玛尼玛尼哄 发表于 2024-9-27 22:44
PIC18F2520驱动RDA5807方案
**** Hidden Message *****
是一个非常简单的固件,用于控制RDA5807 I2C 无线电 ic。
[*]2x16 LCD 显示屏。
[*]存储 6 个内存位置。
[*]RDS 就绪。
[*]音量控制。
    File:   main.c
    Copyright 2016 Marcos Mori de Siqueira <mori.br@gmail.com>
    Licensed under the Apache License, Version 2.0 (the "License");
    you may not use this file except in compliance with the License.
    You may obtain a copy of the License at
       http://www.apache.org/licenses/LICENSE-2.0
    Unless required by applicable law or agreed to in writing, software
    distributed under the License is distributed on an "AS IS" BASIS,
    WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
    See the License for the specific language governing permissions and
    limitations under the License.
//#include <p18cxxx.h>
#include <p18f2520.h>
#include <delays.h>
#include <usart.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <i2c.h>
#include <timers.h>
#include "rda5807.h"
#include "hardwareprofile.h"
#include "LCDBlocking.h"
#include "TimeDelay.h"
#include "keypad.h"
#include "log.h"
#include "eeprom.h"
#include "rds.h"
#include "options.h"
#include "test.h"
#include <math.h>
#pragma config OSC    = HS
#pragma config WDT    = OFF
#pragma config LVP    = OFF
#pragma config MCLRE= ON
#pragma config PWRT   = ON
#pragma config PBADEN = OFF
#define MAX_VOLUME          0x0C    //0x0F
#define SAVE_TIMEOUT      5000
#define BACK2IDLE_TIMEOUT   1000
#define MENU_TIMEOUT      50000
#define STATE_IDLE          0
#define STATE_VOLUME      1
#define STATE_MEMORY      2
#define STATE_MENU          3
#define STATE_LAST_BASIC    3
#define STATE_LAST          4
static BYTE mem_idx = 0;
static BYTE state = STATE_IDLE;
static LONG state_timeout = 0;
extern volatile RDSINFO rds;
static RDAINFO info;
typedef struct
    RDA_MEMORY mem;
    LONG mem_save_timeout;
    BYTE enabled;
} SAVEINFO;
static SAVEINFO save_info = {{0},0,0};
static void update_lcd(void);
static void process_dn(void);
static void process_up(void);
static BYTE setup_memory(void);
void main(void)
    char *c = 0;
    DWORD counter = 0, read = 0;
    BYTEevt;
    DWORD ellapsed = 0;
    BYTEbtn_ok_pressed = 0;
    CMCON   = 0x07; // Comparators Off
    CVRCON= 0;    // voltage reference=off
    ADCON1= 0x0F; // Disable ALL adc channels, PDF page 226
    LED1_TRIS    = OUTPUT_PIN;
        I2C_SCL_TRIS = OUTPUT_PIN;
        I2C_SDA_TRIS = OUTPUT_PIN;
    // Uart
    OpenUSART(USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, 10);
    LOG((ROMCHAR)"\r\n-------------------------------------------------\r\n");
    KeypadInit();
    LCDInit();
    // Setup I2C
    OpenI2C(MASTER, SLEW_OFF);
    //SSPADD = 0x32; //100kHz Baud clock @20MHz
    SSPADD = 0x0B;//400kHz Baud clock @20MHz
    LCDErase();
    strcpypgm2ram(c, (ROMCHAR)"    STARTING    ");
    LCDWriteLine(1, c);
    memset(save_info.mem.data, 0, sizeof(RDA_MEMORY));
//TEST_eeprom_reset();
    if(!EEPROM_load_data(&save_info.mem))
LOG((ROMCHAR)"loading default config\r\n");
      save_info.mem.flags   = RDA_FLAG_RDS|RDA_FLAG_BASS;
      save_info.mem.channel = 101.7;
      save_info.mem.volume= 1;
//save_info.mem.memory = 97.7;
//save_info.mem.memory = 103.3;
//save_info.mem.memory = 90.5;
    LOG((ROMCHAR)"init\r\n");
    RDA5807M_init();
    RDA5807M_PowerON();
    DelayMs(200);
    // Setup radio
    RDA5807M_SetVolume(save_info.mem.volume);
    RDA5807M_SetFrequency(save_info.mem.channel);
    RDA5807M_BassBoost(save_info.mem.flags & RDA_FLAG_BASS);
    RDA5807M_Mono(save_info.mem.flags & RDA_FLAG_MONO);
    RDA5807M_RDS(save_info.mem.flags & RDA_FLAG_RDS);
        while(1)
      LED1 = 0;
      if(counter++ > 3000)
            counter = 0;
            LED1 = 1;
            DelayMs(10);
      evt = GetButtonsEvents();
           if(evt != EVENT_NOTHING)
                        if(evt == EVENT_UP_BUTTON_PUSHED)
                if(state != STATE_MENU)
//LOG((ROMCHAR)"up %d\r\n", state);
                  if(++state >= STATE_LAST_BASIC)
                        state = STATE_IDLE;
                  if(state == STATE_MEMORY)
                        mem_idx = setup_memory();
                  if(state > STATE_IDLE)
                        state_timeout = BACK2IDLE_TIMEOUT;
                  else
                        state_timeout = 0;
                        rds.ps_valid = 1;
                        rds.rt_valid = 1;
                else
                  state_timeout = MENU_TIMEOUT;
                  MENU_run(MENU_UP);
                        else if(evt == EVENT_DN_BUTTON_PUSHED)
//LOG((ROMCHAR)"dn %d\r\n", state);
                  if(--state >= 0xFF)
                        state = STATE_IDLE;
                  else
                        state_timeout = 0;
                        rds.ps_valid = 1;
                        rds.rt_valid = 1;
                else
                  MENU_run(MENU_DOWN);
                        else if(evt == EVENT_LEFT_BUTTON_PUSHED)
                //LOG((ROMCHAR)"left\r\n");
                if(state == STATE_MENU)
                  MENU_run(MENU_LEFT);
                else
                  process_dn();
                        else if(evt == EVENT_RIGHT_BUTTON_PUSHED)
                //LOG((ROMCHAR)"right\r\n");
                  MENU_run(MENU_RIGHT);
                else
                  process_up();
            else if(evt == EVENT_OK_BUTTON_PUSHED)
                btn_ok_pressed = 1;
                ellapsed = 0;
            else if(evt == EVENT_MENU_BUTTON_PUSHED)
                LOG((ROMCHAR)"menu\r\n");
                  state_timeout = 1;// change to idle
                else
                  MENU_init(&save_info.mem);
                  state = STATE_MENU;
            else if(evt == EVENT_OK_BUTTON_RELEASED)
LOG((ROMCHAR)"OK released\r\n");
                btn_ok_pressed = 0;
                if(ellapsed < 250)
                        if(MENU_run(MENU_OK))
                            save_info.enabled = 1;
                            state_timeout = 400;
                        else
                  else
                        switch(state)
                            case STATE_IDLE:
                              RDA5807M_Mute();
                              break;
                            case STATE_MEMORY:
                              if(save_info.mem.memory > 0)
                                    RDA5807M_SetFrequency(save_info.mem.memory);
                              break;
      if(read++ > 1)
            read = 0;
            RDA5807M_Read(&info);
            update_lcd();
      if(save_info.mem_save_timeout > 0)
            if(--save_info.mem_save_timeout <= 0)
                save_info.mem_save_timeout = 0;
LOG((ROMCHAR)"SAVE DATA EEPROM\r\n");
LOG((ROMCHAR)"chann %d\r\n", (int)save_info.mem.channel);
            EEPROM_save_data(&save_info.mem);
      // Dont back to IDLE while pressing memory saving button
      if(!btn_ok_pressed && state_timeout > 0)
            if(--state_timeout <= 0)
LOG((ROMCHAR)"IDLE\r\n");
                state_timeout = 0;
                rds.ps_valid = 1;
                rds.rt_valid = 1;
                state = STATE_IDLE;
      ellapsed++;
      if(btn_ok_pressed && ellapsed > 250)
            save_info.mem.memory = save_info.mem.channel;
            state_timeout = 1;
    switch(state)
      case STATE_IDLE:
            RDA5807M_SeekUp();
            break;
      case STATE_VOLUME:
            if(++save_info.mem.volume >= MAX_VOLUME)
                save_info.mem.volume = MAX_VOLUME;
            break;
      case STATE_MEMORY:
            if(++mem_idx >= MAX_CHANNEL_MEM)
                mem_idx = MAX_CHANNEL_MEM-1;
            break;
    switch(state)
      case STATE_IDLE:
            RDA5807M_SeekDown();
            break;
      case STATE_VOLUME:
            if(--save_info.mem.volume >= 0xFF)
                save_info.mem.volume = 0;
            break;
      case STATE_MEMORY:
            if(--mem_idx >= 0xFF)
                mem_idx = 0;
            break;
static void update_volume(void)
    BYTE i = 0;
    strcpypgm2ram(LCDText, (ROMCHAR)"VOL ");
    for(; i < save_info.mem.volume; ++i)
      strcatpgm2ram(LCDText, (ROMCHAR)"\xFF");
    BYTE i = 0;
    for(; i < MAX_CHANNEL_MEM; ++i)
      if(save_info.mem.memory > 0 && save_info.mem.memory == info.freq)
            return i;
    return 0xFF;
    int num, dec;
    char c = {0};
    BYTE memidx = 0;
    char m = {' '};
    char m1 = {' ',' ', 0};
    static BYTE size = 0;
    static BYTE pos= 0;
    static WORD ps   = 0;
    if(state < STATE_LAST_BASIC)
      // Draw line 1
            // Display current memory station
            strncpypgm2ram(LCDText, (ROMCHAR)"       FM ---.- ", 16);
                num = save_info.mem.memory;
                dec = (int)floor(((save_info.mem.memory - num) * 100)/10);
                if(dec % 2 == 0) dec += 1;
                sprintf(c, (ROMCHAR)"       FM %3d.%1d ", num, dec);
                strncpy(LCDText, c, 16);
      else
            // Display station currently tunned
            strncpypgm2ram(LCDText, (ROMCHAR)" \xA5\xA5 SCANNING \xA5\xA5 ", 16);
            //if(info.fmtrue && info.tuneok)
                num = info.freq;
                dec = (int)floor(((info.freq - num) * 100)/10);
                memidx = setup_memory();
                if(memidx != 0xFF) {
                  itoa(memidx+1, m);
                  m1 = 'M';
                  m1 = m;
                if(info.stereo)
                  sprintf(c, (ROMCHAR)"%1d %s   FM %3d.%1d\xA5", info.rssi, m1, num, dec);
                else
                  sprintf(c, (ROMCHAR)"%1d %s   FM %3d.%1d ", info.rssi, m1, num, dec);
                // Start save timer
                if(save_info.enabled)
                  save_info.mem.channel = info.freq;
                  save_info.mem_save_timeout = SAVE_TIMEOUT;
                  save_info.enabled = 0;
      switch(state)
            case STATE_IDLE:
                if(!rds.use_rt && rds.ps_valid)
                  rds.ps_valid = 0;
                  memset(LCDText, ' ', 16);
                  strncpy(&LCDText, rds.ps_copy, 8);
                else
                  if(rds.rt_valid)
                        rds.rt_valid = 0;
                        size = strlen(rds.rt_copy);
                        pos = 0;
                        ps = 0;
                        strncpy(LCDText, rds.rt_copy, size > 16 ? 16 : size);
                  else
                        if(rds.use_rt && ps++ > 30)
                            ps = 0;
                            if(size < 16)
                            else
                              strncpy(LCDText, &rds.rt_copy, (size - pos) > 16 ? 16 : size);
            break;
            case STATE_VOLUME:
                update_volume();
                break;
            case STATE_MEMORY:
                switch(mem_idx)
                  case 0:
                        strncpypgm2ram(LCDText, (ROMCHAR)"MEM \x0A51 2 3 4 5 6", 16);
                        break;
                  case 1:
                        strncpypgm2ram(LCDText, (ROMCHAR)"MEM 1 \x0A52 3 4 5 6", 16);
                        break;
                  case 2:
                        strncpypgm2ram(LCDText, (ROMCHAR)"MEM 1 2 \x0A53 4 5 6", 16);
                        break;
                  case 3:
                        strncpypgm2ram(LCDText, (ROMCHAR)"MEM 1 2 3 \x0A54 5 6", 16);
                        break;
                  case 4:
                        strncpypgm2ram(LCDText, (ROMCHAR)"MEM 1 2 3 4 \x0A55 6", 16);
                        break;
                  case 5:
                        strncpypgm2ram(LCDText, (ROMCHAR)"MEM 1 2 3 4 5 \x0A56", 16);
                        break;
                  default:
                        LOG((ROMCHAR)"ERR %d\r\n", mem_idx);
                        mem_idx = 0;
                        break;
            break;
    else
      MENU_draw();
    LCDUpdate();
xinpian101 发表于 2024-9-28 21:00
只要实现I2C读写一般就没太多问题了。所以学会I2C很重要啊。
coyoteie 发表于 2024-10-13 07:53
{:victory:}
页: [1]
查看完整版本: PIC18F2520驱动RDA5807方案
