rosemoore 发表于 2023-11-18 23:30
IIC协议通信解析
// 该代码用于测试没问题
#define I2C_SCL_PORTGPIOB
#define I2C_SCL_Pin   GPIO_Pin_8
#define I2C_SDA_PORTGPIOB
#define I2C_SDA_Pin   GPIO_Pin_9
#define OUTPUT 0
#define INPUT 1
static void I2C_Tail(void); //发送结束标志
static void I2C_Head(unsigned short Addrs); // 发送起始标志
static void hal_I2C_Config(void); // 模拟I2C配置函数
static void hal_I2C_SCL_SET(unsigned char i);// 设置时钟引脚
static void hal_I2C_SDA_SET(unsigned char i);// 设置数据引脚
static void hal_I2C_Start(void);// 起始标志
static void hal_I2C_Stop(void);   // 结束标志
static void I2C_Delay(unsigned short t);
static void I2C_ACK(void);   // 有ACK应答
static void I2C_NOACK(void); // 无ACK应答
static void I2C_SendByte(unsigned char data);   // 写一个byte数据时序
static void I2C_WriteByte(unsigned short Addr, unsigned char data); // 发送一个byte
static unsigned char I2C_RecvByte(void); // 读一个字节时序
static unsigned char I2C_WaitAck(void);// 返回0,无应答数据 。返回1,有应答数据
void hal_I2C_SDA_IO_SET(unsigned char IOMode); // OUTPUT 或者 INPUT
unsigned char hal_IC_SDA_INPUT(void);
unsigned char I2C_ReadByte(unsigned short Addr); // 读一个字节数据
void hal_eeprom_Init(void)
hal_I2C_Config();
unsigned char dat;
        hal_I2C_Start();
        I2C_SendByte(0xA0);
        I2C_WaitAck();
        I2C_SendByte((Addr>>8)&0xFF);
        I2C_WaitAck();
        I2C_SendByte(Addr&0xFF);
        I2C_WaitAck();
        hal_I2C_Start();
        I2C_SendByte(0xA1); // 发送 1010 0001 最低位的1代表从该芯片读取数据
        I2C_WaitAck();
        dat = I2C_RecvByte();
        I2C_NOACK();
        hal_I2C_Stop();
        return dat;
   unsigned char i = 0;
       unsigned char RecvByte = 0;
   hal_I2C_SCL_SET(0);
       I2C_Delay(1);
       hal_I2C_SDA_SET(1);
       hal_I2C_SDA_IO_SET(INPUT);
       for(; i < 8; i++)
           RecvByte<<=1;
                  I2C_Delay(1);
                  hal_I2C_SCL_SET(1);
                  I2C_Delay(1);
                  if(hal_IC_SDA_INPUT()) {
                          RecvByte |= 0x01;
                        hal_I2C_SCL_SET(0);
        hal_I2C_SDA_IO_SET(OUTPUT);
        I2C_Delay(1);
        return RecvByte;
void hal_I2C_Read( unsigned short Addrs, unsigned char *pBuf, unsigned short Len)
unsigned short i = 0;
        I2C_Head(Addrs);
        hal_I2C_Start();
        I2C_WaitAck();
        for( i = 0; i < Len; i++)
          pBuf = I2C_RecvByte();
                if(i == Len - 1) I2C_NOACK();
                else I2C_ACK();
        hal_I2C_Stop();
hal_I2C_Start(); // 发送有效数据起始标志
        // 该芯片最低位的一个bit位代表读/写:0 代表写入数据 || 1 代表读出数据
        I2C_SendByte(0xA0); // 发送需要通信的硬件地址(对应的硬件手册上有!!!!!)
        I2C_WaitAck();
        I2C_SendByte((Addr>>8)&0xFF); // 发送写入的地址(高字节地址)
        I2C_WaitAck();
        I2C_SendByte(Addr&0xFF);    // 发送写入的地址(低字节地址)
        I2C_WaitAck();
        I2C_SendByte(data);
        I2C_WaitAck();
        hal_I2C_Stop();// 发送有效数据结束标志
        I2C_Delay(20000);
hal_I2C_SDA_SET(1);
        hal_I2C_SDA_IO_SET(INPUT);// 设置SDA引脚为输入引脚
        hal_I2C_SCL_SET(1);
        I2C_Delay(1);
        if(hal_IC_SDA_INPUT()) { // 该引脚为高电平,代表无应答
                hal_I2C_SDA_IO_SET(OUTPUT);// 设置SDA引脚为输出引脚
          return 0;
        hal_I2C_SCL_SET(0);
        I2C_Delay(1);
        return 1;
          I2C_WaitAck();
          I2C_SendByte((Addrs>>8)&0xFF); // 发送写入的地址(高字节地址)
          I2C_WaitAck();
          I2C_SendByte(Addrs&0xFF);    // 发送写入的地址(低字节地址)
          I2C_WaitAck();
        I2C_Delay(20000);
void hal_I2C_Write(unsigned short Addrs, unsigned char* pBuf, unsigned short Len)
        unsigned short tmp = 0;
        unsigned short i = 0, j = 0;
        unsigned short page = 0;
        unsigned short size;
        if(Addrs%EEPROM_PAGE_SIZE)
          tmp = EEPROM_PAGE_SIZE-(Addrs%EEPROM_PAGE_SIZE); // 拿到当前页还有多少字节可写入
                if(tmp > Len)
             tmp = Len;        // 后续写入操作,需要tmp来做循环因子
        // 先将数据写入当前页
        if(tmp)
                I2C_Head(Addrs);
                // 正式写入数据
                for(i = 0; i < tmp; i++)
                  I2C_SendByte(pBuf);
                        I2C_WaitAck();
                I2C_Tail();
        Len -= tmp;   // 将已经发送过的数据个数减掉
        Addrs += tmp; // 将写入的地址更新
        page = Len/EEPROM_PAGE_SIZE; // int整形除法,只会得到整数
        size = Len%EEPROM_PAGE_SIZE; // 不足一页还有几个字节
        for(i = 0; i < page; i++)
          I2C_Head(Addrs);
                for(j = 0; j < EEPROM_PAGE_SIZE; j++)
                  I2C_SendByte(pBuf);
                        I2C_WaitAck();
                I2C_Tail();
                Addrs += EEPROM_PAGE_SIZE;
                tmp += EEPROM_PAGE_SIZE;
        if(size)
          I2C_Head(Addrs);
                for(i = 0; i < size; i++)
                  I2C_SendByte(pBuf);
                        I2C_WaitAck();
                I2C_Tail();
        for(; i < 8; i++)
                hal_I2C_SCL_SET(0);
                I2C_Delay(1);
          if(data&0x80){
                  hal_I2C_SDA_SET(1);
                } else {
                  hal_I2C_SDA_SET(0);
                I2C_Delay(1);
                hal_I2C_SCL_SET(1);
                I2C_Delay(1);
                data<<=1;
        hal_I2C_SCL_SET(0);
I2C_Delay(1);
        hal_I2C_SDA_SET(1);
I2C_Delay(1);
   hal_I2C_SCL_SET(0);
       I2C_Delay(1);
       hal_I2C_SDA_SET(0); // SDA数据线置低,进行数据位应答。
       I2C_Delay(1);
       hal_I2C_SCL_SET(1);
       I2C_Delay(1);
       hal_I2C_SCL_SET(0);
       I2C_Delay(1);
   hal_I2C_SCL_SET(0);
       I2C_Delay(1);
       hal_I2C_SDA_SET(1); // SDA数据线置高,不进行数据应答。
       I2C_Delay(1);
       hal_I2C_SCL_SET(1);
       I2C_Delay(1);
       hal_I2C_SCL_SET(0);
       I2C_Delay(1);
hal_I2C_SDA_SET(1);
        I2C_Delay(1);
        hal_I2C_SCL_SET(1);
        I2C_Delay(1);
        hal_I2C_SDA_SET(0);
        I2C_Delay(1);
hal_I2C_SDA_SET(0);
        I2C_Delay(1);
        hal_I2C_SCL_SET(1);
        I2C_Delay(1);
        hal_I2C_SDA_SET(1);
        I2C_Delay(1);
   GPIO_InitTypeDef GPIO_Struct;
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
       GPIO_Struct.GPIO_Mode = GPIO_Mode_Out_OD;
       GPIO_Struct.GPIO_Speed = GPIO_Speed_50MHz;
       GPIO_Struct.GPIO_Pin = I2C_SCL_Pin | I2C_SDA_Pin;
       GPIO_Init(GPIOB, &GPIO_Struct);
       hal_I2C_SDA_SET(1);
       hal_I2C_SCL_SET(1);
if(0 == IOMode) {
       GPIO_Struct.GPIO_Pin =I2C_SDA_Pin;
        if(1 == IOMode) {
       GPIO_Struct.GPIO_Mode = GPIO_Mode_IPU;
if(i) {
           GPIO_SetBits(I2C_SDA_PORT,I2C_SDA_Pin);
       } else {
           GPIO_ResetBits(I2C_SDA_PORT,I2C_SDA_Pin);
   if(i) {
           GPIO_SetBits(I2C_SCL_PORT,I2C_SCL_Pin);
       } else {
           GPIO_ResetBits(I2C_SCL_PORT,I2C_SCL_Pin);
unsigned short i=50,j,c;
   c = t;
   for(j=0; j<c; j++)
           while(i)
                                i--;
return GPIO_ReadInputDataBit(I2C_SDA_PORT, I2C_SDA_Pin);
单片小菜 发表于 2023-11-24 17:16
我还是认为软件的I2C更香,至少通用性更强一些。
页: [1]
查看完整版本: IIC协议通信解析
