hehhehee 发表于 2023-8-31 07:59
灵动微MM32F013x芯片学习-内部RC时钟倍频
MM32F013x内部集成了48Mhz的RC时钟,同时也有PLL,所以,这里采用PLL倍频内部RC时钟的方式,产生72MHZ的系统时钟。
上代码:
void clk_init(void)
    u8 temp=0;
    RCC->CR |= RCC_CR_HSION;
    while(!(RCC->CR & RCC_CR_HSIRDY));
    // HSI/4 is the input clock for pll
    RCC->CFGR &= ~RCC_CFGR_PLLSRC;
    //set pll mul
    RCC->CR &= ~RCC_CR_PLLDIV;// PLLDIV=0,M=1
    RCC->CR &= ~(0x1f << 26);//PLLMUL=5,N=6
    RCC->CR |= (6 - 1) << 26;
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;//AHB factor
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV2;//APB1 factor
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;//APB2 factor
    FLASH->ACR = FLASH_ACR_LATENCY_2 | FLASH_ACR_PRFTBE;//important
    //enable pll
    RCC->CR |= RCC_CR_PLLON;
    while(!(RCC->CR & RCC_CR_PLLRDY));
    // select pll as system clock
    RCC->CFGR &= ~RCC_CFGR_SW;
    RCC->CFGR |= RCC_CFGR_SW_PLL;
    //wait unitl system clock is switched to pll
    while(temp != 0x02)
      temp = RCC->CFGR >> 2;
      temp &= 0x03;
页: [1]
查看完整版本: 灵动微MM32F013x芯片学习-内部RC时钟倍频
