基于 华大 HC32F460 芯片的 串口封装
接触嵌入式短短1年,也不知道封装的合理性如何,实际性能如何,就是自己写的爽,我就这么干了~~~直接上代码~#define Print(type,fmt,...){m_PrintfDevice = usart.usart_ch;printf(fmt,##__VA_ARGS__);};typedef enum usart_type
uart1= 0u, uart2, uart3, uart4
} usart_t;
typedef struct Usart_Struct{
M4_USART_TypeDef * usart_ch; // 串口通道
en_port_t Rx_Port; // Rx串口Port
en_pin_t Rx_Pin; // Tx串口Pin
en_port_t Tx_Port;
en_pin_t Tx_Pin;
uint32_t BAUDRATE;
en_port_func_t USART_RX_FUNC;
en_port_func_t USART_TX_FUNC;
en_int_src_t INT_USART_RI;
en_int_src_t INT_USART_EI;
en_int_src_t INT_USART_TI;
en_int_src_t INT_USART_TCI;
enum IRQn Rx_IRQn;
enum IRQn Tx_IRQn;
en_usart_parity_t usart_type;
en_usart_clk_div_t clk;
uint16_t u16UsedSize;
uint16_t au8Buf;
}Usart;
void usart_common_call(void);
void usart_common_err_call(void);
static void RingBufWriteNew(Usart *usart, uint8_t u8Data,usart_t type);
void all_usart_init(void);
void new_usart_init(Usart *u);
void resetBuf(Usart *u);
配置4路串口
Usart usart = {
M4_USART3, // group 2
PortE,Pin13,PortE,Pin14,
115200ul,
Func_Usart3_Rx,Func_Usart3_Tx,
INT_USART3_RI,INT_USART3_EI,INT_USART3_TI,INT_USART3_TCI,
Int001_IRQn,Int003_IRQn,
UsartParityNone,
UsartClkDiv_1,0
} 初始化各路串口
void all_usart_init () {
PORT_DebugPortSetting(TDI,Disable);
int len = sizeof(usart) / sizeof(usart);
for ( int i = 0 ; i < len ; i++) {
new_usart_init(&usart);
void new_usart_init(Usart *u){
stc_irq_regi_conf_t stcIrqRegiCfg;
const stc_usart_uart_init_t stcInitCfg = {
UsartIntClkCkNoOutput,
u->clk,
UsartDataBits8,
UsartDataLsbFirst,
UsartOneStopBit,
u->usart_type,
UsartSampleBit8,
UsartStartBitFallEdge,
UsartRtsEnable,
PORT_SetFunc(u->Rx_Port, u->Rx_Pin, u->USART_RX_FUNC, Disable);
PORT_SetFunc(u->Tx_Port, u->Tx_Pin, u->USART_TX_FUNC, Disable);
USART_UART_Init(u->usart_ch, &stcInitCfg);
USART_SetBaudrate(u->usart_ch, u->BAUDRATE);
stcIrqRegiCfg.enIRQn = u->Rx_IRQn;
stcIrqRegiCfg.pfnCallback = usart_common_call;
stcIrqRegiCfg.enIntSrc = u->INT_USART_RI ;
enIrqRegistration(&stcIrqRegiCfg);
NVIC_SetPriority(stcIrqRegiCfg.enIRQn, DDL_IRQ_PRIORITY_DEFAULT);
NVIC_ClearPendingIRQ(stcIrqRegiCfg.enIRQn);
NVIC_EnableIRQ(stcIrqRegiCfg.enIRQn);
stcIrqRegiCfg.enIRQn =u->Tx_IRQn;
stcIrqRegiCfg.pfnCallback = usart_common_err_call;
stcIrqRegiCfg.enIntSrc = u->INT_USART_EI;
USART_FuncCmd(u->usart_ch, UsartRx, Enable);
USART_FuncCmd(u->usart_ch, UsartRxInt, Enable);
USART_FuncCmd(u->usart_ch, UsartTx, Enable);
} 处理4路串口的接收中断,异常处理中断
void usart_common_call(void){
for ( usart_t i = u_4g ; i <= u_dw ; i++) {
if (Set == USART_GetStatus(usart.usart_ch,UsartRxNoEmpty)){
uint8_t u8Data = USART_RecData(usart.usart_ch);
(void)RingBufWriteNew(&usart, u8Data,i);
void usart_common_err_call(void){
en_usart_status_t errFlag = {UsartFrameErr,UsartParityErr,UsartOverrunErr};
for (int i = 0 ; i < 3 ; i++) {
for ( usart_t j = u_4g ; j <= u_dw ; j++ ) {
if (Set == USART_GetStatus(usart.usart_ch, errFlag))
USART_ClearStatus(usart.usart_ch, errFlag);
if (usart->u16UsedSize > 150) { // 这里的长度没有配置
resetBuf(usart);
usart->au8Buf = u8Data;
if ( type == uart1 ) {
//自行判断是否完整接收 校验 ...
if ( type == uart2 ) {
if ( type == uart3 ) {
if ( type == uart4 ) {
} 最后~各路串口的打印调试
Print(uart1,"%s\r\n" , "Hello World!"); 建议:确保m_PrintfDevice被正确使用并初始化。宏定义本身是简洁的,但如果printf在实际使用中不稳定或无法打印所有类型的格式化输出,可以考虑使用更安全的日志记录方法。 说实话,有点臃肿。
页:
[1]
