Wallys / QCN9074/QCN9024 WIFI 6E 802.11AX 4X4 6GHz wifi module.
Features■ Qualcomm Atheros QCN9074/QCN9024
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
QCN9074 and QCN9024 are both model numbers of Qualcomm's system-on-chip (SoC) products, which are used in mobile devices such as smartphones and tablets.
The QCN9074 is a newer and more advanced SoC compared to the QCN9024. It is based on the 5nm manufacturing process and has a more powerful CPU and GPU, as well as better support for advanced connectivity features such as Wi-Fi 6E and 5G.
In contrast, the QCN9024 is based on the 8nm manufacturing process and is a slightly older and less powerful SoC. It still offers good performance and features, but it may not be as advanced or efficient as the QCN9074.
In summary, the main differences between the QCN9074 and QCN9024 are their manufacturing process, performance, and support for advanced connectivity features.
QCN9074 和 QCN7024 的区别
1. Qualcomm Atheros QCN9074/QCN9024: This refers to the specific model or chipset used in the wireless network adapter. Qualcomm Atheros is a well-known manufacturer of wireless communication products. 2. 6GHz, max 23dBm per chain, up to 4949Mbps: This indicates the frequency band and the maximum power output of the wireless adapter. It operates in the 6GHz frequency range and can transmit up to 23dBm (decibels per milliwatt) of power per chain. The maximum data transfer rate supported is 4949Mbps (megabits per second). 3. Single Band 6GHz 4x4 WiFi 6E (802.11ax): This describes the type of wireless technology used by the adapter. It supports the WiFi 6E standard (also known as 802.11ax), which operates in the 6GHz frequency range. It has a 4x4 configuration, meaning it supports four transmit and four receive streams. 4. spatial streams (4SS): This refers to the number of spatial streams supported by the wireless adapter. In this case, it supports four spatial streams, which can enhance the data transfer capacity and improve overall performance. 5. M.2 E Key Interface: This indicates the physical interface used for connecting the wireless adapter to a compatible device. The M.2 E Key interface is a standardized connector commonly used for wireless communication modules. 6. PCI Express 3.0 Interface: This indicates an alternative interface option for connecting the wireless adapter. The PCI Express (PCIe) 3.0 interface is a widely used high-speed serial expansion bus standard that provides a fast and reliable connection between the adapter and the device it's installed in. Overall, the wireless network adapter you described is a high-performance module designed for use in devices such as laptops, desktops, or other devices that require a fast and reliable wireless connection in the 6GHz frequency band.
页:
[1]
