dzfansman 发表于 2023-11-13 15:23
AURIX-studio安装流程
1.1、软件安装包①、百度云盘:链接:https://pan.baidu.com/s/1qQAiDWATcTbgict4WQKTCQ 提取码:lhzb
②、官网下载地址:
https://www.infineon.com/cms/en/product/promopages/aurix-development-studio/https://pic2.zhimg.com/80/v2-b472ab0131dc3fb1123b88d442a51cf9_720w.webp1.2、右击以管理员身份运行安装包https://pic4.zhimg.com/80/v2-5e834bcd5b0e089108f42d08aabae92f_720w.webp1.3、选择安装路径,尽量不要放在C盘https://pic3.zhimg.com/80/v2-81feb7dfd6b7edf84c295ac7c0165496_720w.webp1.4、选择nexthttps://pic1.zhimg.com/80/v2-d346e0c5a8538bde81078b307bf8499c_720w.webp1.5、选择installhttps://pic3.zhimg.com/80/v2-5e565c776136f754cf5045c0c82d6e2a_720w.webphttps://pic4.zhimg.com/80/v2-727aef9126bec85b6d812d7c07f080f7_720w.webp1.6、安装DAS驱动,选择nexthttps://pic3.zhimg.com/80/v2-a7512da67b59c7dc96afd793c51cb362_720w.webp1.7、打勾,选择nexthttps://pic1.zhimg.com/80/v2-25d377589febc0a500ce425477dc3d24_720w.webphttps://pic2.zhimg.com/80/v2-d4f5a9bbf33a9f4cd4811e68f9778c8d_720w.webp1.8、选择nexthttps://pic2.zhimg.com/80/v2-9f48abaca345be9ecbd836b83c31c2b5_720w.webp1.9、完成安装!https://pic2.zhimg.com/80/v2-388075b0a28e49ecdae46d1663c3b361_720w.webp1.10、安装好后,就会显示如下软件,AURIX Developmen Studio是IDE,DAS Device Scanner为驱动。https://pic4.zhimg.com/80/v2-be48c01cde2bbe9e12bcda576d4ff8db_720w.webp
二、导入工程2.1、选择工作空间(不要有中文路径)https://pic1.zhimg.com/80/v2-f5aefea0803d04bf8355a55c2f58ea80_720w.webp2.2导入工程选择file-import--导入工程https://pic2.zhimg.com/80/v2-17ac5bd7bc45c0590e3d3e984e67ee05_720w.webp2.3、选择已存在工作空间https://pic3.zhimg.com/80/v2-6f1e490fc674a6ac399b4fb75ee74bba_720w.webp2.4、选择工程路径https://pic1.zhimg.com/80/v2-269d06c3d2708f4b3c4d70f5e1c0eddc_720w.webphttps://pic3.zhimg.com/80/v2-690eab0a31da5a4e8e3907a852180152_720w.webp三、编译工程3.1、选择工程-右击clean Projecthttps://pic1.zhimg.com/80/v2-c1e3b3da7ca19ea7c048be071a6ecec8_720w.webp3.2、选择set active project 激活工程https://pic4.zhimg.com/80/v2-5b367ec974f9e6ac014c643ad744ce73_720w.webp3.3、右击--Build Projecthttps://pic4.zhimg.com/80/v2-44265cd27542c26b3c23d3e7d3ddfcbb_720w.webp3.4、完成编译https://pic3.zhimg.com/80/v2-7006a02dc0eeac9a48992341c07eb1de_720w.webp四、将程序烧入MCU4.1、使用DAP Miniwiggler连接MCU,如下图:https://pic1.zhimg.com/80/v2-7d08162a489659a8f2c103f2bc536820_720w.webp4.2、打开设备管理器,看是否自动识别并安装驱动,如下图成功识别;https://pic3.zhimg.com/80/v2-b2ef60dd2e55177d7d1f7a149a582616_720w.webp4.3、如果出现在其它设备,且带⚠号,得手动安装驱动;https://pic4.zhimg.com/80/v2-38ee6897e9eb91a4d6347e05598a0e97_720w.webp4.4、手动更新驱动https://pic4.zhimg.com/80/v2-ecc54437ef36d2818256f17183ea01c7_720w.webp4.5、在program files \DAS目录下https://pic1.zhimg.com/80/v2-66953f3bcf34c299677028a3acedb158_720w.webp4.6、编译并下载程序https://pic3.zhimg.com/80/v2-bd584722df64aaec5cd87d472ec22e26_720w.webp转自 https://zhuanlan.zhihu.com/p/605186543
wahe2008 发表于 2024-3-29 14:45
666
wahe2008 发表于 2024-3-29 14:46
TC375应该也是用的这个环境
小夏天的大西瓜 发表于 2024-4-22 22:08
AURIX-studio适配哪些MCU呢?
中国龙芯CDX 发表于 2024-4-23 14:54
下载学习一下飞凌的MCU教学
suncat0504 发表于 2024-4-30 16:47
楼主用的是啥下载器?多少钱?指专用于英飞凌单片机的吗?
问天少年 发表于 2024-4-30 17:24
挺详细的,很不错
页: [1]
查看完整版本: AURIX-studio安装流程
