lemonhub 发表于 2024-5-30 21:49
极海APM32F411V Tiny开发板评测 APM32F4xx_DAL_Driver工程模板建立
极海APM32F411V Tiny开发板评测08 APM32F4xx_DAL_Driver工程模板建立这几天在极海半导体官网逛的时候看到了APM32F4xx_DAL_SDK相关东西比较好奇,所以研究了研究。APM32F4xx_DAL_Driver是APM32F4系列的类似STM32-HAL抽象层的库,国产APM32芯片从标准固件库终于到HAL库了。1. 准备目标硬件(开发板/芯片/模组)本教程将极海APM32F411 Tiny开发板进行示例移植,其他 ARM Cortex M4系列开发板和芯片移植方法类似。调试ARM Cortex M核还需要仿真器,如果您的开发板或者芯片模组没有板载仿真器,就需要连接外置的仿真器,如J-Link、DAPLink之类的。2.准备编译器环境本移植指南针对的是Keil编译器,所以我们移植内核前需要先安装Keil编译器,能编译ARM Cortex M核的Keil编译器现在也叫MDK。下载地址为:https://www.keil.com/demo/eval/arm.htm3. APM32F4xx_DAL_Driver      APM32F4xx_DAL_Driver是极海APM32F4 DAL SDK的一部分,APM32F4xx_DAL_Driver与STM32_HAL_Driver类似,属于抽象层库,同系列的芯片,使用同一套API函数,应用层快速迭代,丰富的组件和驱动抽象层。APM32F4XXDALSDK内容组成:
[*]Application:例程和模板工程
[*]中间件:USB、RTOS、文件系统和网络协议栈
[*]IDE支持:Keil-MDK、IAR-EWARM、Eclipse-GCC等
[*]驱动和组件:DAL库、DDL库、CMSIScore设备文件、BSP和Component等
下载地址APM32F4 DAL SDK https://www.geehy.com/support/online_detail?id=75APM32F4 DAL SDK组成\
4. 工程创建
[*]文件结构工程以GPIO例程作为基础创建。1.Board
    Source/board_apm32f411_tiny.c
    Include/board_apm32f411_tiny.h
2.Libraries
    Libraries/APM32F4xx_DAL_Driver/Include
    Libraries/APM32F4xx_DAL_Driver/Source
    Libraries/CMSIS
    Libraries/Device
3.Middlewares
   FreeRTOS/RT-Thread/LwIP/Fat_Fs等
4.Project
    Project/MDK Project/IAR Project/GCC
    Source/main.c 等
    Include/main.h等
    Config/Source/apm32f4xx_device_cfg.c等
    Config/Include/apm32f4xx_device_cfg.h等
[*]添加文件
[*]Config配置文件(选择性配置)/**
* @file       apm32f4xx_dal_cfg.h
* @brief       DAL configuration file
* @version   V1.0.0
* @date       2023-12-01
* @attention
* Copyright (C) 2023 Geehy Semiconductor
* You may not use this file except in compliance with the
* GEEHY COPYRIGHT NOTICE (GEEHY SOFTWARE PACKAGE LICENSE).
* The program is only for reference, which is distributed in the hope
* that it will be useful and instructional for customers to develop
* their software. Unless required by applicable law or agreed to in
* writing, the program is distributed on an "AS IS" BASIS, WITHOUT
* ANY WARRANTY OR CONDITIONS OF ANY KIND, either express or implied.
* See the GEEHY SOFTWARE PACKAGE LICENSE for the governing permissions
* and limitations under the License.
/* Define to prevent recursive inclusion */
#ifndef APM32F4xx_DAL_CFG_H
#define APM32F4xx_DAL_CFG_H
#ifdef __cplusplus
extern "C" {
#endif
/* Configuration settings for log component */
#define USE_LOG_COMPONENT   1U
/* Include log header file */
#include "apm32f4xx_dal_log.h"
/* Configuration settings for assert enable */
/* #define USE_FULL_ASSERT   1U */
/* DAL module configuration */
#define DAL_MODULE_ENABLED
//#define DAL_ADC_MODULE_ENABLED
//#define DAL_CAN_MODULE_ENABLED
//#define DAL_CRC_MODULE_ENABLED
//#define DAL_COMP_MODULE_ENABLED
#define DAL_DMA_MODULE_ENABLED
#define DAL_FLASH_MODULE_ENABLED
//#define DAL_NAND_MODULE_ENABLED
//#define DAL_NOR_MODULE_ENABLED
//#define DAL_PCCARD_MODULE_ENABLED
//#define DAL_SRAM_MODULE_ENABLED
#define DAL_GPIO_MODULE_ENABLED
//#define DAL_EINT_MODULE_ENABLED
//#define DAL_I2C_MODULE_ENABLED
//#define DAL_SMBUS_MODULE_ENABLED
//#define DAL_I2S_MODULE_ENABLED
//#define DAL_IWDT_MODULE_ENABLED
#define DAL_PMU_MODULE_ENABLED
//#define DAL_QSPI_MODULE_ENABLED
#define DAL_RCM_MODULE_ENABLED
//#define DAL_RNG_MODULE_ENABLED
//#define DAL_RTC_MODULE_ENABLED
//#define DAL_SD_MODULE_ENABLED
//#define DAL_SPI_MODULE_ENABLED
//#define DAL_TMR_MODULE_ENABLED
#define DAL_UART_MODULE_ENABLED
#define DAL_USART_MODULE_ENABLED
//#define DAL_IRDA_MODULE_ENABLED
//#define DAL_SMARTCARD_MODULE_ENABLED
//#define DAL_WWDT_MODULE_ENABLED
#define DAL_CORTEX_MODULE_ENABLED
//#define DAL_PCD_MODULE_ENABLED
//#define DAL_HCD_MODULE_ENABLED
//#define DAL_MMC_MODULE_ENABLED
/* Value of the external high speed oscillator in Hz */
#if !defined (HSE_VALUE)
#define HSE_VALUE             8000000U
#endif /* HSE_VALUE */
/* Timeout for external high speed oscillator in ms */
#if !defined (HSE_STARTUP_TIMEOUT)
#define HSE_STARTUP_TIMEOUT   100U
#endif /* HSE_STARTUP_TIMEOUT */
/* Value of the internal high speed oscillator in Hz */
#if !defined (HSI_VALUE)
#define HSI_VALUE             16000000U
#endif /* HSI_VALUE */
/* Value of the internal low speed oscillator in Hz */
#if !defined (LSI_VALUE)
#define LSI_VALUE               32000U
#endif /* LSI_VALUE */
/* Value of the external low speed oscillator in Hz */
#if !defined (LSE_VALUE)
#define LSE_VALUE               32768U
#endif /* LSE_VALUE */
/* Timeout for external low speed oscillator in ms */
#if !defined (LSE_STARTUP_TIMEOUT)
#define LSE_STARTUP_TIMEOUT   5000U
#endif /* LSE_STARTUP_TIMEOUT */
/* Value of the external high speed oscillator in Hz for I2S peripheral */
#if !defined (EXTERNAL_CLOCK_VALUE)
#define EXTERNAL_CLOCK_VALUE   12288000U
#endif /* EXTERNAL_CLOCK_VALUE */
/* System Configuration */
#define VDD_VALUE                   3300U /*!< Value of VDD in mv */
#define TICK_INT_PRIORITY         0x0FU /*!< tick interrupt priority */
#define USE_RTOS                     0U
#define PREFETCH_ENABLE             1U
#define INSTRUCTION_CACHE_ENABLE   1U
#define DATA_CACHE_ENABLE         1U
/* DAL peripheral register callbacks */
#define USE_DAL_ADC_REGISTER_CALLBACKS         0U /* ADC register callback disabled       */
#define USE_DAL_CAN_REGISTER_CALLBACKS         0U /* CAN register callback disabled       */
#define USE_DAL_CRYP_REGISTER_CALLBACKS       0U /* CRYP register callback disabled   */
#define USE_DAL_DAC_REGISTER_CALLBACKS         0U /* DAC register callback disabled       */
#define USE_DAL_DCI_REGISTER_CALLBACKS         0U /* DCI register callback disabled       */
#define USE_DAL_ETH_REGISTER_CALLBACKS         0U /* ETH register callback disabled       */
#define USE_DAL_HASH_REGISTER_CALLBACKS       0U /* HASH register callback disabled   */
#define USE_DAL_HCD_REGISTER_CALLBACKS         0U /* HCD register callback disabled       */
#define USE_DAL_I2C_REGISTER_CALLBACKS         0U /* I2C register callback disabled       */
#define USE_DAL_I2S_REGISTER_CALLBACKS         0U /* I2S register callback disabled       */
#define USE_DAL_IRDA_REGISTER_CALLBACKS       0U /* IRDA register callback disabled   */
#define USE_DAL_MMC_REGISTER_CALLBACKS         0U /* MMC register callback disabled       */
#define USE_DAL_NAND_REGISTER_CALLBACKS       0U /* NAND register callback disabled   */
#define USE_DAL_NOR_REGISTER_CALLBACKS         0U /* NOR register callback disabled       */
#define USE_DAL_PCCARD_REGISTER_CALLBACKS   0U /* PCCARD register callback disabled   */
#define USE_DAL_PCD_REGISTER_CALLBACKS         0U /* PCD register callback disabled       */
#define USE_DAL_RNG_REGISTER_CALLBACKS         0U /* RNG register callback disabled       */
#define USE_DAL_RTC_REGISTER_CALLBACKS         0U /* RTC register callback disabled       */
#define USE_DAL_SD_REGISTER_CALLBACKS         0U /* SD register callback disabled       */
#define USE_DAL_SMARTCARD_REGISTER_CALLBACKS   0U /* SMARTCARD register callback disabled */
#define USE_DAL_SDRAM_REGISTER_CALLBACKS       0U /* SDRAM register callback disabled   */
#define USE_DAL_SRAM_REGISTER_CALLBACKS       0U /* SRAM register callback disabled   */
#define USE_DAL_SMBUS_REGISTER_CALLBACKS       0U /* SMBUS register callback disabled   */
#define USE_DAL_SPI_REGISTER_CALLBACKS         0U /* SPI register callback disabled       */
#define USE_DAL_TMR_REGISTER_CALLBACKS         0U /* TMR register callback disabled       */
#define USE_DAL_UART_REGISTER_CALLBACKS       0U /* UART register callback disabled   */
#define USE_DAL_USART_REGISTER_CALLBACKS       0U /* USART register callback disabled   */
#define USE_DAL_WWDT_REGISTER_CALLBACKS       0U /* WWDT register callback disabled   */
/* Ethernet peripheral configuration */
/* Addr and buffer size */
/* MAC ADDRESS */
#define ETH_MAC_ADDR_0   2U
#define ETH_MAC_ADDR_1   0U
#define ETH_MAC_ADDR_2   0U
#define ETH_MAC_ADDR_3   0U
#define ETH_MAC_ADDR_4   0U
#define ETH_MAC_ADDR_5   0U
/* Ethernet driver buffers size and number */
#define ETH_BUFFER_SIZE_RX             ETH_MAX_PACKET_SIZE /* Buffer size for receive               */
#define ETH_BUFFER_SIZE_TX             ETH_MAX_PACKET_SIZE /* Buffer size for transmit             */
#define ETH_BUFFER_NUMBER_RX         4U                  /* 4 Rx buffers of size ETH_BUFFER_SIZE_RX */
#define ETH_BUFFER_NUMBER_TX         4U                  /* 4 Tx buffers of size ETH_BUFFER_SIZE_TX */
/* Delay and timeout */
/* PHY Reset MAX Delay */
#define EXT_PHY_RESET_MAX_DELAY         0x000000FFU
/* PHY Configuration MAX Delay */
#define EXT_PHY_CONFIG_MAX_DELAY       0x00000FFFU
#define EXT_PHY_READ_TIMEOUT         0x0000FFFFU
#define EXT_PHY_WRITE_TIMEOUT         0x0000FFFFU
/* SPI peripheral configuration */
/* SPI CRC FEATURE */
#define USE_SPI_CRC                     1U
/* Include module's header file */
#ifdef DAL_RCM_MODULE_ENABLED
#include "apm32f4xx_dal_rcm.h"
#endif /* DAL_RCM_MODULE_ENABLED */
#ifdef DAL_GPIO_MODULE_ENABLED
#include "apm32f4xx_dal_gpio.h"
#endif /* DAL_GPIO_MODULE_ENABLED */
#ifdef DAL_EINT_MODULE_ENABLED
#include "apm32f4xx_dal_eint.h"
#endif /* DAL_EINT_MODULE_ENABLED */
#ifdef DAL_DMA_MODULE_ENABLED
#include "apm32f4xx_dal_dma.h"
#endif /* DAL_DMA_MODULE_ENABLED */
#ifdef DAL_CORTEX_MODULE_ENABLED
#include "apm32f4xx_dal_cortex.h"
#endif /* DAL_CORTEX_MODULE_ENABLED */
#ifdef DAL_ADC_MODULE_ENABLED
#include "apm32f4xx_dal_adc.h"
#endif /* DAL_ADC_MODULE_ENABLED */
#ifdef DAL_CAN_MODULE_ENABLED
#include "apm32f4xx_dal_can.h"
#endif /* DAL_CAN_MODULE_ENABLED */
#ifdef DAL_CRC_MODULE_ENABLED
#include "apm32f4xx_dal_crc.h"
#endif /* DAL_CRC_MODULE_ENABLED */
#ifdef DAL_CRYP_MODULE_ENABLED
#include "apm32f4xx_dal_cryp.h"
#endif /* DAL_CRYP_MODULE_ENABLED */
#ifdef DAL_DAC_MODULE_ENABLED
#include "apm32f4xx_dal_dac.h"
#endif /* DAL_DAC_MODULE_ENABLED */
#ifdef DAL_DCI_MODULE_ENABLED
#include "apm32f4xx_dal_dci.h"
#endif /* DAL_DCI_MODULE_ENABLED */
#ifdef DAL_ETH_MODULE_ENABLED
#include "apm32f4xx_dal_eth.h"
#endif /* DAL_ETH_MODULE_ENABLED */
#ifdef DAL_FLASH_MODULE_ENABLED
#include "apm32f4xx_dal_flash.h"
#endif /* DAL_FLASH_MODULE_ENABLED */
#ifdef DAL_HASH_MODULE_ENABLED
#include "apm32f4xx_dal_hash.h"
#endif /* DAL_HASH_MODULE_ENABLED */
#ifdef DAL_HCD_MODULE_ENABLED
#include "apm32f4xx_dal_hcd.h"
#endif /* DAL_HCD_MODULE_ENABLED */
#ifdef DAL_I2C_MODULE_ENABLED
#include "apm32f4xx_dal_i2c.h"
#endif /* DAL_I2C_MODULE_ENABLED */
#ifdef DAL_I2S_MODULE_ENABLED
#include "apm32f4xx_dal_i2s.h"
#endif /* DAL_I2S_MODULE_ENABLED */
#ifdef DAL_IRDA_MODULE_ENABLED
#include "apm32f4xx_dal_irda.h"
#endif /* DAL_IRDA_MODULE_ENABLED */
#ifdef DAL_MMC_MODULE_ENABLED
#include "apm32f4xx_dal_mmc.h"
#endif /* DAL_MMC_MODULE_ENABLED */
#ifdef DAL_NAND_MODULE_ENABLED
#include "apm32f4xx_dal_nand.h"
#endif /* DAL_NAND_MODULE_ENABLED */
#ifdef DAL_NOR_MODULE_ENABLED
#include "apm32f4xx_dal_nor.h"
#endif /* DAL_NOR_MODULE_ENABLED */
#ifdef DAL_PCCARD_MODULE_ENABLED
#include "apm32f4xx_dal_pccard.h"
#endif /* DAL_PCCARD_MODULE_ENABLED */
#ifdef DAL_PCD_MODULE_ENABLED
#include "apm32f4xx_dal_pcd.h"
#endif /* DAL_PCD_MODULE_ENABLED */
#ifdef DAL_PMU_MODULE_ENABLED
#include "apm32f4xx_dal_pmu.h"
#endif /* DAL_PMU_MODULE_ENABLED */
#ifdef DAL_RNG_MODULE_ENABLED
#include "apm32f4xx_dal_rng.h"
#endif /* DAL_RNG_MODULE_ENABLED */
#ifdef DAL_RTC_MODULE_ENABLED
#include "apm32f4xx_dal_rtc.h"
#endif /* DAL_RTC_MODULE_ENABLED */
#ifdef DAL_SRAM_MODULE_ENABLED
#include "apm32f4xx_dal_sram.h"
#endif /* DAL_SRAM_MODULE_ENABLED */
#ifdef DAL_SDRAM_MODULE_ENABLED
#include "apm32f4xx_dal_sdram.h"
#endif /* DAL_SDRAM_MODULE_ENABLED */
#ifdef DAL_SMBUS_MODULE_ENABLED
#include "apm32f4xx_dal_smbus.h"
#endif /* DAL_SMBUS_MODULE_ENABLED */
#ifdef DAL_SD_MODULE_ENABLED
#include "apm32f4xx_dal_sd.h"
#endif /* DAL_SD_MODULE_ENABLED */
#ifdef DAL_SPI_MODULE_ENABLED
#include "apm32f4xx_dal_spi.h"
#endif /* DAL_SPI_MODULE_ENABLED */
#ifdef DAL_SMARTCARD_MODULE_ENABLED
#include "apm32f4xx_dal_smartcard.h"
#endif /* DAL_SMARTCARD_MODULE_ENABLED */
#ifdef DAL_TMR_MODULE_ENABLED
#include "apm32f4xx_dal_tmr.h"
#endif /* DAL_TMR_MODULE_ENABLED */
#ifdef DAL_UART_MODULE_ENABLED
#include "apm32f4xx_dal_uart.h"
#endif /* DAL_UART_MODULE_ENABLED */
#ifdef DAL_USART_MODULE_ENABLED
#include "apm32f4xx_dal_usart.h"
#endif /* DAL_USART_MODULE_ENABLED */
#ifdef DAL_IWDT_MODULE_ENABLED
#include "apm32f4xx_dal_iwdt.h"
#endif /* DAL_IWDT_MODULE_ENABLED */
#ifdef DAL_WWDT_MODULE_ENABLED
#include "apm32f4xx_dal_wwdt.h"
#endif /* DAL_WWDT_MODULE_ENABLED */
/* Assert Component */
#if (USE_FULL_ASSERT == 1U)
   #define ASSERT_PARAM(_PARAM_)                         ((_PARAM_) ? (void)0U : AssertFailedHandler((uint8_t *)__FILE__, __LINE__))
   /* Declaration */
   void AssertFailedHandler(uint8_t *file, uint32_t line);
#else
   #define ASSERT_PARAM(_PARAM_)                         ((void)0U)
#endif /* USE_FULL_ASSERT */
void DAL_ErrorHandler(void);
#ifdef __cplusplus
#endif
#endif /* APM32F4xx_DAL_CFG_H */
上面的配置过程中,由于后面我们要开启log功能,我们需要打开 USE_LOG_COMPONENT和 DAL_UART_MODULE_ENABLED/* Configuration settings for log component */
[*]添加串口驱动由于在GPIO端口工程中,没有配置UART,因此需要进行配置添加apm32f4xx_usart_cfg.c apm32f4xx_usart_cfg.h 对串口进行端口,波特率等配置/* Includes ***************************************************************/
#include "apm32f4xx_usart_cfg.h"
/* Private includes *******************************************************/
#include <stdio.h>
/* Private macro **********************************************************/
/* Private typedef ********************************************************/
/* Private variables ******************************************************/
UART_HandleTypeDef huart1;
/* Private function prototypes ********************************************/
/* External variables *****************************************************/
/* External functions *****************************************************/
* @brief   USART1 configuration
* @param   None
* @retval None
void DAL_USART1_Config(void)
   huart1.Instance             = USART1;
   huart1.Init.BaudRate      = 115200U;
   huart1.Init.WordLength      = UART_WORDLENGTH_8B;
   huart1.Init.StopBits      = UART_STOPBITS_1;
   huart1.Init.Parity          = UART_PARITY_NONE;
   huart1.Init.Mode            = UART_MODE_TX_RX;
   huart1.Init.HwFlowCtl       = UART_HWCONTROL_NONE;
   huart1.Init.OverSampling    = UART_OVERSAMPLING_16;
   if (DAL_UART_Init(&huart1) != DAL_OK)
       DAL_ErrorHandler();
* @brief   UART MSP Init
* @param   huart Pointer to a UART_HandleTypeDef structure that contains
*               the configuration information for the specified UART module
* @retval None
void DAL_UART_MspInit(UART_HandleTypeDef *huart)
   GPIO_InitTypeDef GPIO_InitStruct = {0};
   if (huart->Instance == USART1)
       /* Enable USART1 GPIO clock */
       __DAL_RCM_GPIOA_CLK_ENABLE();
       /* Enable USART1 clock */
       __DAL_RCM_USART1_CLK_ENABLE();
       /* Configure the UART TX and RX pin */
       GPIO_InitStruct.Pin         = GPIO_PIN_9 | GPIO_PIN_10;
       GPIO_InitStruct.Mode      = GPIO_MODE_AF_PP;
       GPIO_InitStruct.Pull      = GPIO_NOPULL;
       GPIO_InitStruct.Speed       = GPIO_SPEED_FAST;
       GPIO_InitStruct.Alternate   = GPIO_AF7_USART1;
       DAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
* @brief UART MSP DeInit
* @retval None
void DAL_UART_MspDeInit(UART_HandleTypeDef *huart)
       /* Reset USART */
       __DAL_RCM_USART1_FORCE_RESET();
       __DAL_RCM_USART1_RELEASE_RESET();
       /* Disable USART and GPIO clocks */
       DAL_GPIO_DeInit(GPIOA, GPIO_PIN_9 | GPIO_PIN_10);
       /* Disable USART interrupt */
       DAL_NVIC_DisableIRQ(USART1_IRQn);
#if defined (__CC_ARM) || defined (__ICCARM__) || (defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050))
* @brief       Redirect C Library function printf to serial port.
*             After Redirection, you can use printf function.
* @param       ch: The characters that need to be send.
* @param       *f: pointer to a FILE that can recording all information
*             needed to control a stream
* @retval   The characters that need to be send.
* @note
int fputc(int ch, FILE* f)
   /* send a byte of data to the serial port */
   DAL_UART_Transmit(&huart1, (uint8_t *)&ch, 1U, 1000U);
   return (ch);
#elif defined (__GNUC__)
* @note
int __io_putchar(int ch)
   return ch;
* @param       file: Meaningless in this function.
* @param       *ptr: Buffer pointer for data to be sent.
* @param       len: Length of data to be sent.
* @note
int _write(int file, char* ptr, int len)
   int i;
   for (i = 0; i < len; i++)
       __io_putchar(*ptr++);
   return len;
#else
#warning Not supported compiler type
#endif
[*]下载程序主程序代码/* Includes ***************************************************************/
#include "main.h"
#include "apm32f4xx_device_cfg.h"
static const char* tag = "main";//log组件
* @brief   Main program
int main(void)
    /* Device configuration */
    DAL_DeviceConfig();
          DAL_LOGE(tag, "Hardware_Init \r\n");
                DAL_LOGE(tag, "apm32f411tiny board testing 2024-05-30\n");
          DAL_LOGE(tag, "apm32f411tiny-board APM32F4xx_DAL_Driver\n");
    /* Infinite loop */
    while (1)
      DAL_GPIO_TogglePin(GPIOE, GPIO_PIN_6);
      DAL_Delay(500U);
                        DAL_LOGE(tag, "DAL_GPIO_TogglePin Testing\r\n");
采用APM32F411-Tiny Board自带的Geehy Link进行下载。成功点亮。
在apm32f4xx_device_cfg.c中开启log打印组件,调试调试
星辰大海不退缩 发表于 2024-6-22 21:08
LED灯确实很亮,有时不太好分辨
页: [1]
查看完整版本: 极海APM32F411V Tiny开发板评测 APM32F4xx_DAL_Driver工程模板建立
