c语言几大基本算法
// 冒泡排序void bubbleSort(int arr[], int n) {
int i, j, temp;
for (i = 0; i < n - 1; i++)
for (j = 0; j < n - i - 1; j++)
if (arr > arr) {
temp = arr;
arr = arr;
arr = temp;
// 选择排序
void selectionSort(int arr[], int n) {
int i, j, min_idx;
for (i = 0; i < n - 1; i++) {
min_idx = i;
for (j = i + 1; j < n; j++)
if (arr < arr)
min_idx = j;
swap(&arr, &arr);
// 插入排序
void insertionSort(int arr[], int n) {
int i, j, key;
for (i = 1; i < n; i++) {
key = arr;
j = i - 1;
while (j >= 0 && arr > key) {
arr = arr;
j = j - 1;
arr = key;
// 快速排序
int partition (int arr[], int low, int high) {
int pivot = arr;
int i = (low - 1);
for (j = low; j <= high - 1; j++) {
if (arr < pivot) {
i++;
swap(&arr, &arr);
swap(&arr, &arr);
return (i + 1);
void quickSort(int arr[], int low, int high) {
if (low < high) {
int pi = partition(arr, low, high);
quickSort(arr, low, pi - 1);
quickSort(arr, pi + 1, high);
// 归并排序
void merge(int arr[], int l, int m, int r) {
int i, j, k;
int n1 = m - l + 1;
int n2 = r - m;
int L, R;
for (i = 0; i < n1; i++)
L = arr;
for (j = 0; j < n2; j++)
R = arr;
i = 0;
j = 0;
k = l;
while (i < n1 && j < n2) {
if (L <= R) {
arr = L;
i++;
else {
arr = R;
j++;
k++;
while (i < n1) {
arr = L;
i++;
k++;
while (j < n2) {
arr = R;
j++;
k++;
void mergeSort(int arr[], int l, int r) {
if (l < r) {
int m = l + (r - l) / 2;
mergeSort(arr, l, m);
这不就是C语言10大常用算法之一吗
页:
[1]
