video surveillance systems. It can process data streams from multiple high-resolution cameras while providing real-time video streaming and analytics.
Industrial Internet of Things (IIoT): The high performance and reliability of the IPQ9554 chip makes it suitable for IIoT applications. It can connect sensors, controllers and other industrial equipment to realize real-time data collection, remote monitoring and analysis, and improve production efficiency and equipment management.
Wallys has over10 years of research and development experience, experienced in linux, wifi protocol and other aspects, Qualcomm chip development drivers, kernel and other important software development, modification and compilation, to meet customers' different wifi functional needs.
We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
Clients: TIP,Facebook, Openwrt, etc
Email:sales@wallystech.com
WEB:https://www.wallystech.com/
页: [1]
查看完整版本: IPQ9554 IIoT High Performance Network Processor Advanced Routing Function
