IFX_Lingling 发表于 2024-3-20 10:16
memtool batch mode
1: Please refer to the file memtol_batch_mode.pdf.
2: create a bat file like below screenshot. Please note that: rename your hex file as fw.hex, and place it in C disk. If not, you should change the command.
3:Place the file into the same directory like the IMTMemtool.exe.
4: Run the command line just like below screenshot.
LOVEEVER 发表于 2024-3-27 17:40
了解一下
jf101 发表于 2024-3-28 17:47
这个是在什么环境下运行的相关设置?
页: [1]
查看完整版本: memtool batch mode
