tlled 发表于 2023-10-25 17:36
【AT-START-F423测评】+串口printf
测试串口,使用printf打印输出。
一、硬件电路部分
仿真器带调试串口,调试串口连接硬件的MCU的USRAT1。
二、程序
2.1、usart.c
#include "stdio.h"
#include "at32f423.h"
#include "usart/usart.h"
/* support printf function, usemicrolib is unnecessary */
#if (__ARMCC_VERSION > 6000000)
__asm (".global __use_no_semihosting\n\t");
void _sys_exit(int x)
    x = x;
/* __use_no_semihosting was requested, but _ttywrch was */
void _ttywrch(int ch)
    ch = ch;
FILE __stdout;
#else
#ifdef __CC_ARM
#pragma import(__use_no_semihosting)
struct __FILE
    int handle;
FILE __stdout;
    x = x;
    ch = ch;
#endif
#endif
#if defined (__GNUC__) && !defined (__clang__)
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif
* @briefretargets the c library printf function to the usart.
* @paramnone
* @retval none
PUTCHAR_PROTOTYPE
while(usart_flag_get(USART1, USART_TDBE_FLAG) == RESET);
usart_data_transmit(USART1, (uint16_t)ch);
while(usart_flag_get(USART1, USART_TDC_FLAG) == RESET);
return ch;
#if (defined (__GNUC__) && !defined (__clang__)) || (defined (__ICCARM__))
int _write(int fd, char *pbuffer, int size)
#elif defined ( __ICCARM__ )
#pragma module_name = "?__write"
int __write(int fd, char *pbuffer, int size)
#endif
for(int i = 0; i < size; i ++)
    while(usart_flag_get(PRINT_UART, USART_TDBE_FLAG) == RESET);
    usart_data_transmit(PRINT_UART, (uint16_t)(*pbuffer++));
    while(usart_flag_get(PRINT_UART, USART_TDC_FLAG) == RESET);
return size;
#endif
void init_usart(uint32_t baudrate)
        gpio_init_type gpio_init_struct;
setvbuf(stdout, NULL, _IONBF, 0);
#endif
/* enable the uart and gpio clock */
crm_periph_clock_enable(USART1_CLOCK, TRUE);
crm_periph_clock_enable(USART1_GPIO_CLOCK, TRUE);
gpio_default_para_init(&gpio_init_struct);
/* configure the uart tx pin */
gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
gpio_init_struct.gpio_out_type= GPIO_OUTPUT_PUSH_PULL;
gpio_init_struct.gpio_mode = GPIO_MODE_MUX;
gpio_init_struct.gpio_pins = USART1_TX_PIN;
gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
gpio_init(USART1_GPIO, &gpio_init_struct);
gpio_pin_mux_config(USART1_GPIO, USART1_TX_PIN_SOURCE, USART1_TX_PIN_MUX_NUM);
/* configure uart param */
usart_init(USART1, baudrate, USART_DATA_8BITS, USART_STOP_1_BIT);
usart_transmitter_enable(USART1, TRUE);
usart_enable(USART1, TRUE);
2.2、usart.h
#ifndef _USART_H
#define _USART_H
#define USART1_CLOCK                      CRM_USART1_PERIPH_CLOCK
#define USART1_TX_PIN                GPIO_PINS_9
#define USART1_GPIO                  GPIOA
#define USART1_GPIO_CLOCK                  CRM_GPIOA_PERIPH_CLOCK
#define USART1_TX_PIN_SOURCE         GPIO_PINS_SOURCE9
#define USART1_TX_PIN_MUX_NUM      GPIO_MUX_7
void init_usart(uint32_t baudrate);
#endif
2.3、main.c
#include "at32f423_board.h"
#include "at32f423_clock.h"
#include "led/led.h"
#include "key/key.h"
int main(void)
system_clock_config();
at32_board_init();
        init_led();
        init_key();
        init_usart(115200);
while(1)
    led2_tog();
    delay_ms(200);
    led3_tog();
    delay_ms(200);
    led4_tog();
    delay_ms(200);
                printf("AT32F423 USART1 TEST! \r\n");
三、程序运行
页: [1]
查看完整版本: 【AT-START-F423测评】+串口printf
