快速获取结构体成员大小
#include <stdio.h>// 获取结构体成员大小
#defineGET_MEMBER_SIZE(type, member) sizeof(((type*)0)->member)
// 获取结构体成员偏移量
#defineGET_MEMBER_OFFSET(type, member)((size_t)(&(((type*)0)->member)))
typedef struct _test_struct0
char x;
char y;
char z;
}test_struct0;
typedef struct _test_struct1
char a;
char c;
short b;
int d;
test_struct0 e;
}test_struct1;
int main(int arc, char *argv[])
printf("GET_MEMBER_SIZE(test_struct1, a) = %ld\n", GET_MEMBER_SIZE(test_struct1, a));
printf("GET_MEMBER_SIZE(test_struct1, c) = %ld\n", GET_MEMBER_SIZE(test_struct1, c));
printf("GET_MEMBER_SIZE(test_struct1, b) = %ld\n", GET_MEMBER_SIZE(test_struct1, b));
printf("GET_MEMBER_SIZE(test_struct1, d) = %ld\n", GET_MEMBER_SIZE(test_struct1, d));
printf("GET_MEMBER_SIZE(test_struct1, e) = %ld\n", GET_MEMBER_SIZE(test_struct1, e));
printf("test_struct1 size = %ld\n", sizeof(test_struct1));
printf("GET_MEMBER_OFFSET(a): %ld\n", GET_MEMBER_OFFSET(test_struct1, a));
printf("GET_MEMBER_OFFSET(c): %ld\n", GET_MEMBER_OFFSET(test_struct1, c));
printf("GET_MEMBER_OFFSET(b): %ld\n", GET_MEMBER_OFFSET(test_struct1, b));
printf("GET_MEMBER_OFFSET(d): %ld\n", GET_MEMBER_OFFSET(test_struct1, d));
printf("GET_MEMBER_OFFSET(e): %ld\n", GET_MEMBER_OFFSET(test_struct1, e));
return 0;
真不错,这种就可以用已有的库实现获取数组的大小,非常节省时间呢
页:
[1]
