burgessmaggie 发表于 2024-11-19 11:00
PWM输出蜂鸣器频率变声器
一、工作原理:1.利用STM32的定时器PWM输出通道,驱动蜂鸣器以特定频率发声,实现播放音乐的效果。2.C调音符与频率对照表:https://pic1.zhimg.com/v2-6ab42f141a50a5f9d8bd44f6690f21ba_1440w.jpg3.以下为常用的七声音阶频率(Hz):#define MC 262 Do#define MD 294 Re#define ME 330 Mi#define MF 349 Fa#define MG 392 Sol#define MA 440 La#define MB 494 Si#define MCC 523 Do二、软件设计:1.蜂鸣器GPIO和定时器初始化void PWM_Init_TIM1(u16 Psc,u16 Per){    GPIO_InitTypeDef GPIO_InitStruct;    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;    TIM_OCInitTypeDef TIM_OCInitStruct;            RCC_APB2PeriphClockCmd(PWMA_GPIO_CLK | PWMA_TIMx_CLK,ENABLE);//开启时钟      GPIO_InitStruct.GPIO_Mode=GPIO_Mode_AF_PP;      // 初始化GPIO--PA8、PA11为复用推挽输出    GPIO_InitStruct.GPIO_Pin=PWMA_GPIO_PIN ;    GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;    GPIO_Init(PWMA_GPIO_PORT,&GPIO_InitStruct);    GPIO_ResetBits(PWMA_GPIO_PORT, PWMA_GPIO_PIN);            TIM_TimeBaseStructInit(&TIM_TimeBaseInitStruct);// 初始化定时器。    TIM_TimeBaseInitStruct.TIM_ClockDivision=TIM_CKD_DIV1;    TIM_TimeBaseInitStruct.TIM_CounterMode=TIM_CounterMode_Up;    TIM_TimeBaseInitStruct.TIM_Period=Per; //arr    TIM_TimeBaseInitStruct.TIM_Prescaler=Psc;    TIM_TimeBaseInit(PWMA_TIMx,&TIM_TimeBaseInitStruct);   // TIM1      TIM_OCInitStruct.TIM_OCMode=TIM_OCMode_PWM1;      // 初始化输出比较    TIM_OCInitStruct.TIM_OCPolarity=TIM_OCPolarity_Low;    TIM_OCInitStruct.TIM_OutputState=TIM_OutputState_Enable;    TIM_OCInitStruct.TIM_Pulse=Per/2;    TIM_OC1Init(PWMA_TIMx,&TIM_OCInitStruct);      TIM_OC1PreloadConfig(PWMA_TIMx,TIM_OCPreload_Enable);// OC1预装载寄存器使能    TIM_ARRPreloadConfig(PWMA_TIMx,ENABLE);// TIM1在ARR上预装载寄存器使能    /*Open PWM output*/    TIM_CtrlPWMOutputs(PWMA_TIMx,ENABLE);// 高级定时器专属!!!--MOE主输出使能    TIM_Cmd(PWMA_TIMx,ENABLE);         // 开定时器。    buzzerQuiet();                         //关闭蜂鸣器}
2.控制蜂鸣器发声://compare:比较值void TIM_SetTIM1Compare1(u32 compare){        TIM1->CCR2=compare; } //设置TIM3通道2的arrvoid TIM_SetTIM1Autoreload(u32 Autoreload){        TIM1->ARR=Autoreload;} void buzzerQuiet(void)//停止发声{        buzzerSound(20000, 20);//        TIM1->CCR2=0; //        TIM_CtrlPWMOutputs(PWMA_TIMx,DISABLE);//        TIM_Cmd(PWMA_TIMx,DISABLE);         }void buzzerOpen(void)//发声{                TIM_CtrlPWMOutputs(PWMA_TIMx,ENABLE);        TIM_Cmd(PWMA_TIMx,ENABLE);             } void buzzerSound(unsigned short usFraq,unsigned char volume_level)//发声模块{        unsigned long Autoreload;                buzzerOpen();                if((usFraq<=122)||(usFraq>20000))        {                buzzerQuiet();        }        else        {                Autoreload=(8000000/usFraq)-1;                 TIM_SetTIM1Autoreload(Autoreload);                TIM_SetTIM1Compare1(Autoreload>>volume_level);         }}
3.频率对照表宏定义:#defineLC                 262#defineLD                 294#defineLE                 330#defineLF                 349#defineLG                 392#defineLA                 440#defineLAP_LBN        466#defineLB                 494#defineMC                        523#defineMD                        587#defineME                        659#defineMEP                740#defineMF                        698#defineMG                        784#defineMA                        880#defineMAP_MBN        932#defineMB                        988#defineHC                        1046#defineHD                        1175#defineHE                        1318#defineHF                        1397#defineHG                        1568#defineHA                        1760#defineHB                        1976
4.播放音乐(爱的罗曼史):uint16_t romance={        ME,ME,ME, ME,MD,MC, MC,LB,LA, LA,MC,ME, MA,MA,MA,        MA,MG,MD, MF,ME,MD, MD,ME,MF, ME,MF,ME, MEP,MF,ME,        ME,MD,MC, MC,LB,LA, LB,LB,LB, LB,MC,LB, LA,LA,LA, LA,20000,20000,        ME,ME,ME, ME,MD,MC, MC,LB,LB, LB,LAP_LBN,LB, MA,MA,MA,        MA,MB,MA, MA,MG,MG, MG,MA,MB, HC,HC,HC, HC,MB,MAP_MBN,        MA,MA,MA, MA,ME,MD, ME,ME,ME, ME,MF,MD, MC,MC,MC, MC,20000,20000}; void Romance(void){        uint16_t i=0;        for(i=0; i<96; i++)        {                buzzerSound(romance, 200);                delay_ms(150);                buzzerQuiet();                delay_ms(150);        }        buzzerQuiet();        delay_ms(500);}
页: [1]
查看完整版本: PWM输出蜂鸣器频率变声器
