AT32 MCU OTGHS Application Note
前言本文档主要描述AT32 OTGHS 外设特性,OTGHS 支持主机和设备模式。OTGHS 可以通过ID 线判
断当前处于主机还是设备模式,也可以配置为只支持设备或者主机模式。
目录
1 OTGHS 介绍 ............................................................................................................ 5
1.1 OTGHS 特性 ............................................................................................................ 5
1.2 OTGHS 高速PHY .................................................................................................... 6
1.3 OTGHS GPIO 引脚 ................................................................................................... 6
1.4 OTGHS 12MHz 时钟 ................................................................................................ 7
1.5 OTGHS 数据FIFO 管理 ........................................................................................... 7
1.5.1 设备模式下的FIFO 分配 .............................................................................................. 7
1.5.2 主机模式下的FIFO 分配 .............................................................................................. 8
1.6 OTGHS 中断结构 ................................................................................................... 10
2 OTG 模式 ............................................................................................................... 12
3 设备模式 ................................................................................................................ 13
3.1 OTGHS 强制作为设备 ............................................................................................ 13
3.2 OTGHS 设备常用功能 ............................................................................................ 13
3.3 OTGHS 设备端点配置 ............................................................................................ 14
3.3.1 IN 端点配置 ................................................................................................................. 14
3.3.2 OUT 端点配置............................................................................................................. 14
4 主机模式 ................................................................................................................ 15
4.1 OTGHS 强制作为主机 ............................................................................................ 15
4.2 OTGHS 主机常用功能 ............................................................................................ 15
4.3 OTGHS 主机通道配置 ............................................................................................ 16
5 版本历史 ................................................................................................................ 17
页:
[1]
