分享CH32V307VCT6 驱动ST7735 LCD的C代码
以下是一个使用C语言编写的驱动ST7735 LCD的示例代码:#include <stdio.h>
#include <stdint.h>
#include "stm32f4xx.h"
// 定义SPI接口的引脚和端口
#define SPI_PORT GPIOC
#define SPI_CLK_PIN GPIO_Pin_10
#define SPI_MOSI_PIN GPIO_Pin_12
// 定义D/C引脚所在的端口和引脚
#define DC_PIN GPIO_Pin_15
#define DC_PORT GPIOA
// 定义RST引脚所在的端口和引脚
#define RST_PIN GPIO_Pin_5
#define RST_PORT GPIOB
// 定义SPI控制器
#define SPIx SPI3
void SPI_Config(void)
SPI_InitTypeDef SPI_InitStructure;
// 使能SPI和GPIO时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOA, ENABLE);
// 配置SPI引脚
GPIO_InitStructure.GPIO_Pin = SPI_CLK_PIN | SPI_MOSI_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_DOWN;
GPIO_Init(SPI_PORT, &GPIO_InitStructure);
// 配置D/C引脚为输出
GPIO_InitStructure.GPIO_Pin = DC_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_NOPULL;
GPIO_Init(DC_PORT, &GPIO_InitStructure);
// 配置RST引脚为输出
GPIO_InitStructure.GPIO_Pin = RST_PIN;
GPIO_Init(RST_PORT, &GPIO_InitStructure);
// 将引脚连到SPI功能
GPIO_PinAFConfig(SPI_PORT, GPIO_PinSource10, GPIO_AF_SPI3);
GPIO_PinAFConfig(SPI_PORT, GPIO_PinSource12, GPIO_AF_SPI3);
// 配置SPI控制器
SPI_I2S_DeInit(SPIx);
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPIx, &SPI_InitStructure);
SPI_Cmd(SPIx, ENABLE);
void SPI_SendCommand(uint8_t cmd)
// 设置D/C为低电平,表示发送命令
GPIO_ResetBits(DC_PORT, DC_PIN);
// 等待SPI发送缓冲区空
while (SPI_I2S_GetFlagStatus(SPIx, SPI_I2S_FLAG_TXE) == RESET);
// 发送命令
SPI_SendData8(SPIx, cmd);
while(SPI_I2S_GetFlagStatus(SPIx, SPI_I2S_FLAG_BSY) == SET);
void SPI_SendData(uint8_t data)
// 设置D/C引脚为高电平,表示发送数据
GPIO_SetBits(DC_PORT, DC_PIN);
// 等待SPI发送缓冲区空
// 发送数据
SPI_SendData8(SPIx, data);
void LCD_Reset(void)
// 复位LCD
GPIO_ResetBits(RST_PORT, RST_PIN);
delay_ms(100);
GPIO_SetBits(RST_PORT, RST_PIN);
delay_ms(100);
void LCD_Init(void)
LCD_Reset();
SPI_SendCommand(0x11); // Sleep Out
delay_ms(100);
SPI_SendCommand(0xB1); // Frame Rate Control
SPI_SendData(0x01);
SPI_SendData(0x2C);
SPI_SendData(0x2D);
SPI_SendCommand(0xB2); // Frame Rate Control
SPI_SendData(0x01);
SPI_SendData(0x2C);
SPI_SendData(0x2D);
SPI_SendCommand(0xB3); // Frame Rate Control
SPI_SendData(0x01);
SPI_SendData(0x2C);
SPI_SendData(0x2D);
SPI_SendData(0x01);
SPI_SendData(0x2C);
SPI_SendData(0x2D);
SPI_SendCommand(0xB4); // Display Inversion Control
SPI_SendData(0x07);
SPI_SendCommand(0xC0); // Power Control 1
SPI_SendData(0xA2);
SPI_SendData(0x02);
SPI_SendData(0x84);
SPI_SendCommand(0xC1); // Power Control 2
SPI_SendData(0xC5);
SPI_SendCommand(0xC2); // Power Control 3
SPI_SendData(0x0A);
SPI_SendData(0x00);
SPI_SendCommand(0xC3); // Power Control 4
SPI_SendData(0x8A);
SPI_SendData(0x2A);
SPI_SendCommand(0xC4); // Power Control 5
SPI_SendData(0x8A);
SPI_SendData(0xEE);
SPI_SendCommand(0xC5); // VCOM Control 1
SPI_SendData(0x0E);
SPI_SendCommand(0x36); // Memory Access Control
SPI_SendData(0xC8);
SPI_SendCommand(0x3A); // COLMOD Pixel Format Set
SPI_SendData(0x05);
SPI_SendCommand(0x2A); // Column Address Set
SPI_SendData(0x00);
SPI_SendData(0x02);
SPI_SendData(0x00);
SPI_SendData(0x7F);
SPI_SendCommand(0x2B); // Page Address Set
SPI_SendData(0x00);
SPI_SendData(0x01);
SPI_SendData(0x00);
SPI_SendData(0x9F);
SPI_SendCommand(0x29); // Display ON
void LCD_DrawPixel(uint16_t x, uint16_t y, uint16_t color)
SPI_SendData((x >> 8) & 0xFF);
SPI_SendData(x & 0xFF);
SPI_SendData(((x + 1) >> 8) & 0xFF);
SPI_SendData((x + 1) & 0xFF);
SPI_SendData((y >> 8) & 0xFF);
SPI_SendData(y & 0xFF);
SPI_SendData(((y + 1) >> 8) & 0xFF);
SPI_SendData((y + 1) & 0xFF);
SPI_SendCommand(0x2C); // Memory Write
SPI_SendData((color >> 8) & 0xFF);
SPI_SendData(color & 0xFF);
void LCD_FillRect(uint16_t x, uint16_t y, uint16_t width, uint16_t height, uint16_t color)
uint16_t i, j;
SPI_SendData(((x + width - 1) >> 8) & 0xFF);
SPI_SendData((x + width - 1) & 0xFF);
SPI_SendData(((y + height - 1) >> 8) & 0xFF);
SPI_SendData((y + height - 1) & 0xFF);
for (i = 0; i < width; i++) {
for (j = 0; j < height; j++) {
void delay_ms(uint32_t ms)
volatile uint32_t nCount;
RCC_ClocksTypeDef RCC_Clocks;
RCC_GetClocksFreq(&RCC_Clocks);
nCount = (RCC_Clocks.HCLK_Frequency / 10000) * ms;
for (; nCount != 0; nCount--);
int main(void)
SPI_Config();
LCD_Init();
// 示例:绘制一个红色的矩形框
LCD_FillRect(10, 10, 100, 50, 0xF800);
while (1) {
这个代码使用STM32的SPI3接口连接到ST7735 LCD,页面显示一个红色的矩形框。你可以根据需要修改代码来支持英文、画图和汉字显示。请确保在使用之前正确配置STM32的GPIO引脚和SPI控制器。 其他系列可以用吗
页:
[1]
