qweasda 发表于 2024-12-9 16:41
HC32L110 LPUART不进接收中断
基本按照例程写的 ,只把模式三改成了模式一,是还需要改其他地方的配置么
void LPRxIntCallback(void)
    u8RxData=M0P_LPUART->SBUF;
                u8LpRx** = 1;
void LPErrIntCallback(void)
void LPUART_Init(void)
                uint16_t u16timer = 0;
    uint32_t u32sclk = 0;
    stc_lpuart_config_tstcConfig;
    stc_lpuart_irq_cb_t stcLPUartIrqCb;
    stc_lpuart_multimode_t stcMulti;
    stc_lpuart_sclk_sel_tstcLpuart_clk;
    stc_lpuart_mode_t       stcRunMode;
    stc_lpuart_baud_config_tstcBaud;
    stc_bt_config_t stcBtConfig;
    DDL_ZERO_STRUCT(stcConfig);
    DDL_ZERO_STRUCT(stcLPUartIrqCb);
    DDL_ZERO_STRUCT(stcMulti);
    DDL_ZERO_STRUCT(stcBtConfig);
    Clk_SetPeripheralGate(ClkPeripheralLpUart,TRUE);
    Clk_SetPeripheralGate(ClkPeripheralBt,TRUE);
    Gpio_InitIOExt(2,5,GpioDirOut,TRUE,FALSE,FALSE,FALSE);
    Gpio_InitIOExt(2,6,GpioDirOut,TRUE,FALSE,FALSE,FALSE);
    Gpio_SetFunc_UART2RX_P25();
    Gpio_SetFunc_UART2TX_P26();
    stcLpuart_clk.enSclk_sel = LPUart_Pclk;
    stcLpuart_clk.enSclk_Prs = LPUartDiv1;
    stcConfig.pstcLpuart_clk = &stcLpuart_clk;
    stcRunMode.enLpMode = LPUartNoLPMode;
    stcRunMode.enMode   = LPUartMode1;
    stcConfig.pstcRunMode = &stcRunMode;
    stcLPUartIrqCb.pfnRxIrqCb = LPRxIntCallback;
    stcLPUartIrqCb.pfnTxIrqCb = NULL;
    stcLPUartIrqCb.pfnRxErrIrqCb = LPErrIntCallback;
    stcConfig.pstcIrqCb = &stcLPUartIrqCb;
    stcConfig.bTouchNvic = TRUE;
    stcMulti.enMulti_mode = LPUartNormal;
    stcConfig.pstcMultiMode = &stcMulti;
    LPUart_EnableIrq(LPUartRxIrq);
    LPUart_Init(&stcConfig);
    if(LPUart_Pclk == stcLpuart_clk.enSclk_sel)
      u32sclk = Clk_GetPClkFreq();
    else if(LPUart_Rcl == stcLpuart_clk.enSclk_sel)
      u32sclk = 38400;
    else
      u32sclk = 32768;
    stcBaud.u32Baud = 9600;
    stcBaud.bDbaud = 0;
    stcBaud.u8LpMode = LPUartNoLPMode;
    stcBaud.u8Mode = LPUartMode1;
    u16timer = LPUart_SetBaudRate(u32sclk,stcLpuart_clk.enSclk_Prs,&stcBaud);
    stcBtConfig.enMD = BtMode2;
    stcBtConfig.enCT = BtTimer;
    stcBtConfig.enTog = BtTogEnable;
    Bt_Init(TIM2, &stcBtConfig);
    Bt_ARRSet(TIM2,u16timer);
    Bt_Cnt16Set(TIM2,u16timer);
    Bt_Run(TIM2);
    LPUart_EnableFunc(LPUartRx);
主函数写的这一段,串口1是可以正常收发数据的
if(u8LpRx**)
      Gpio_SetIO(0,2,led_flagR);
      Uart_SendData(UARTCH1,u8RxData);
yang377156216 发表于 2024-12-11 11:14
一点点改,看哪一步改出问题的吧,可以缩小下范围
classroom 发表于 2024-12-11 17:01
检查外部电路
laocuo1142 发表于 2024-12-11 19:00
确认LPUART的时钟配置正确,包括PCLK和SCLK的时钟源和预分频设置。
检查LPUART的控制寄存器(如LPUART_SCON)的配置,确保波特率、字符长度、停止位和校验位等参数设置正确。
powerantone 发表于 2024-12-11 19:00
波特率设置不正确
flycamelaaa 发表于 2024-12-11 20:00
检查驱动程序中是否有关于LPUART接收中断的错误处理或配置不当。
powerantone 发表于 2024-12-12 17:00
检查是否有其他代码(如printf等)干扰了串口的接收过程。
wang6623 发表于 2025-4-30 22:37
你需要确认你的时钟源和频率配置是准确的,尤其是 LPUart_Pclk 和 LPUartDiv1,这些会影响到波特率的精度。
页: [1]
查看完整版本: HC32L110 LPUART不进接收中断
