tpgf 发表于 2024-6-27 09:07
国民技术与stm32 ADC采集
一、国民技术芯片ADC采集配置
PA1ADC1_IN2默认功能
DMA 通道1由ADC1触发
外部晶振16系统时钟144MAHB 2分频 HCLK=72M
HCLK经APB1 4分频 pclk1 = 18M=HCLK/4
HCLK经APB2 4分频 pclk2 = 18M=HCLK/4
ADCCLK不得超过14M
void DMA_ADC_Config(void)
          ADC_InitType ADC_InitStructure;
      DMA_InitType DMA_InitStructure;
          GPIO_InitType GPIO_InitStructure;
          /* Enable peripheral clocks ------------------------------------------------*/
          /* Enable DMA1 and DMA2 clocks */
          RCC_EnableAHBPeriphClk(RCC_AHB_PERIPH_DMA1 , ENABLE);
          /* Enable ADC1, ADC2, ADC3 and GPIOC clocks */
          // RCC_EnableAPB2PeriphClk(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 | RCC_APB2_PERIPH_GPIOC, ENABLE);
          /* Enable GPIOC clocks */        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
          /* Enable ADC1, ADC2, ADC3 and ADC4 clocks */
          RCC_EnableAHBPeriphClk(RCC_AHB_PERIPH_ADC1,ENABLE);
          /* RCC_ADCHCLK_DIV16 144/1672/8*/
          ADC_ConfigClk(ADC_CTRL3_CKMOD_AHB,RCC_ADCHCLK_DIV8);
   GPIO_InitStructure.Pin       = GPIO_PIN_1;
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
       GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
/* DMA1 channel1 configuration ----------------------------------------------*/
    DMA_DeInit(DMA1_CH1);
    DMA_InitStructure.PeriphAddr   = (uint32_t)&ADC1->DAT;
    DMA_InitStructure.MemAddr      = (uint32_t)&ADCConvertedValue;
    DMA_InitStructure.Direction      = DMA_DIR_PERIPH_SRC;
    DMA_InitStructure.BufSize      = 1;
    DMA_InitStructure.PeriphInc      = DMA_PERIPH_INC_DISABLE;
    DMA_InitStructure.DMA_MemoryInc= DMA_MEM_INC_DISABLE;
    DMA_InitStructure.PeriphDataSize = DMA_PERIPH_DATA_SIZE_HALFWORD;
    DMA_InitStructure.MemDataSize    = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.CircularMode   = DMA_MODE_CIRCULAR;
    DMA_InitStructure.Priority       = DMA_PRIORITY_HIGH;
    DMA_InitStructure.Mem2Mem      = DMA_M2M_DISABLE;
    DMA_Init(DMA1_CH1, &DMA_InitStructure);
    /* Enable DMA1 channel1 */
    DMA_EnableChannel(DMA1_CH1, ENABLE);
    /* ADC1 configuration ------------------------------------------------------*/
    ADC_InitStructure.WorkMode       = ADC_WORKMODE_INDEPENDENT;
    ADC_InitStructure.MultiChEn      = ENABLE;
    ADC_InitStructure.ContinueConvEn = ENABLE;
    ADC_InitStructure.ExtTrigSelect= ADC_EXT_TRIGCONV_NONE;
    ADC_InitStructure.DatAlign       = ADC_DAT_ALIGN_R;
    ADC_InitStructure.ChsNumber      = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
       //配置ADC时钟分频因子不超过14M    8分频得到
       //使用外部高速时钟
       // RCC_ConfigAdc1mClk(RCC_ADC1MCLK_SRC_HSE, RCC_ADC1MCLK_DIV2);
    /* ADC1 regular channel14 configuration */
    //ADC_ConfigRegularChannel(ADC1, ADC_CH_2, 1, ADC_SAMP_TIME_55CYCLES5);
                ADC_ConfigRegularChannel(ADC1, ADC1_Channel_02_PA1, 1, ADC_SAMP_TIME_55CYCLES5);
    /* Enable ADC1 DMA */
    ADC_EnableDMA(ADC1, ENABLE);
    /* Enable ADC1 */
    ADC_Enable(ADC1, ENABLE);
    /*Check ADC Ready*/
    while(ADC_GetFlagStatusNew(ADC1,ADC_FLAG_RDY) == RESET);
    /* Start ADC1 calibration */
    ADC_StartCalibration(ADC1);
    /* Check the end of ADC1 calibration */
    while (ADC_GetCalibrationStatus(ADC1));
    /* Start ADC1 Software Conversion */
    ADC_EnableSoftwareStartConv(ADC1, ENABLE);
二、stm32ADC采集
// ADC多通道采集
void ADC_IN_x_Config(void)
   ADC_InitTypeDef ADC_InitStructure;
          //使能ADC时钟
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
       //ADC结构体配置
       ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;   //独立模式   ADC1/2/3/4只使用了一个
       ADC_InitStructure.ADC_ScanConvMode = ENABLE;         //扫描模式
       ADC_InitStructure.ADC_ContinuousConvMode=ENABLE;   //连续转换(多次转换ENABLE)   一次转换(disable)
       ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;//禁止触发检测、使用软件触发ADC_ExternalTrigConv_None
       ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; //   右对齐
       ADC_InitStructure.ADC_NbrOfChannel=NOFCHANEL;                //2个转换在规则序列中
       ADC_Init(ADC1,&ADC_InitStructure);
       //配置ADC时钟分频因子不超过14M   APB2=72M   APB2 8分频得到
          RCC_ADCCLKConfig(RCC_PCLK2_Div8);
       // 配置ADC通道的转换顺序和采样时间 Tconv = 采样时间 +12.5 个周期   第三个参数为通道转换序列
   ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5); // 配置 ADC 通道转换顺序为 1,第一个转换,采样时间为 55.5 个时钟周期
       ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5); // 配置 ADC 通道转换顺序为 2,第二个转换,采样时间为 55.5 个时钟周期
   //ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);            // ADC 转换结束产生中断,在中断服务程序中读取转换值
       ADC_DMACmd(ADC1,ENABLE);                               // 使能ADC DMA请求
       //使能ADC并开始转换
       ADC_Cmd(ADC1,ENABLE);
       //初始化并校准寄存器
       ADC_ResetCalibration(ADC1);
       //等待校准寄存器初始化完成
       while(ADC_GetResetCalibrationStatus(ADC1));
       //ADC开始校准
       //等待校准完成
       while(ADC_GetCalibrationStatus(ADC1));
       //软件触发ADC转换,没有使用时外部触发
       ADC_SoftwareStartConvCmd(ADC1, ENABLE);
/*********************************************DMA配置*********************************************/
// 1、DMA_ChxDMA通道2、Dpba外设地址3、Dmba存储器地址4、DbseDMA通道的缓冲区大小
void DMA_Config(DMA_Channel_TypeDef* DMA_Chx,uint32_t Dpba,uint32_t Dmba,uint32_t Dbs)
        DMA_InitTypeDef DMA_InitStructure;
//使能时钟
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        //复位DMA控制器DMA 通道复位
        DMA_DeInit(DMA_Chx);
        //配置结构体
        DMA_InitStructure.DMA_PeripheralBaseAddr=Dpba;//ADC数据寄存器地址
        DMA_InitStructure.DMA_MemoryBaseAddr=Dmba;      //存储器地址目标地址
        DMA_InitStructure.DMA_DIR=DMA_DIR_PeripheralSRC;//数据传输方向:数据来源于外设
        DMA_InitStructure.DMA_BufferSize=Dbs;         //DMA缓冲区大小=数据目的地的大小
        DMA_InitStructure.DMA_PeripheralInc=DMA_PeripheralInc_Disable;             //   指定外设地址寄存器是否递增.只有一个不递增
        DMA_InitStructure.DMA_MemoryInc=DMA_MemoryInc_Enable;                      //   内存地址寄存器递增
        DMA_InitStructure.DMA_PeripheralDataSize=DMA_PeripheralDataSize_HalfWord;//   外设数据宽度为半字,即两个字节
        DMA_InitStructure.DMA_MemoryDataSize=DMA_MemoryDataSize_HalfWord;          //   内存数据宽度为半字,与外设数据大小相同
DMA_InitStructure.DMA_Mode=DMA_Mode_Circular;                              //   DMA工作模式循环输出模式    正常工作模式DMA_Mode_Normal
        DMA_InitStructure.DMA_Priority=DMA_Priority_High;                        //   优先级 DMA 传输通道优先级为高,当使用一个 DMA 通道时,优先级设置不影响
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;                               //   禁用内存到内存的传输模式   外设->内存
        DMA_Init(DMA_Chx,&DMA_InitStructure);
        DMA_Cmd(DMA_Chx,ENABLE);
初始化
#define ADC_X_PIN   GPIO_Pin_0
#define ADC_X_CHANNEL ADC_Channel_8
#define ADC_Y_PIN   GPIO_Pin_1
#define ADC_Y_CHANNEL ADC_Channel_9
// ADC1 对应 DMA1 通道 1,ADC3 对应 DMA2 通道 5,ADC2 没有 DMA 功能
#define ADC_DMA_CHANNEL DMA1_Channel1
ext short int ADC_CollectValue;   //需要ADC转换的电压值
#define NOFCHANEL2
void ADC_XY_Init(void)
        //x(PA0)、y轴 引脚初始化   模拟输入   AD
        // GPIOx_Config(RCC_APB2Periph_GPIOA,GPIOA,GPIO_Pin_0|GPIO_Pin_1,GPIO_Mode_AIN);
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
          GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN; // 模拟输入
          GPIO_Init(GPIOA,&GPIO_InitStructure);
        //ADC配置
        //Tconv = 采样时间 + 12.5 个周期    55.5+12.5Tconver=(55.5+12.5)*1/9=7.55us
       ADC_IN_x_Config();
        //ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );        //ADC1,ADC通道,采样时间为239.5周期
        //DMA配置    1、DMA通道   2、外设地址3、存储器地址4、缓冲区大小,应该等于数据目的地的大小
        DMA_Config(ADC_DMA_CHANNEL,(u32)(&( ADC1->DR )),(u32)ADC_CollectValue,NOFCHANEL);
原文链接:https://blog.csdn.net/RONG_YAO/article/details/135377664
LEDyyds 发表于 2024-6-27 16:20
有DMA,好评
埃娃 发表于 2024-6-28 17:44
两个配置的东西差不多啊
suncat0504 发表于 2024-6-29 09:33
测试结果做过比较吗?怎么样,区别大不?
结合国际经验 发表于 2024-8-31 20:02
开发设计和调试
申小林一号 发表于 2024-10-30 21:25
有对比资料么?
页: [1]
查看完整版本: 国民技术与stm32 ADC采集
