【APM32F411V开发板测评】+SHT31温湿度传感器测试
SHT31温湿度传感器在SHT20的基础上提升了精度,缩小了体积。同时通信命令增加了一位。
在群里知道了这款板子是和ST芯片兼容的,ST的代码可以烧录进去,所以我也尝试用ST的HAL库进行这次的IIC实验。
在cubemx中进行配置,芯片选择一样,然后选择硬件IIC1。就配置这一点。
#define SHT30_ADDR_WRITE 0x44<<1 //10001000,根据用户手册的指示,这个就是SHT30的写入地址
#define SHT30_ADDR_READ (0x44<<1)+1 //10001011,根据用户手册的指示,这个就是SHT30的读取地址
extern I2C_HandleTypeDef hi2c1;//开启I2C1的接口,你用的哪个就改哪个
typedef enum //命令的定义
/* 软件复位命令 */
SOFT_RESET_CMD = 0x30A2,
单次测量模式
命名格式:Repeatability_CS_CMD
CS: Clock stretching
HIGH_ENABLED_CMD = 0x2C06,
MEDIUM_ENABLED_CMD= 0x2C0D,
LOW_ENABLED_CMD = 0x2C10,
HIGH_DISABLED_CMD = 0x2400,
MEDIUM_DISABLED_CMD = 0x240B,
LOW_DISABLED_CMD = 0x2416,
周期测量模式
命名格式:Repeatability_MPS_CMD
MPS:measurement per second
HIGH_0_5_CMD = 0x2032,
MEDIUM_0_5_CMD = 0x2024,
LOW_0_5_CMD = 0x202F,
HIGH_1_CMD = 0x2130,
MEDIUM_1_CMD = 0x2126,
LOW_1_CMD = 0x212D,
HIGH_2_CMD = 0x2236,
MEDIUM_2_CMD = 0x2220,
LOW_2_CMD = 0x222B,
HIGH_4_CMD = 0x2334,
MEDIUM_4_CMD = 0x2322,
LOW_4_CMD = 0x2329,
HIGH_10_CMD = 0x2737,
MEDIUM_10_CMD= 0x2721,
LOW_10_CMD = 0x272A,
/* 周期测量模式读取数据命令 */
READOUT_FOR_PERIODIC_MODE = 0xE000,
} SHT30_CMD;
* @brief 向SHT30发送一条指令(16bit)
* @param cmd —— SHT30指令(在SHT30_MODE中枚举定义)
* @retval 成功返回HAL_OK
static uint8_t SHT30_Send_Cmd(SHT30_CMD cmd)
uint8_t cmd_buffer;
cmd_buffer = cmd >> 8;
cmd_buffer = cmd;
return HAL_I2C_Master_Transmit(&hi2c1, SHT30_ADDR_WRITE, (uint8_t*)cmd_buffer, 2, 0xFFFF);
* @brief 复位SHT30
* @param none
* @retval none
void SHT30_Reset(void)
SHT30_Send_Cmd(SOFT_RESET_CMD);
HAL_Delay(20);
* @brief 初始化SHT30
* @param none
* @NOTE 周期测量模式
uint8_t SHT30_Init(void)
return SHT30_Send_Cmd(MEDIUM_2_CMD);
* @brief 从SHT30读取一次数据
* @param dat —— 存储读取数据的地址(6个字节数组)
* @retval 成功 —— 返回HAL_OK
uint8_t SHT30_Read_Dat(uint8_t* dat)
SHT30_Send_Cmd(READOUT_FOR_PERIODIC_MODE);
return HAL_I2C_Master_Receive(&hi2c1, SHT30_ADDR_READ, dat, 6, 0xFFFF);
* 本驱动最大的难点,CRC验证;没看懂,懂行的来讲讲
* 不管了会用就行
#define CRC8_POLYNOMIAL 0x31
uint8_t CheckCrc8(uint8_t* const message, uint8_t initial_value)
uint8_tremainder; //余数
uint8_ti = 0, j = 0;//循环变量
/* 初始化 */
remainder = initial_value;
for(j = 0; j < 2;j++)
remainder ^= message;
/* 从最高位开始依次计算*/
for (i = 0; i < 8; i++)
if (remainder & 0x80)
remainder = (remainder << 1)^CRC8_POLYNOMIAL;
else
remainder = (remainder << 1);
/* 返回计算的CRC码 */
return remainder;
* @brief 将SHT30接收的6个字节数据进行CRC校验,并转换为温度值和湿度值
* @param dat—— 存储接收数据的地址(6个字节数组)
* @retval 校验成功—— 返回0
* 校验失败—— 返回1,并设置温度值和湿度值为0
uint8_t SHT30_Dat_To_Float(uint8_t* const dat, float *temperature,float *humidity)
uint16_t recv_temperature = 0;
uint16_t recv_humidity = 0;
/* 校验温度数据和湿度数据是否接收正确 */
if(CheckCrc8(dat, 0xFF) != dat || CheckCrc8(&dat, 0xFF) != dat)
return 1;
/* 转换温度数据 */
recv_temperature = ((uint16_t)dat<<8)|dat;
*temperature = -45 + 175*((float)recv_temperature/65535);
/* 转换湿度数据 */
recv_humidity = ((uint16_t)dat<<8)|dat;
*humidity = 100 * ((float)recv_humidity / 65535);
return 0;
然后用HAL的硬件IIC发送函数,比较简单一条函数就搞定了。
void SHT30_Reset(void);
uint8_t SHT30_Init(void);
uint8_t SHT30_Read_Dat(uint8_t* dat);
uint8_t CheckCrc8(uint8_t* const message, uint8_t initial_value);
uint8_t SHT30_Dat_To_Float(uint8_t* const dat, float* temperature, float* humidity);
uint8_t dat={0};
float temperature ,humidity;
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_I2C1_Init();
/* USER CODE BEGIN 2 */
SHT30_Reset();
SHT30_Init();
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
SHT30_Read_Dat(dat);
SHT30_Dat_To_Float(dat,&temperature,&humidity);
/* USER CODE END 3 */
Main函数,这里先借鉴别人的代码,搞的复杂了。然后就是修改芯片,换成极海的。
然后烧录仿真,看结果。
是可以读到正确温度数值的。
用ST的代码可以直接在极海上进行适用?
页:
[1]
