国民N32G031使用发光二极管上电闪亮。
我的发光LED驱动是低电平导通的,而国民的这个芯片上电默认是模拟输入,导致我的板子上电一瞬间灯会亮一下。不改变电路的情况下,请问一下如何解决,谢谢了。 修改i/o初始配置。 它的底层代码吗?void SystemInit(void)
/* FPU settings
#if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
SCB->CPACR |= ((3UL << 10 * 2) | (3UL << 11 * 2)); /* set CP10 and CP11 Full Access */
#endif
/* Reset the RCC clock configuration to the default reset state(for debug purpose) */
/* Set MSIEN bit */
RCC->CTRLSTS |= (uint32_t)0x00000004;
/* Reset SW, HPRE, PPRE1, PPRE2 and MCO bits */
RCC->CFG &= (uint32_t)0xF8FFC000;
/* Reset HSEON, CLKSSEN and PLLEN bits */
RCC->CTRL &= (uint32_t)0xFEF6FFFF;
/* Reset HSEBYP bit */
RCC->CTRL &= (uint32_t)0xFFFBFFFF;
/* Reset PLLSRC, PLLXTPRE, PLLMUL, MCOPRES and USBPRES bits */
RCC->CFG &= (uint32_t)0x0700FFFF;
/* Reset CFG2 register */
RCC->CFG2 = 0x00000000;
/* Reset CFG3 register */
RCC->CFG3 = 0x00000000;
/* Reset RDCTRL register */
RCC->RDCTRL = 0x00000000;
/* Reset PLLHSIPRE register */
RCC->PLLHSIPRE = 0x00000000;
/* Disable all interrupts and clear pending bits*/
RCC->CLKINT = 0x04BF8000;
/* Enable ex mode */
RCC->APB1PCLKEN |= RCC_APB1PCLKEN_PWREN;
RCC->APB1PCLKEN &= (uint32_t)(~RCC_APB1PCLKEN_PWREN);
/* Enable ICACHE and Prefetch Buffer */
FLASH->AC |= (uint32_t)(FLASH_AC_ICAHEN | FLASH_AC_PRFTBFEN);
/* Checks whether the Low Voltage Mode status is SET or RESET */
if((FLASH->AC & FLASH_AC_LVMF) != RESET)
/* FLASH Low Voltage Mode Disable */
FLASH->AC &= (uint32_t)(~FLASH_AC_LVMEN);
#ifdef DATA_IN_ExtSRAM
SystemInit_ExtMemCtl();
#endif /* DATA_IN_ExtSRAM */
/* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
/* Configure the Flash Latency cycles and enable prefetch buffer */
SetSysClock();
#ifdef VECT_TAB_SRAM
SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */
#else
SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */
#endif
} 顾言 发表于 2023-9-7 14:57
修改i/o初始配置。
它的底层代码吗?
/* FPU settings
#endif
/* Set MSIEN bit */
SetSysClock();
#else
#endif
} 在修改端口为输出模式之前,先把LED 对应的端口输出寄存器POD对应位置1.
复位时,POD位大部分默认为0. 如果不这么操作是会闪一下。 xch 发表于 2023-9-7 15:59
复位时,POD位大部分默认为0. 如果 ...
main 函数入口设置一个断点。或者死循环。LED应当不亮。
如果亮了,改硬件。 ...
你用了哪只引脚? Pxy? xch 发表于 2023-9-8 17:35
你用了哪只引脚? Pxy?
data:image/png;base64,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***v***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**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**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***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
小白儿 发表于 2023-9-9 11:58
PB8\PB9 xch 发表于 2023-9-8 17:35
你用了哪只引脚? Pxy?
PB8\PB9 小白儿 发表于 2023-9-9 17:22
PB8\PB9
还是软件问题 xch 发表于 2023-9-9 21:24
还是软件问题
我知道,我查了相关资料,很多芯片上电是浮空输入,属于高阻态上电没这个问题,国民的是模拟输入。 小白儿 发表于 2023-9-11 17:15
我知道,我查了相关资料,很多芯片上电是浮空输入,属于高阻态上电没这个问题,国民的是模拟输入。 ...
用JFLASH 工具擦除芯片。然后上电。LED应该不亮。如果还亮,检查一下电路
常量了{:sad:}
页:
[1]
