gaoyang9992006 发表于 2024-2-4 12:29
如何正确使用MCC生成的I2C库函数执行读取内存操作
关于MCC生成的PIC18F系列的I2C库函数的写操作的应用可以查看下面的帖子
https://bbs.21ic.com/icview-3353486-1-1.html
关于IO模拟I2C的操作可以查看下面的帖子
https://bbs.21ic.com/icview-3343744-1-1.html
本帖讲解如何使用MCC生成的I2C库函数执行读内存操作。
MCC的使用方法和I2C的启用方法这里不再赘述。
这里我们使用函数
* @ingroup i2c_host
* @brief This function writes data from the writeData to the bus
*      and then reads data from the Client and stores the received in the
*      readData. The function generates a Start condition on the bus and
*      will then send writeLength number of bytes contained in writeData.
*      The function will then insert a Repeated start condition and
*      proceed to read readLength number of bytes from the client.
*      The received bytes are stored in readData buffer. A Stop condition
*      is generated after the last byte has been received.
*      If the Client NAKs the request or a bus error was encountered on
*      the bus, the transfer is terminated. The application can call
*      I2C1_ErrorGet() function to know that cause of the error.
*      The function is non-blocking. It initiates bus activity and returns
*      immediately. The transfer is then completed in the peripheral
*      interrupt. For polling mode, user has to callI2C1_Tasks
*      in while loop. A transfer request cannot be placed when another
*      transfer is in progress. Calling this function when another function
*      is already in progress will cause the function to return false.
* @param address   - 7-bit / 10-bit Client address.
* @param writeData   - pointer to write data buffer.
* @param writeLength - write data length in bytes.
* @param readData    - pointer to read data buffer.
* @param readLength- read data length in bytes.
* @return
*         true- The request was placed successfully and the bus activity was
*               initiated.
*         false - The request fails,if there was already a transfer in
*               progress when this function was called
bool I2C1_WriteRead(uint16_t address, uint8_t *writeData, size_t writeLength, uint8_t *readData, size_t readLength);该函数的执行过程是:往指定的地址的设备写入数据后,再从该地址的设备读取数据。
参数一共5个:芯片的I2C总线地址,要写入的数据,写入数据的长度,读取的数据,读取的长度。
请注意写入的数据和读取的数据通过指针实现。
我们查看库函数实现的方式
    bool retStatus = false;
    if (!I2C1_IsBusy())
      i2c1Status.busy = true;
      i2c1Status.address = address;
      i2c1Status.switchToRead = true;
      i2c1Status.writePtr = writeData;
      i2c1Status.writeLength = writeLength;
      i2c1Status.readPtr = readData;
      i2c1Status.readLength = readLength;
      i2c1Status.errorState = I2C_ERROR_NONE;
      I2C1_WriteStart();
      retStatus = true;
    return retStatus;
}通过以上代码我们了解到,这是一个非阻塞函数,进入函数后判断是否忙,如果不忙就执行相关的寄存器配置与执行操作并返回真,这里函数并未考虑到如果为假的情况,另外为真的话也未考虑是否执行成功。所以我们需要自己在程序里考虑这个问题,否则将会执行失败,或者错过执行。接下来我找一个I2C的芯片来执行读操作。
芯片的时序定义如上所示,可以看出读操作是标准的I2C时序。
示例代码如下:
int main(void)
    uint8_t val=0;
    uint8_t reg=0x00;
    SYSTEM_Initialize();
    // If using interrupts in PIC18 High/Low Priority Mode you need to enable the Global High and Low Interrupts
    // If using interrupts in PIC Mid-Range Compatibility Mode you need to enable the Global Interrupts
    // Use the following macros to:
    // Enable the Global Interrupts
    INTERRUPT_GlobalInterruptEnable();
    // Disable the Global Interrupts
    //INTERRUPT_GlobalInterruptDisable();
printf("Hello\n");
DELAY_milliseconds(3000);
    while(1)
            DELAY_milliseconds(1000);
            I2C1_WriteRead(0x35,&reg,1,&val,1);
            while(I2C1_IsBusy());
            printf("REG%d=%x\n",reg,val);
            reg++;
            val=0;
            if(reg>30) reg=0;
}我们往I2C地址为0x35的设备写入reg,并将读取的数据放到val,之后通过检测是否忙,如果忙就等待,等到写入完成后再执行打印结果的操作。
这里使用了阻塞的方式判断,也可以使用非阻塞方式,增加一个时间判断,防止程序卡死。
简单的示例如下所示:
int main(void)
    uint8_t val=0;
    uint8_t reg=0x00;
    uint8_t delay_time=0;
printf("Hello\n");
    while(1)
            while(I2C1_IsBusy()&&(delay_time++<20));
            reg++;
            val=0;
            delay_time=0;
            if(reg>30) reg=0;
最后我们看看读取的效果
最后补充一个先写后读取的示例,并测试对应的寄存器哪些位可以进行写操作。
int main(void)
    uint8_t val=0;
    uint8_t reg=0x00;
    uint8_t daa;
    daa=0x04;
    daa=0x00;
printf("Hello\n");
    while(1)
      I2C1_Write(0x35,daa,2);
      while(I2C1_IsBusy()&&(delay_time++<20));delay_time=0;
      reg=0x04;
      I2C1_WriteRead(0x35,®,1,&val,1);
      printf("DAA[%x]---REG%d=%x\n",daa,reg,val);
      daa++;
经过测试在0x04寄存器上,低4位中的BIT3是不能执行写操作的。
正常使用时候这么看明显的不好看,我们可以将函数进行封装使用,不仅方便阅读,还更容易调用,同时这么做不容易弄错。void KT_Byte_Write(uint8_t kt_reg,uint8_t kt_dat)
    uint8_t dats;
    dats = kt_reg;
    dats = kt_dat;
    I2C1_Write(0x35,dats,2);
uint8_t KT_Byte_Read(uint8_t kt_reg)
    uint8_t val=0;
    I2C1_WriteRead(0x35,&kt_reg,1,&val,1);
    return val;
调用方式int main(void)
    uint8_t i=0;
printf("Hello\n");
    while(1)
      for(i=0;i<10;i++)
            KT_Byte_Write(0x04,i);
            printf("REG=%x\n",KT_Byte_Read(0x04));
好了,基于我使用的这个芯片的I2C读写使用方式讲解完了,另外只要是标准I2C协议的芯片都可以这么使用。
caigang13 发表于 2024-2-4 12:37
MCC还是差了点便捷性,还需继续优化。
MCC还是差了点便捷性,还需继续优化。
是的,我刚更新了帖子。
幸福小强 发表于 2024-2-4 17:48
掌握住诀窍了。
页: [1]
查看完整版本: 如何正确使用MCC生成的I2C库函数执行读取内存操作
