598330983 发表于 2024-9-28 13:33
ATtiny85驱动RDA5807的收音机应用
**** Hidden Message *****
// Project:   tinyFMradio - FM Tuner with RDS based on ATtiny45/85 and RDA5807
// Version:   v1.0
// Year:      2019 - 2021
// Author:    Stefan Wagner
// Github:    https://github.com/wagiminator
// EasyEDA:   https://easyeda.com/wagiminator
// License:   http://creativecommons.org/licenses/by-sa/3.0/
// Description:
// This is just a demo sketch that implements basic functionality. By pressing
// the rotary encoder button the RDA5807 seeks the next radio station. Turning
// the rotary encoder increases/decreases the volume. Selected frequency and
// volume are stored in the EEPROM. Station name, frequency, signal strength,
// volume and battery state of charge are shown on an OLED display.
// References:
// RDA5807 datasheet:
// https://datasheet.lcsc.com/szlcsc/1806121226_RDA-Microelectronics-RDA5807MP_C167245.pdf
// SSD1306 OLED datasheet:
// https://cdn-shop.adafruit.com/datasheets/SSD1306.pdf
// The OLED font was adapted from Neven Boyanov and Stephen Denne:
// https://github.com/datacute/Tiny4kOLED
// The RDA8507 implementation was adapted from Maarten Janssen:
// https://hackaday.io/project/9009-arduino-radio-with-rds
// Wiring:
//         --- RST ADC0 PB51|°   |8Vcc
// Encoder A ------- ADC3 PB32|    |7PB2 ADC1 -------- OLED/RDA SCK
// Encoder B ------- ADC2 PB43|    |6PB1 AIN1 OC0B --- Encoder SW
//                        GND4|    |5PB0 AIN0 OC0A --- OLED/RDA SDA
// Compilation Settings:
// Core:    ATtinyCore (https://github.com/SpenceKonde/ATTinyCore)
// Board:   ATtiny25/45/85 (No bootloader)
// Chip:    ATtiny 45 or ATtiny85 (depending on your chip)
// Clock:   1 MHz (internal)
// B.O.D:   disabled
// Leave the rest on default settings. Don't forget to "Burn bootloader"!
// No Arduino core functions or libraries are used. Use the makefile if
// you want to compile without Arduino IDE.
// Fuse settings: -U lfuse:w:0x62:m -U hfuse:w:0xd7:m -U efuse:w:0xff:m
// Libraries, Definitions and Macros
// Libraries
#include <avr/io.h>               // for GPIO
#include <avr/eeprom.h>             // for storing user settings into EEPROM
#include <avr/pgmspace.h>         // for reading data from program memory
#include <avr/interrupt.h>          // for interrupt functions
#include <util/delay.h>             // for delays
// Pin assignments
#define PIN_SDA       PB0         // I2C Serial Data,connect to OLED/RDA
#define PIN_SCL       PB2         // I2C Serial Clock, connect to OLED/RDA
#define PIN_ENC_SW    PB1         // pin connected to rotary encoder switch
#define PIN_ENC_A   PB3         // pin connected to rotary encoder A
#define PIN_ENC_B   PB4         // pin connected to rotary encoder B
// EEPROM identifier
#define EEPROM_IDENT0x6CE7      // to identify if EEPROM was written by this program
// Text strings
const char HEADER[] PROGMEM = "Tiny FM Radio v1.0";
// Variables
uint16_tchannel;                  // 0 .. 1023
uint8_t   volume = 1;               // 0 .. 15
// Pin manipulation macros
#define pinInput(x)   DDRB&= ~(1<<(x))      // set pin to INPUT
#define pinOutput(x)DDRB|=(1<<(x))      // set pin to OUTPUT
#define pinLow(x)   PORTB &= ~(1<<(x))      // set pin to LOW
#define pinHigh(x)    PORTB |=(1<<(x))      // set pin to HIGH
#define pinPullup(x)PORTB |=(1<<(x))      // enable PULLUP resistor
#define pinIntEn(x)   PCMSK |=(1<<(x))      // enable pin change interrupt
#define pinIntDis(x)PCMSK &= ~(1<<(x))      // disable pin change interrupt
#define pinRead(x)    (PINB &   (1<<(x)))       // READ pin
// I2C Master Implementation
// I2C macros
#define I2C_SDA_HIGH()pinInput(PIN_SDA)       // release SDA   -> pulled HIGH by resistor
#define I2C_SDA_LOW()   pinOutput(PIN_SDA)      // SDA as output -> pulled LOWby MCU
#define I2C_SCL_HIGH()pinInput(PIN_SCL)       // release SCL   -> pulled HIGH by resistor
#define I2C_SCL_LOW()   pinOutput(PIN_SCL)      // SCL as output -> pulled LOWby MCU
#define I2C_SDA_READ()pinRead(PIN_SDA)      // read SDA line
#define I2C_CLOCKOUT()I2C_SCL_HIGH();I2C_SCL_LOW()// clock out
// I2C transmit one data byte to the slave, ignore ACK bit, no clock stretching allowed
void I2C_write(uint8_t data) {
for(uint8_t i=8; i; i--, data<<=1) {          // transmit 8 bits, MSB first
    (data&0x80)?I2C_SDA_HIGH():I2C_SDA_LOW();   // SDA depending on bit
    I2C_CLOCKOUT();                           // clock out -> slave reads the bit
I2C_SDA_HIGH();                               // release SDA for ACK bit of slave
I2C_CLOCKOUT();                               // 9th clock pulse is for the ignored ACK bit
// I2C start transmission
void I2C_start(uint8_t addr) {
I2C_SDA_LOW();                              // start condition: SDA goes LOW first
I2C_SCL_LOW();                              // start condition: SCL goes LOW second
I2C_write(addr);                              // send slave address
// I2C restart transmission
void I2C_restart(uint8_t addr) {
I2C_SDA_HIGH();                               // prepare SDA for HIGH to LOW transition
I2C_SCL_HIGH();                               // restart condition: clock HIGH
I2C_start(addr);                              // start again
// I2C stop transmission
void I2C_stop(void) {
I2C_SDA_LOW();                              // prepare SDA for LOW to HIGH transition
I2C_SCL_HIGH();                               // stop condition: SCL goes HIGH first
I2C_SDA_HIGH();                               // stop condition: SDA goes HIGH second
// I2C receive one data byte from the slave (ack=0 for last byte, ack>0 if more bytes to follow)
uint8_t I2C_read(uint8_t ack) {
uint8_t data = 0;                           // variable for the received byte
I2C_SDA_HIGH();                               // release SDA -> will be toggled by slave
for(uint8_t i=8; i; i--) {                  // receive 8 bits
    data <<= 1;                                 // bits shifted in right (MSB first)
    I2C_SCL_HIGH();                           // clock HIGH
    if(I2C_SDA_READ()) data |= 1;               // read bit
    I2C_SCL_LOW();                              // clock LOW -> slave prepares next bit
if(ack) I2C_SDA_LOW();                        // pull SDA LOW to acknowledge (ACK)
I2C_CLOCKOUT();                               // clock out -> slave reads ACK bit
return data;                                  // return the received byte
// OLED Implementation
// OLED definitions
#define OLED_ADDR       0x78                  // OLED write address
#define OLED_CMD_MODE   0x00                  // set command mode
#define OLED_DAT_MODE   0x40                  // set data mode
#define OLED_INIT_LEN   9                     // length of init command array
// OLED init settings
const uint8_t OLED_INIT_CMD[] PROGMEM = {
0xC8, 0xA1,                                 // flip screen
0xA8, 0x1F,                                 // set multiplex ratio
0xDA, 0x02,                                 // set com pins hardware configuration
0x8D, 0x14,                                 // set DC-DC enable
0xAF                                          // display on
// Standard ASCII 5x8 font (adapted from Neven Boyanov and Stephen Denne)
const uint8_t OLED_FONT[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2F, 0x00, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00,
0x14, 0x7F, 0x14, 0x7F, 0x14, 0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x23, 0x13, 0x08, 0x64, 0x62,
0x36, 0x49, 0x55, 0x22, 0x50, 0x00, 0x05, 0x03, 0x00, 0x00, 0x00, 0x1C, 0x22, 0x41, 0x00,
0x00, 0x41, 0x22, 0x1C, 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14, 0x08, 0x08, 0x3E, 0x08, 0x08,
0x00, 0x00, 0xA0, 0x60, 0x00, 0x08, 0x08, 0x08, 0x08, 0x08, 0x00, 0x60, 0x60, 0x00, 0x00,
0x20, 0x10, 0x08, 0x04, 0x02, 0x3E, 0x51, 0x49, 0x45, 0x3E, 0x00, 0x42, 0x7F, 0x40, 0x00,
0x42, 0x61, 0x51, 0x49, 0x46, 0x21, 0x41, 0x45, 0x4B, 0x31, 0x18, 0x14, 0x12, 0x7F, 0x10,
0x27, 0x45, 0x45, 0x45, 0x39, 0x3C, 0x4A, 0x49, 0x49, 0x30, 0x01, 0x71, 0x09, 0x05, 0x03,
0x36, 0x49, 0x49, 0x49, 0x36, 0x06, 0x49, 0x49, 0x29, 0x1E, 0x00, 0x36, 0x36, 0x00, 0x00,
0x00, 0x56, 0x36, 0x00, 0x00, 0x08, 0x14, 0x22, 0x41, 0x00, 0x14, 0x14, 0x14, 0x14, 0x14,
0x00, 0x41, 0x22, 0x14, 0x08, 0x02, 0x01, 0x51, 0x09, 0x06, 0x32, 0x49, 0x59, 0x51, 0x3E,
0x7C, 0x12, 0x11, 0x12, 0x7C, 0x7F, 0x49, 0x49, 0x49, 0x36, 0x3E, 0x41, 0x41, 0x41, 0x22,
0x7F, 0x41, 0x41, 0x22, 0x1C, 0x7F, 0x49, 0x49, 0x49, 0x41, 0x7F, 0x09, 0x09, 0x09, 0x01,
0x3E, 0x41, 0x49, 0x49, 0x7A, 0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00, 0x41, 0x7F, 0x41, 0x00,
0x20, 0x40, 0x41, 0x3F, 0x01, 0x7F, 0x08, 0x14, 0x22, 0x41, 0x7F, 0x40, 0x40, 0x40, 0x40,
0x7F, 0x02, 0x0C, 0x02, 0x7F, 0x7F, 0x04, 0x08, 0x10, 0x7F, 0x3E, 0x41, 0x41, 0x41, 0x3E,
0x7F, 0x09, 0x09, 0x09, 0x06, 0x3E, 0x41, 0x51, 0x21, 0x5E, 0x7F, 0x09, 0x19, 0x29, 0x46,
0x46, 0x49, 0x49, 0x49, 0x31, 0x01, 0x01, 0x7F, 0x01, 0x01, 0x3F, 0x40, 0x40, 0x40, 0x3F,
0x1F, 0x20, 0x40, 0x20, 0x1F, 0x3F, 0x40, 0x38, 0x40, 0x3F, 0x63, 0x14, 0x08, 0x14, 0x63,
0x07, 0x08, 0x70, 0x08, 0x07, 0x61, 0x51, 0x49, 0x45, 0x43, 0x00, 0x7F, 0x41, 0x41, 0x00,
0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x41, 0x41, 0x7F, 0x00, 0x04, 0x02, 0x01, 0x02, 0x04,
0x40, 0x40, 0x40, 0x40, 0x40, 0x00, 0x01, 0x02, 0x04, 0x00, 0x20, 0x54, 0x54, 0x54, 0x78,
0x7F, 0x48, 0x44, 0x44, 0x38, 0x38, 0x44, 0x44, 0x44, 0x20, 0x38, 0x44, 0x44, 0x48, 0x7F,
0x38, 0x54, 0x54, 0x54, 0x18, 0x08, 0x7E, 0x09, 0x01, 0x02, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,
0x7F, 0x08, 0x04, 0x04, 0x78, 0x00, 0x44, 0x7D, 0x40, 0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,
0x7F, 0x10, 0x28, 0x44, 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,
0x7C, 0x08, 0x04, 0x04, 0x78, 0x38, 0x44, 0x44, 0x44, 0x38, 0xFC, 0x24, 0x24, 0x24, 0x18,
0x18, 0x24, 0x24, 0x18, 0xFC, 0x7C, 0x08, 0x04, 0x04, 0x08, 0x48, 0x54, 0x54, 0x54, 0x20,
0x04, 0x3F, 0x44, 0x40, 0x20, 0x3C, 0x40, 0x40, 0x20, 0x7C, 0x1C, 0x20, 0x40, 0x20, 0x1C,
0x3C, 0x40, 0x30, 0x40, 0x3C, 0x44, 0x28, 0x10, 0x28, 0x44, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,
0x44, 0x64, 0x54, 0x4C, 0x44, 0x08, 0x36, 0x41, 0x41, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x00,
0x00, 0x41, 0x41, 0x36, 0x08, 0x08, 0x04, 0x08, 0x10, 0x08, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
// OLED variables
uint8_t OLED_x, OLED_y;                         // current cursor position
const uint16_t DIVIDER[] PROGMEM = {10000, 1000, 100, 10, 1}; // BCD conversion array
// OLED init function
void OLED_init(void) {
I2C_start(OLED_ADDR);                         // start transmission to OLED
I2C_write(OLED_CMD_MODE);                     // set command mode
for (uint8_t i = 0; i < OLED_INIT_LEN; i++)
    I2C_write(pgm_read_byte(&OLED_INIT_CMD));// send the command bytes
I2C_stop();                                 // stop transmission
// OLED set the cursor
void OLED_setCursor(uint8_t xpos, uint8_t ypos) {
I2C_write(xpos & 0x0F);                     // set low nibble of start column
I2C_write(0x10 | (xpos >> 4));                // set high nibble of start column
I2C_write(0xB0 | (ypos & 0x07));            // set start page
OLED_x = xpos; OLED_y = ypos;               // set the cursor variables
// OLED clear rest of the current line
void OLED_clearLine(void) {
I2C_write(OLED_DAT_MODE);                     // set data mode
while(OLED_x++ < 128) I2C_write(0);         // clear rest of the line
if(++OLED_y > 3) OLED_y = 0;                  // calculate next line
OLED_setCursor(0, OLED_y);                  // set cursor to start of next line
// OLED clear screen
void OLED_clearScreen(void) {
OLED_setCursor(0, 0);                         // set cursor to home position
for(uint8_t i=4; i; i--) OLED_clearLine();    // clear all 4 lines
// OLED plot a single character
void OLED_plotChar(char c) {
uint16_t ptr = c - 32;                        // character pointer
ptr += ptr << 2;                              // -> ptr = (ch - 32) * 5;
I2C_write(0x00);                              // write space between characters
for (uint8_t i=5 ; i; i--) I2C_write(pgm_read_byte(&OLED_FONT));
OLED_x += 6;                                  // update cursor
if (OLED_x > 122) {                           // line end ?
    I2C_stop();                                 // stop data transmission
    OLED_setCursor(0,++OLED_y);               // set next line start
// OLED print a string
void OLED_printStr(uint8_t* str) {
while(*str) OLED_plotChar(*str++);            // plot each character
// OLED print a string from program memory
void OLED_print(const char* p) {
char ch = pgm_read_byte(p);                   // read first character from program memory
while (ch) {                                  // repeat until string terminator
    OLED_plotChar(ch);                        // print character on OLED
    ch = pgm_read_byte(++p);                  // read next character
// OLED print a string from program memory with new line
void OLED_println(const char* p) {
OLED_print(p);
OLED_clearLine();
// OLED print 8-bit value as 2-digit decimal (BCD conversion by substraction method)
void OLED_printVal(uint8_t value) {
if(value > 99) value = 99;                  // limit 2-digit value
uint8_t digitval = 0;                         // start with digit value 0
while(value >= 10) {                        // if current divider fits into the value
    digitval++;                                 // increase digit value
    value -= 10;                              // decrease value by divider
if(digitval) OLED_plotChar(digitval + '0');   // print first digit
else OLED_plotChar(' ');                      // leading space if zero
OLED_plotChar(value + '0');                   // print second digit
// OLED print frequency (BCD conversion by substraction method)
void OLED_printFrequency(uint16_t value) {
uint8_t leadflag = 0;                         // flag for leading spaces
for(uint8_t digit = 0; digit < 5; digit++) {// 5 digits
    uint16_t divider = pgm_read_word(&DIVIDER); // current divider
    while(value >= divider) {                   // if current divider fits into the value
      leadflag = 1;                           // end of leading spaces
      value -= divider;                         // decrease value by divider
    if(leadflag || (digit > 1)) OLED_plotChar(digitval + '0'); // print the digit
    else OLED_plotChar(' ');                  // or print leading space
    if(digit == 2) OLED_plotChar('.');          // print decimal after 3rd digit
// RDA5807 Implementation
// RDA definitions
#define RDA_ADDR_SEQ    0x20                  // RDA I2C write address for sequential access
#define RDA_ADDR_INDEX0x22                  // RDA I2C write address for indexed access
#define RDA_VOL         1                     // start volume
// RDA register definitions
enum{ RDA_REG_2, RDA_REG_3, RDA_REG_4, RDA_REG_5, RDA_REG_6, RDA_REG_7 };
enum{ RDA_REG_A, RDA_REG_B, RDA_REG_C, RDA_REG_D, RDA_REG_E, RDA_REG_F };
uint16_t RDA_read_regs;                      // RDA registers for reading
uint16_t RDA_write_regs = {                  // RDA registers for writing:
0b1101001000001101,                           // RDA register 0x02 preset
0b0001010111000000,                           // RDA register 0x03 preset
0b0000101000000000,                           // RDA register 0x04 preset
0b1000100010000000,                           // RDA register 0x05 preset
0b0000000000000000,                           // RDA register 0x06 preset
0b0000000000000000                            // RDA register 0x07 preset
// RDA state macros
#define RDA_hasRdsData      ( RDA_read_regs & 0x8000 )
#define RDA_isTuning          (~RDA_read_regs & 0x4000 )
#define RDA_tuningError       ( RDA_read_regs & 0x2000 )
#define RDA_hasRdsBlockE      ( RDA_read_regs & 0x0800 )
#define RDA_isStereo          ( RDA_read_regs & 0x0400 )
#define RDA_channel         ( RDA_read_regs & 0x03FF )
#define RDA_isTunedToChannel( RDA_read_regs & 0x0100 )
#define RDA_rdsBlockE         ( RDA_read_regs & 0x0010 )
#define RDA_rdsBlockErrors    ( RDA_read_regs & 0x000F )
#define RDA_signalStrength    ((RDA_read_regs & 0xFE00 ) >> 9 )
// RDA variables
uint8_t RDA_stationName;                     // string for the station name
uint8_t RDA_rdsStationName;                  // just for internal use
// RDA write specified register
void RDA_writeReg(uint8_t reg) {
I2C_start(RDA_ADDR_INDEX);                  // start I2C for index write to RDA
I2C_write(0x02 + reg);                        // set the register to write
I2C_write(RDA_write_regs >> 8);          // send high byte
I2C_write(RDA_write_regs);               // send low byte
I2C_stop();                                 // stop I2C
// RDA write all registers
void RDA_writeAllRegs(void) {
I2C_start(RDA_ADDR_SEQ);                      // start I2C for sequential write to RDA
for(uint8_t i=0; i<6; i++) {                  // write to 6 registers
// RDA read all registers
void RDA_readAllRegs(void) {
I2C_start(RDA_ADDR_SEQ | 1);                  // start I2C for sequential read from RDA
for(uint8_t i=0; i<6; i++)                  // read 6 registers
    RDA_read_regs = (uint16_t)(I2C_read(1) << 8) | I2C_read(5-i);
// RDA clear station
void RDA_resetStation(void) {
for(uint8_t i=0; i<8; i++) RDA_stationName = ' ';
// RDA initialize tuner
void RDA_init(void) {
RDA_resetStation();                           // reset station available
RDA_stationName = 0;                     // set string terminator
RDA_write_regs |=0x0002;         // set soft reset
RDA_write_regs |=RDA_VOL;      // set start volume
RDA_writeAllRegs();                           // write all registers
RDA_write_regs &= ~0x0002;         // clear soft reset
RDA_writeReg(RDA_REG_2);                      // write to register 0x02
// RDA set volume
void RDA_setVolume(uint8_t vol) {
RDA_write_regs &= ~0x000F;         // clear volume bits
RDA_write_regs |=vol;            // set volume
RDA_writeReg(RDA_REG_5);                      // write to register 0x05
// RDA tune to a specified channel
void RDA_setChannel(uint16_t chan) {
RDA_resetStation();
RDA_write_regs &= ~0xFFC0;         // clear channel
RDA_write_regs |= (chan << 6) | 0x0010;// set channel and tune enable
RDA_writeReg(RDA_REG_3);                      // write register
// RDA seek next channel
void RDA_seekUp(void) {
RDA_resetStation();
RDA_write_regs |=0x0100;         // set seek enable bit
// RDA update status and handle RDS
void RDA_updateStatus(void) {
RDA_readAllRegs();
// When tuned disable tuning and stop seeking
if (!RDA_isTuning) {
    RDA_write_regs &= ~0x0010;       // clear tune enable flag
    RDA_write_regs &= ~0x0100;       // clear seek enable flag
// Check for RDS data
if(RDA_hasRdsData) {                        // RDS ready?
    // Toggle RDS flag to request new data
    RDA_write_regs &= ~0x0008;       // clear RDS flag
    RDA_write_regs |=0x0008;       // set RDS flag
    // Decode RDS message (station name)
    if(!RDA_rdsBlockE) {                                       // REG_B..F carrying blocks A-D?
      if( (RDA_read_regs & 0xF800) == 0x0000) {       // is it station name?
      uint8_t offset = (RDA_read_regs & 0x03) << 1; // get character position
      uint8_t c1 = RDA_read_regs >> 8;            // get character 1
      uint8_t c2 = RDA_read_regs;                   // get character 2
      // Copy station name characters only if received twice in a row...
      if(RDA_rdsStationName == c1)                     // 1st char received twice?
             RDA_stationName = c1;                     // copy to station name
      else RDA_rdsStationName = c1;                  // save for next test
      if(RDA_rdsStationName == c2)               // 2nd char received twice?
             RDA_stationName = c2;                   // copy to station name
      else RDA_rdsStationName = c2;                // save for next test
// Calculate frequency in 10kHz
uint16_t RDA_getFrequency(void) {
return(8700 + (RDA_channel << 3) + (RDA_channel << 1));
// Waits until tuning completed
void RDA_waitTuning(void) {
do {
    _delay_ms(100);
    RDA_updateStatus();
} while(RDA_isTuning);
// ADC Implementation for Supply Voltage Measurement
// Init ADC
void ADC_init(void) {
ADCSRA = (1<<ADPS1) | (1<<ADPS0);             // set ADC clock prescaler to 8
ADMUX= (1<<MUX3)| (1<<MUX2);            // set 1.1V Vref against Vcc
// Read Vcc voltage in dV by measuring 1.1V reference against Vcc
uint8_t ADC_readVcc(void) {
PRR    &= ~(1<<PRADC);                        // power on ADC
ADCSRA |=(1<<ADEN);                         // enable ADC
_delay_ms(2);                                 // wait for vref to settle
ADCSRA |= (1<<ADSC);                        // start sampling
while(ADCSRA & (1<<ADSC));                  // wait for sampling to complete
uint16_t vcc = ADC;                           // read sampling result
ADCSRA &= ~(1<<ADEN);                         // disable ADC
PRR    |=(1<<PRADC);                        // power off ADC
vcc = 11253 / vcc;                            // calculate Vcc in dV; 11253 = 1.1*1023*10
return vcc;                                 // divide by 8 and return result
// Rotary Encoder Implementation using Pin Change Interrupt
// Global variables
volatile uint8_tENC_a0, ENC_b0, ENC_ab0;
volatile int16_tENC_count, ENC_countMin, ENC_countMax, ENC_countStep;
// Init rotary encoder
void ENC_init(void) {
pinPullup(PIN_ENC_A);                         // enable pullup on encoder pins ...
pinPullup(PIN_ENC_B);
pinPullup(PIN_ENC_SW);
pinIntEn(PIN_ENC_A);                        // enable pin change interrupt on ENC A
ENC_a0= !pinRead(PIN_ENC_A);                // set initial values ...
ENC_b0= !pinRead(PIN_ENC_B);
ENC_ab0 = (ENC_a0 == ENC_b0);
GIMSK|= (1<<PCIE);                        // enable pin change interrupts
// Set parameters for rotary encoder
void ENC_set(int16_t rmin, int16_t rmax, int16_t rstep, int16_t rvalue) {
ENC_countMin= rmin << 1;                  // min value
ENC_countMax= rmax << 1;                  // max value
ENC_countStep = rstep;                        // count steps (negative if CCW)
ENC_count   = rvalue << 1;                  // actual count value
// reads current rotary encoder value
int ENC_get(void) {
return(ENC_count >> 1);
// Pin change interrupt service routine for rotary encoder
ISR(PCINT0_vect) {
uint8_t a = !pinRead(PIN_ENC_A);
uint8_t b = !pinRead(PIN_ENC_B);
if(a != ENC_a0) {                           // A changed?
    ENC_a0 = a;
    if(b != ENC_b0) {                           // B changed?
      ENC_b0 = b;
      ENC_count += (a == b) ? -ENC_countStep : ENC_countStep;
      if((a == b) != ENC_ab0) ENC_count += (a == b) ? -ENC_countStep : ENC_countStep;
      if(ENC_count < ENC_countMin) ENC_count = ENC_countMin;
      if(ENC_count > ENC_countMax) ENC_count = ENC_countMax;
      ENC_ab0 = (a == b);
// EEPROM Functions
// updates frequency and volume stored in EEPROM
void EEPROM_update() {
eeprom_update_word((uint16_t*)0, EEPROM_IDENT);
eeprom_update_word((uint16_t*)2, RDA_channel);
eeprom_update_byte((uint8_t*)4, volume);
// reads frequency and volume stored in EEPROM
uint8_t EEPROM_get() {
uint16_t identifier = eeprom_read_word((const uint16_t*)0);
if (identifier == EEPROM_IDENT) {
    channel = eeprom_read_word((const uint16_t*)2);
    volume= eeprom_read_byte((const uint8_t*)4);
    return 1;
return 0;
// Main Function
int main(void) {
// Setup
ADC_init();                                 // setup ADC
ENC_init();                                 // setup rotary encoder
sei();                                        // enable global interrupts
// Disable unused peripherals to save power
ACSR =(1<<ACD);                           // disable analog comperator
PRR=(1<<PRADC)                            // shut down ADC
       |(1<<PRUSI)                            // shut down USI
       |(1<<PRTIM0)                           // shut down timer0
       |(1<<PRTIM1);                        // shut down timer1
// Prepare and start OLED
OLED_init();
OLED_clearScreen();
OLED_println(HEADER);
OLED_print(PSTR("Starting ..."));
// Start the tuner
RDA_init();
if(EEPROM_get()) RDA_setChannel(channel);
else RDA_seekUp();
ENC_set(0, 15, 1, volume);
RDA_setVolume(volume);
RDA_waitTuning();
// Loop
while(1) {
    // Update information on OLED
    RDA_updateStatus();
    uint8_t vcc = ADC_readVcc();
    OLED_setCursor(0, 1);
    OLED_print(PSTR("Station:"));
    OLED_printStr(RDA_stationName);
    OLED_clearLine();
    OLED_print(PSTR("Vol: "));
    OLED_printVal(volume);
    OLED_print(PSTR("   Frq: "));
    OLED_printFrequency(RDA_getFrequency());
    OLED_print(PSTR("Sig: "));
    OLED_printVal(RDA_signalStrength);
    OLED_print(PSTR("   Bat: "));
    if(vcc < 32) OLED_println(PSTR("weak"));
    else OLED_println(PSTR("OK"));
    // Check rotary encoder switch for channel seek
    if (!pinRead(PIN_ENC_SW)) {               // seek up if encoder button is pressed
      OLED_println(PSTR("Tuning ..."));
      OLED_clearLine(); OLED_clearLine();
      RDA_seekUp();
      RDA_waitTuning();
      while (!pinRead(PIN_ENC_SW));
      EEPROM_update();
    // Check rotary encoder for volume change
    if (volume != ENC_get()) {                  // change volume if encoder was turned
      volume = ENC_get();
      EEPROM_update();
598330983 发表于 2024-9-28 13:40
低成本RDA5807MP是一款单芯片广播 FM 立体声收音机调谐器,具有完全集成的合成器、IF 选择性、RDS/RBDS 和 MPX 解码器。调谐器采用 CMOS 工艺,支持多接口,需要最少的外部元件。所有这些都使其非常适合便携式设备。
FM 调谐器 IC RDA5807MP 由 ATtiny 通过 I²C 控制。它有 6 个可写的 16 位寄存器(地址 0x02 - 0x07)和 6 个可读的 16 位寄存器(地址 0x0A - 0x0F)。RDA5807 有两种写入访问方法,一种是顺序方法,其中寄存器总是从地址 0x02 开始写入,另一种是索引方法,其中首先传输寄存器地址,然后传输内容。两种方法都由不同的 I²C 地址决定。要传输 16 位寄存器内容,首先发送高字节。RDA5807 是通过设置或清除相应 registers 中的某些 bits 来控制的。各个寄存器的含义的详细信息可以在数据表中找到。当前 register 内容保存在 RDA_regs 数组中。
734774645 发表于 2024-9-28 17:11
IO模拟的,比较通用,学习一下。
wanduzi 发表于 2024-9-29 20:04
85现在是多少钱一片、
wanduzi 发表于 2024-9-29 20:05
查了一下这个芯片竟然好几块,用不起。。。
gejigeji521 发表于 2024-9-30 11:56
下载参靠学习。
单片小菜 发表于 2024-9-30 13:51
这个电路图有源文件吗?
KCCHEN 发表于 2024-10-1 08:24
学习一下
antusheng 发表于 2024-11-24 19:34
这个是真不错。好玩。
页: [1]
查看完整版本: ATtiny85驱动RDA5807的收音机应用
