VERILOG实现异步FIFO
首先要理解fifo的写满和读空,用多出来的一位来扩充地址使用格雷码判断当,写指针追上读指针时候就是写满,为了方便判断当写满时候即,写地址地最高和次高位与读地址相反其他位相同时就是写满,当读地址的所有位和写地址的所有位相等就是读空代码根据图可以轻松得到:
下图是地址计数器的增加图https://www.freesion.com/images/757/891f5a96acd0b3e4e0f4046c20b9c2dd.png
https://www.freesion.com/images/586/8eda161204b5d3d629b7407e3ba8253a.png写控制器:
module w_ctrl(
input wire w_clk,//写时钟
input wire rst_n,//复位
input wire w_en,//写使能
input wire r_gaddr,//读时钟域过来的格雷码读地址指针
output reg w_full,//写满标志
output wire w_addr,//256深度的FIFO写二进制地址
output wire w_gaddr//写FIFO地址格雷码编码
reg addr;
reg gaddr;
wire addr_wire;
wire gaddr_wire;
reg r_gaddr_d1,r_gaddr_d2;
wire w_full_wire;
//打两拍进行时钟同步
always @(posedge w_clk or negedge rst_n)
if(rst_n == 1'b0)
{r_gaddr_d2,r_gaddr_d1} <= 18'd0;
else
{r_gaddr_d2,r_gaddr_d1} <= {r_gaddr_d1,r_gaddr};
//产生些ram的地址指针二进制
assign w_addr = addr;
if(rst_n == 1'b0)
addr <= 9'd0;
else
addr <= addr_wire;
assign addr_wire = addr + ((~w_full)&w_en);
//转换格雷码编码地址
assign gaddr_wire=(addr_wire>>1)^addr_wire;
if(rst_n == 1'b0)
gaddr<=9'd0;
else gaddr <= gaddr_wire;
assign w_gaddr = gaddr;
//写满标志产生完成
if(rst_n == 1'b0)
w_full <= 1'b0;
else if({~gaddr_wire,gaddr_wire}==r_gaddr_d2)//根据仿真验证一下打两拍对空满标志的影响???
w_full <=1'b1; //w_full_wire;
else w_full <=1'b0;
endmodule
读数据:
module r_ctrl (
input wire r_clk,//读时钟
input wire rst_n,
input wire r_en,//读使能
input wire w_gaddr,//写时钟域中的写地址指针
output reg r_empty,//读空标志
output wire r_addr,//读地址二进制
output wire r_gaddr//读格雷码地址
reg addr;
reg gaddr;
wire addr_wire;
wire gaddr_wire;
reg w_gaddr_d1,w_gaddr_d2;
wire r_empty_wire;
//打两拍进行时钟同步
always @(posedge r_clk or negedge rst_n)
if(rst_n == 1'b0)
{w_gaddr_d2,w_gaddr_d1} <= 18'd0;
else
{w_gaddr_d2,w_gaddr_d1} <= {w_gaddr_d1,w_gaddr};
//二进制的读地址
assign r_addr = addr;
always @(posedge r_clkor negedge rst_n)
if(rst_n == 1'b0)
addr <=9'd0;
else
addr <= addr_wire;
assign addr_wire = addr + ((~r_empty)&r_en);
//格雷码的读地址
assign r_gaddr = gaddr;
assign gaddr_wire = (addr_wire >>1 )^ addr_wire;
if(rst_n == 1'b0)
gaddr <= 9'd0;
else
//读空标志的产生
assign r_empty_wire =(gaddr_wire == w_gaddr_d2);
if(rst_n == 1'b0)
r_empty<=1'b1;
else //if(gaddr_wire == w_gaddr_d2)//根据仿真验证一下打两拍对空满标志的影响???
r_empty <= r_empty_wire;
//else
//r_empty <= 1'b0;
endmodule
下面是fifo_mem实现:
module fifomem(
input wire w_clk,
input wire r_clk,
input wire w_en,//来自于FIFO的写控制模块
input wire w_full,//来自于FIFO的写控制模块
input wire w_data,//来自于外部数据源
input wire w_addr,//来自于FIFO的写控制模块
input wire r_empty,//来自于FIFO的读控制模块
input wire r_addr,//来自于FIFO的读控制模块
inputwire rst_n,
output reg r_data//读数据是从内部ram中读取
regdata_mem;
wire w_addr_r;//定义写入地址
wire r_addr_r;//定义写入地址
integer i;
assign w_addr_r = w_addr;
assign r_addr_r = r_addr;
//写入数据
always@(posedge w_clk or negedge rst_n)
if(!rst_n)begin
for(i = 0;i < 256;i = i + 1)begin
data_mem <= 8'b0;
end
end
else if(w_en &&(!w_full))//防止写溢出,如果已经满了禁止写数据
data_mem <= w_data;
//读出数据
always@(posedge r_clk or negedge rst_n)
if(!rst_n)
r_data <= 0;
else
r_data <=data_mem;
endmodule
下面是顶层模块:
module ex_fifo(
input wire w_clk,
input wire r_clk,
input wire rst_n,
input wire w_en,
input wire w_data,
output wire w_full,
input wire r_en,
output wire r_data,
output wire r_empty
wire r_gaddr;
wire w_addr;
wire w_gaddr;
wire r_addr;
w_ctrl w_ctrl_inst(
.w_clk (w_clk),//写时钟
.rst_n (rst_n),//复位
.w_en (w_en),//写使能
.r_gaddr (r_gaddr),//读时钟域过来的格雷码读地址指针
.w_full (w_full),//写满标志
.w_addr (w_addr),//256深度的FIFO写二进制地址
.w_gaddr (w_gaddr)//写FIFO地址格雷码编码
fifomem fifomem_inst(
.w_clk (w_clk),
.r_clk (r_clk),
.w_en (w_en),//来自于FIFO的写控制模块
.w_full (w_full),//来自于FIFO的写控制模块
.w_data (w_data),//来自于外部数据源
.w_addr (w_addr),//来自于FIFO的写控制模块
.r_empty (r_empty),//来自于FIFO的读控制模块
.r_addr (r_addr),//来自于FIFO的读控制模块
.r_data (r_data),//读数据是从内部ram中读取
.rst_n(rst_n)
r_ctrl r_ctrl_inst(
.r_clk (r_clk),//读时钟
.rst_n (rst_n),
.r_en (r_en),//读使能
.w_gaddr (w_gaddr),//写时钟域中的写地址指针
.r_empty (r_empty),//读空标志
.r_addr (r_addr),//读地址二进制
.r_gaddr (r_gaddr)//读格雷码地址
endmodule
下面是testbench:
`timescale 1ns/1ns
module tb_ex_fifo;
reg r_clk,w_clk,rst_n;
reg w_en;
reg w_data;
reg r_en;
wire w_full;
wire r_empty;
wire r_data;
parameter CLK_P=20;
initial begin
rst_n<=0;
r_clk<=0;
w_clk<=0;
#200
rst_n=1;
end
//写的初始化模块
initial begin
w_en=0;
w_data=0;
#300
write_data(256);
end
//读的初始化模块
initial begin
r_en =0;
@(posedge w_full);
#40;
read_data(256);
end
always #(CLK_P/2) r_clk =~r_clk;
always #(CLK_P/2) w_clk =~w_clk;
ex_fifo ex_fifo_inst(
.w_clk (w_clk),
.r_clk (r_clk),
.rst_n (rst_n),
.w_en (w_en),
.w_data (w_data),
.w_full (w_full),
.r_en (r_en),
.r_data (r_data),
.r_empty (r_empty)
task write_data(len);
integer i,len;
begin
for (i=0;i<len;i=i+1)
begin
@(posedge w_clk);
w_en=1'b1;
w_data=i;
end
@(posedge w_clk);
w_en = 1'b0;
w_data =0;
end
endtask
task read_data(len);
integer i,len;
begin
begin
@(posedge r_clk);
r_en=1'b1;
end
@(posedge r_clk);
r_en = 1'b0;
end
endtask
endmodule
自己用modelsim仿真脚本如下:
quit -sim
.main clear
vlib work
vlog ./tb_ex_fifo.v
vlog ./../design/*.v
vsim -voptargs=+acc work.tb_ex_fifo
add wave tb_ex_fifo/*
add wave tb_ex_fifo/ex_fifo_inst/*
add wave -divider {w}
add wave tb_ex_fifo/ex_fifo_inst/w_ctrl_inst/*
add wave -divider {R}
add wave tb_ex_fifo/ex_fifo_inst/r_ctrl_inst/*
run 25us
页:
[1]
