sleep模式下无法被唤醒
请问N32WB03 在进入sleep之前,配置了外部中断,但是sleep了之后外部中断唤不醒,进不去对应的中断服务函数是什么原因,代码:
LEDInit(GPIOB,GPIO_PIN_2);
KeyInputExtiInit(KEY_INPUT_PORT, KEY_INPUT_PIN);
/* Enable PWR Clock */
RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_PWR, ENABLE);
//enter sleep
PWR_EnterSLEEPMode(PWR_SLEEPENTRY_WFI);
void KeyInputExtiInit(GPIO_Module* GPIOx, uint16_t Pin)
GPIO_InitType GPIO_InitStructure;
EXTI_InitType EXTI_InitStructure;
NVIC_InitType NVIC_InitStructure;
/* Check the parameters */
assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
/* Enable the GPIO Clock */
if (GPIOx == GPIOA)
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_AFIO, ENABLE);
else if (GPIOx == GPIOB)
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB /*| RCC_APB2_PERIPH_AFIO*/, ENABLE);
else
return;
/*Configure the GPIO pin as input floating*/
if (Pin <= GPIO_PIN_ALL)
GPIO_InitStruct(&GPIO_InitStructure);
GPIO_InitStructure.Pin = Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_INPUT;
GPIO_InitStructure.GPIO_Pull = GPIO_NO_PULL;
GPIO_InitPeripheral(GPIOx, &GPIO_InitStructure);
/*Configure key EXTI Line to key input Pin*/
GPIO_ConfigEXTILine(KEY_INPUT_PORT_SOURCE, KEY_INPUT_PIN_SOURCE);
/*Configure key EXTI line*/
EXTI_InitStructure.EXTI_Line = KEY_INPUT_EXTI_LINE;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising; // EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_InitPeripheral(&EXTI_InitStructure);
/*Set key input interrupt priority*/
NVIC_InitStructure.NVIC_IRQChannel = KEY_INPUT_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
} 你先试试加上定时中断(定时中期长一些,避免刚进入睡眠就被唤醒)。看看能不能自动唤醒。然后再确认,是不是外部中断的设置不正确。定时中断触发LED亮灭,这样更便于观察。 对了,你可以先利用LED,验证外部中断是不是起作用了,然后再去测试中断唤醒功能。 LedOn(LED1_PORT, LED1_PIN);
delay(3000);
LedOff(LED1_PORT, LED1_PIN);
//enter sleep
PWR_EnterSLEEPMode(PWR_SLEEPENTRY_WFI);//PWR_SLEEPENTRY_WFI
//exit sleep
LEDInit(LED1_PORT, LED1_PIN);
KeyInputExtiInit(KEY_INPUT_PORT, KEY_INPUT_PIN); 在进入sleep模式前,可能没有正确配置或使能相关的时钟,特别是与GPIO和外部中断相关的时钟。
中断配置没有对吧
页:
[1]
