MianQi 发表于 2024-9-21 17:19
【Curiosity Nano测评报告】L6234 + BLDC
KiCad 上没有 Curiosity Nano Kit PIC16F13145,自己画了一个。
LEDyyds 发表于 2024-9-23 16:01
能不能分享出来
MianQi 发表于 2024-9-23 16:18
正在做。。。
MianQi 发表于 2024-9-23 16:47
最新进展:
MianQi 发表于 2024-9-23 16:57
这次要做的是将之间在 ATmega328P 上测试过的方案在 PIC16F13145 上复现一下,上次的帖子在这里 - https://bbs.21ic.com/icview-3376522-1-1.html
呐咯密密 发表于 2024-9-25 10:02
很好,借鉴一下
能不能分享出来
L6234 运行的核心功能来自 PIC MCU 的 GPIO,具体来说,就是每一步有一个管脚输出高,相对应的另一个管脚输出低,我先将基础的 GPIO 程序发到回复中,重要的是要注意的几个细节。
// PIC16F13145 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
#pragma config FEXTOSC = OFF    // External Oscillator Selection bits (Oscillator not enabled)
#pragma config RSTOSC = LFINTOSC// Reset Oscillator Selection bits (LFINTOSC)
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2)
#pragma config CSWEN = ON       // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config VDDAR = HI       // VDD Range Analog Calibration Selection bit (Internal analog systems are calibrated for operation between VDD = 2.3 - 5.5V)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
// CONFIG2
#pragma config MCLRE = EXTMCLR// Master Clear Enable bit (If LVP = 0, MCLR pin is MCLR; If LVP = 1, RA3 pin function is MCLR)
#pragma config PWRTS = PWRT_OFF // Power-up Timer Selection bits (PWRT is disabled)
#pragma config LPBOREN = OFF    // Low-Power BOR Enable bit (ULPBOR disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bits (Brown-out Reset enabled, SBOREN bit is ignored)
#pragma config DACAUTOEN = OFF// DAC Buffer Automatic Range Select Enable bit (DAC Buffer reference range is determined by the REFRNG bit)
#pragma config BORV = LO      // Brown-out Reset Voltage Selection bit (Brown-out Reset Voltage (VBOR) set to 1.9V)
#pragma config PPS1WAY = ON   // PPSLOCKED One-Way Set Enable bit (The PPSLOCKED bit can be cleared and set only once after an unlocking sequence is executed; once PPSLOCKED is set, all future changes to PPS registers are prevented)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a reset)
#pragma config DEBUG = OFF      // Background Debugger (Background Debugger disabled)
// CONFIG3
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF       // WDT Operating Mode bits (WDT Disabled, SEN is ignored)
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT Input Clock Select bits (Software Control)
// CONFIG4
#pragma config BBSIZE = BB512   // Boot Block Size Selection bits (512 words boot block size)
#pragma config BBEN = OFF       // Boot Block Enable bit (Boot Block disabled)
#pragma config SAFEN = OFF      // Storage Area Flash (SAF) Enable bit (SAF disabled)
#pragma config WRTAPP = OFF   // Application Block Write Protection bit (Application Block is NOT write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block is NOT write-protected)
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration Register is NOT write-protected)
#pragma config WRTSAF = OFF   // Storage Area Flash (SAF) Write Protection bit (SAF is NOT write-protected)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/Vpp pin function is MCLR. MCLRE Configuration bit is ignored)
// CONFIG5
#pragma config CP = OFF         // Program Flash Memory Code Protection bit (Program Flash Memory code protection is disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
void main(void) {
    TRISB4 = 0; // PORTx output driver is enabled. PORTx pin configured as an output.
    TRISB5 = 0; // PORTx output driver is enabled. PORTx pin configured as an output.
    ANSELB4 = 0;
    ANSELB5 = 0;// Digital I/O. Pin is assigned to port or digital special function.
    // The ANSELx bits default to the Analog mode after Reset.
    // To use any pins as digital general purpose or peripheral inputs,
    // the corresponding ANSEL bits must be changed to ‘0’ by the user.
    // for delay
    unsigned int i = 0;
    while(1) {
      /* turn off the LED (RB5 ---> 1Kohm ---> LED ---> RB4) */
      LATB4 = 1;
      LATB5 = 0;
      // Insert some delay
      i = 500;
      while(i--);
      /* turn on the LED (RB5 ---> 1Kohm ---> LED ---> RB4) */
      LATB4 = 0;
      LATB5 = 1;
      i = 500;
      while(i--);
    return;
MianQi 发表于 2024-9-25 17:36
要注意的细节是:
1、PIC MCU 要能正常运行,首要的是“ Configuration Bits”的设置,这个设置最重要的有两项:时钟源的选择(本例中选用内部低速振荡器)、关闭看门狗定时器(默认为开)。
2、每一个管脚在重启后默认的都是模拟模式为开,用户要自己给相应的寄存器清零,确保关闭这项功能。
grfqq325 发表于 2024-9-26 11:00
MCC没有备注是什么意思
MCC没有备注是什么意思
? 没明白你的意思。
? 没明白你的意思。
我用的工具组合是:
    MPLAB X IDE v6.15
    XC8 v2.50
    PIC16F1xxxx_DFP(1.25.389)
IDE提示 MCC 不可用,我就手动设置了一下。
MianQi 发表于 2024-9-28 17:27
完整的电路图:
MianQi 发表于 2024-9-28 17:30
实物照:
MianQi 发表于 2024-9-28 17:31
程序(待测试):
// CONFIG1
// CONFIG2
// CONFIG3
// CONFIG4
// CONFIG5
// Wiring
// PIC16F13145            L6234
//         RB4            IN1
//         RB5            EN1
//         RB6            IN2
//         RB7            EN2
//         RC6            IN3
//         RC7            EN3
#include <xc.h>
unsigned int bldc_step = 0;
void AH_BL(void);
void AH_CL(void);
void BH_CL(void);
void BH_AL(void);
void CH_AL(void);
void CH_BL(void);
void bldc_move(void);
void main(void) {
    TRISB6 = 0; // PORTx output driver is enabled. PORTx pin configured as an output.
    TRISB7 = 0; // PORTx output driver is enabled. PORTx pin configured as an output.
    TRISC6 = 0; // PORTx output driver is enabled. PORTx pin configured as an output.
    TRISC7 = 0; // PORTx output driver is enabled. PORTx pin configured as an output.
    ANSELB4 = 0;
    // the corresponding ANSEL bits must be changed to ?0? by the user.
    ANSELB6 = 0;
    ANSELB7 = 0;
    ANSELC6 = 0;
    ANSELC7 = 0;
    // for delay
    unsigned int i = 0;
    while(1) {
      bldc_move();
      LATB4 = 1;
      LATB5 = 0;
      //i = 500;
      //while(i--);
      bldc_step++;
      bldc_step %= 6;
      LATB4 = 0;
      LATB5 = 1;
      //i = 500;
      //while(i--);
    return;
void bldc_move(){      // BLDC motor commutation function
      switch(bldc_step){
                case 0:
                AH_BL();    // EN2 - IN1
                //BEMF_C_RISING();
                break;
                case 1:
                AH_CL();    // EN3 - IN1
                //BEMF_B_FALLING();
                break;
                case 2:
                BH_CL();    // EN3 - IN2
                //BEMF_A_RISING();
                break;
                case 3:
                BH_AL();    // EN1 - IN2
                //BEMF_C_FALLING();
                break;
                case 4:
                CH_AL();    // EN1 - IN3
                //BEMF_B_RISING();
                break;
                case 5:
                CH_BL();    // EN2 - IN3
                //BEMF_A_FALLING();
                break;
void AH_BL(){
// EN2 - IN1
    LATB4 = 1;// IN1
    LATB5 = 0;
    LATB6 = 0;
    LATB7 = 1;// EN2
    LATC6 = 0;
    LATC7 = 0;
void AH_CL(){
// EN3 - IN1
    LATB4 = 1;// IN1
    LATB5 = 0;
    LATB6 = 0;
    LATB7 = 0;
    LATC6 = 0;
    LATC7 = 1;// EN3
void BH_CL(){
// EN3 - IN2
    LATB4 = 0;
    LATB5 = 0;
    LATB6 = 1;// IN2
    LATB7 = 0;
    LATC6 = 0;
    LATC7 = 1;// EN3
void BH_AL(){
// EN1 - IN2
    LATB4 = 0;
    LATB5 = 1;// EN1
    LATB6 = 1;// IN2
    LATB7 = 0;
    LATC6 = 0;
    LATC7 = 0;
void CH_AL(){
// EN1 - IN3
    LATB4 = 0;
    LATB5 = 1;// EN1
    LATB6 = 0;
    LATB7 = 0;
    LATC6 = 1;// IN3
    LATC7 = 0;
void CH_BL(){
// EN2 - IN3
    LATB4 = 0;
    LATB5 = 0;
    LATB6 = 0;
    LATB7 = 1;// EN2
    LATC6 = 1;// IN3
    LATC7 = 0;
捉虫天师 发表于 2024-9-29 16:15
台钳不错。
MianQi 发表于 2024-10-1 10:56
实测程序:
// CONFIG1
// CONFIG2
// CONFIG3
// CONFIG4
// CONFIG5
// Wiring
//         RB4            IN1
//         RB5            EN1
//         RB6            IN2
//         RB7            EN2
//         RC6            IN3
//         RC7            EN3
#include <xc.h>
void AH_BL(void);
void AH_CL(void);
void BH_CL(void);
void BH_AL(void);
void CH_AL(void);
void CH_BL(void);
void main(void) {
    ANSELB4 = 0;
    ANSELB6 = 0;
    ANSELB7 = 0;
    ANSELC6 = 0;
    ANSELC7 = 0;
    // for delay
    unsigned int i = 0;
    while(1) {
      bldc_move();
      //i = 10;
      //while(i--);
      //LATB4 = 1;
      //LATB5 = 0;
      //i = 500;
      //while(i--);
      bldc_step++;
      bldc_step %= 6;
      //LATB4 = 0;
      //LATB5 = 1;
      //i = 500;
      //while(i--);
    return;
      switch(bldc_step){
                case 0:
                //BEMF_C_RISING();
                break;
                case 1:
                //BEMF_B_FALLING();
                break;
                case 2:
                //BEMF_A_RISING();
                break;
                case 3:
                //BEMF_C_FALLING();
                break;
                case 4:
                //BEMF_B_RISING();
                break;
                case 5:
                //BEMF_A_FALLING();
                break;
void AH_BL(){
// EN1 - EN2 - IN1
    LATB4 = 1;// IN1
    LATB5 = 1;// EN1
    LATB6 = 0;
    LATB7 = 1;// EN2
    LATC6 = 0;
    LATC7 = 0;
void AH_CL(){
// EN1 - EN3 - IN1
    LATB4 = 1;// IN1
    LATB5 = 1;// EN1
    LATB6 = 0;
    LATB7 = 0;
    LATC6 = 0;
    LATC7 = 1;// EN3
void BH_CL(){
// EN2 - EN3 - IN2
    LATB4 = 0;
    LATB5 = 0;
    LATB6 = 1;// IN2
    LATB7 = 1;// EN2
    LATC6 = 0;
    LATC7 = 1;// EN3
void BH_AL(){
// EN2 - EN1 - IN2
    LATB4 = 0;
    LATB5 = 1;// EN1
    LATB6 = 1;// IN2
    LATB7 = 1;// EN2
    LATC6 = 0;
    LATC7 = 0;
void CH_AL(){
// EN3 - EN1 - IN3
    LATB4 = 0;
    LATB5 = 1;// EN1
    LATB6 = 0;
    LATB7 = 0;
    LATC6 = 1;// IN3
    LATC7 = 1;// EN3
void CH_BL(){
// EN3 - EN2 - IN3
    LATB4 = 0;
    LATB5 = 0;
    LATB6 = 0;
    LATB7 = 1;// EN2
    LATC6 = 1;// IN3
    LATC7 = 1;// EN3
MianQi 发表于 2024-10-1 11:12
实际运行效果演示:
https://www.bilibili.com/video/BV1VmxheYEgR/
MianQi 发表于 2024-10-2 13:21
详细说明:
https://www.bilibili.com/video/BV1a74ueqEYm/
antusheng 发表于 2024-11-24 19:31
BLDC不是用PWM驱动吗
页: [1] 2 3
查看完整版本: 【Curiosity Nano测评报告】L6234 + BLDC
