stm32血压计的设计
来一套stm32血压计的设计,使用示波法测量,下降趋势。测量周期为20s内,最好能够输出测量的波形可以在外包板块找
stm32血压计的设计
#include "stm32f4xx.h" // Device header#include "Handlers.h"
#include "LCDHD44780NonBlocking.h"
#include "BloodPressureMeterFunctions.h"
#include "PressureSensorABPMANN005PG2A3.h"
#include "FIRbandpass_3_10_Hz_Coeff.h"
#include "FIRfilterPtByPt.h"
#include "IIRfilterPtByPt.h"
Formula for pressure calculation:
pressure = ((Output - 1638) * 5)/(14745 - 1638)
1 psi = 51.7149326 mmHg
3.480619445 psi = 180 mmHg
10762 = 180 mmHg
//===Instances of structures and pointers to structures===//
pulseWave__pulseWave;
pulseWave_* pulseWave = &_pulseWave;
FIRfilterObject _BandpassFIRfilter;
FIRfilterObject* BandpassFIRfilter = &_BandpassFIRfilter;
IIR4thOrderFilterObj _LowpassIIRfilter;
IIR4thOrderFilterObj* LowpassIIRfilter = &_LowpassIIRfilter;
//=== Extern variables enabling calculations and display===//
extern volatile uint8_t calculate;
extern volatile uint8_t displayOnLCDevery1sec;
extern volatile uint8_t displayOnLCDevery250milisec;
//===========FIR filter coefficients===========//
extern float FIRbandpass_3_10_Hz_Coeff;
//==== Circular buffers to pass into FIRfilterObject ===//
float signalBufferForBandpassFIRfilter;
int main()
RCCClockConfiguration();
/* FPU initialization */
SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2));/* set CP10 and CP11 Full Access */
PumpValveButtonConfiguration();
LCDInitialize();
TimersInitialization();
LCDLocateXY(0,0);
LCDSendText("Put cuff on arm ");
LCDLocateXY(0,1);
LCDSendText("pressbutton ");
PressureSensorInitialize();
//====== Initialization of pointers ======//
float LPFiltered;
float BPFiltered;
float* lowPassFiltered;
float* bandPassFiltered;
lowPassFiltered = &LPFiltered;
bandPassFiltered = &BPFiltered;
volatile float previousValue, derivative, previousDerivative; // Variables for determining change of 1st derivative sign of lowpass filtered output
volatile float previousValueBP, derivativeBP, previousDerivativeBP;// Variables for determining change of 1st derivative sign of bandpass filtered output
_BandpassFIRfilter = CreateFIRfilterObject(256, signalBufferForBandpassFIRfilter, 166, FIRbandpass_3_10_Hz_Coeff);
_LowpassIIRfilter = IIR_4thOrderSignalFilteringPtByPtInitialize(IIRforwardCoeffLowpass_20Hz, IIRreverseCoeffLowpass_20Hz);
unsigned int BPfilterDelay = (unsigned int) (_BandpassFIRfilter.coefficientsLength - 1) / 2; //Length of bandpass FIR filter group delay
volatile uint8_t displayHeart = 0; //Variable controlling display of heart character on LCD
volatile uint8_t clearHeart = 0; //Variable controlling clear of heart character on LCD
volatile uint8_t calculateMAP = 0; //Variable controlling start of MAP evaluation
while(1)
if(calculate)
if( pressureArrayHead != pressureArrayTail)
//======================= Filtration of data from pressure sensor ========================//
IIR_4thOrderSignalFilteringPtByPt(LowpassIIRfilter, pressureArray, lowPassFiltered);
FIRfilterPtByPt(BandpassFIRfilter, pressureArray, bandPassFiltered);
//=======================Update of buffers and variables values========================//
pulseWave->currentPressure = ((*lowPassFiltered- 1638.0f) * 5.0f) / (14745.0f - 1638.0f) * 52.0f;
pulseWave->numberOfSamples++;
Last128SamplesBufferHead = (Last128SamplesBufferHead+1) & 127;
Last128SamplesBuffer = *lowPassFiltered;
pressureArrayTail = (pressureArrayTail + 1) & pressureArrayMask;
//=======New derivative value calculation=======//
derivative = *lowPassFiltered - previousValue;
derivativeBP = *bandPassFiltered - previousValueBP;
//====================== Peak detection ======================//
if( ((derivative * previousDerivative) < 0) && ((derivative - previousDerivative) < 0) )
if((pulseWave->numberOfSamples - pulseWave->previousPeakXcoordinate ) > 64)// if two Peaks distance > approximate 250 ms
displayHeart = 1;
pulseWave->previousPeakXcoordinate = pulseWave->numberOfSamples;
if( ! pulseWave->systolicPressure )
calculateMAP = 1; // if Systolic peak detected start evaluating MAP
pulseWave->systolicPressure = pulseWave->currentPressure;
//======================== MAP calculation =========================//
if( calculateMAP )
if( ((derivativeBP * previousDerivativeBP) < 0) && ((derivativeBP - previousDerivativeBP) < 0) )
if( *bandPassFiltered > pulseWave->workingMAPpressure )
pulseWave->MAPpressure = ((Last128SamplesBuffer[(Last128SamplesBufferHead - BPfilterDelay) & 127] - 1638.0f) * 5.0f) / (14745.0f - 1638.0f) * 52.0f;
pulseWave->workingMAPpressure = *bandPassFiltered;
//============Variables update=============//
previousDerivative = derivative;
previousValue = *lowPassFiltered;
previousDerivativeBP = derivativeBP;
previousValueBP = *bandPassFiltered;
//============Ending calculations==============//
if( pulseWave->currentPressure < 50 )
LCDLocateXY(0,0);
LCDSendText("SYS:");
LCDLocateXY(7,0);
LCDSendData(' ');
LCDLocateXY(8,0);
LCDSendText("DIA:");
calculate = 0;
calculateMAP = 0;
TIM4->CR1 &= ~TIM_CR1_CEN;// Turn off Timer controlling displaying on LCD
displayOnLCDevery1sec = 0;
displayOnLCDevery250milisec = 0;
pulseWave->diastolicPressure = ( pulseWave->MAPpressure * 3 - pulseWave->systolicPressure ) / 2 ;
LCDLocateXY(4,0);
LCDSend8bitInteger((uint8_t) pulseWave->systolicPressure);
LCDLocateXY(12,0);
LCDSend8bitInteger((uint8_t) pulseWave->diastolicPressure);
LCDLocateXY(0,1);
LCDSendText("MAP:");
LCDLocateXY(6,1);
LCDSend8bitInteger((uint8_t) pulseWave->MAPpressure);
LCDLocateXY(12,1);
LCDSendText(" ");
else
previousDerivative = *lowPassFiltered - previousValue;
previousDerivativeBP = *bandPassFiltered - previousValueBP;
if(displayOnLCDevery250milisec)
if(clearHeart)
LCDLocateXY(8,0);
LCDSendData(' ');
clearHeart = 0;
if(displayHeart)
LCDLocateXY(8,0);
LCDSendData(heart);
displayHeart = 0;
clearHeart = 1;
if(displayOnLCDevery1sec)
LCDLocateXY(12,1);
LCDSend8bitInteger((uint8_t) pulseWave->currentPressure);
stm32血压计的设计
硬件和原理图,私信我。 这个测量的准确度怎么样
页:
[1]
