SWdianzi 发表于 2023-8-23 16:29
ZC811 RESET IC替代MAX811
Features
 Precision voltage monitor for 3V, 3.3V or 5V power supplies
 140ms minimum reset pulse width available
 Reset remains valid with V CC as low as 1V
 3μAtypical supply current
 Available in 4-pin SOT-143 package
Applications
 Computer
 Controller
 Intelligent Instruments
 Critical uP and uC Power Monitoring
 Portable/Battery-Powered Equipment
Description
The ZC811is a low-power microprocessor (μP)
supervisory circuit used to monitor power supplies
in microprocessor and digital systems. Low supply
current makes the ZC811ideal for use in portable
equipment. The device comes in a 4-pin SOT-143
package.
The ZC811provides excellent circuit reliability and
low BOM cost by eliminating external components
and adjustments when used with 5V-powered or
3V-powered circuits. The ZC811also provides a
debounced manual reset input.
The function of this device is to assert a reset if
either the power supply drops below a designed
reset threshold level or MR is forced low. The
reset comparator is designed to ignore fast transients
on V CC . Reset thresholds are available for operation
with a variety of supply voltages.
https://bbs.21ic.com/data/attachment/forum/202308/15/144618vnwwsccnissx5cre.png.thumb.jpg
页: [1]
查看完整版本: ZC811 RESET IC替代MAX811
