CW32L010F8P6电源测量和温度测量问题?
以下是ADC相关初始化代码,得到的电源电压不准确,有时候是3.6V,有时候是3.3V,有时候是1.6V,我是标准3.3V供电的。这个电压不准确,内部温度也就不准确了。是不是初始化有什么问题?/*
描述 : ADC初始化
输入 :
输出 :
void app_smoke_adc_init(void)
ADC_InitTypeDef ADC_InitStructure = {0};
__SYSCTRL_GPIOB_CLK_ENABLE();
PB02_ANALOG_ENABLE();
ADC_InitStructure.ADC_ClkDiv = ADC_Clk_Div8;
ADC_InitStructure.ADC_ConvertMode = ADC_ConvertMode_Continuous;
ADC_InitStructure.ADC_IN0.ADC_InputChannel = ADC_InputCH9;
ADC_InitStructure.ADC_IN0.ADC_SampTime = ADC_SampTime390Clk;//烟雾浓度
ADC_InitStructure.ADC_IN1.ADC_InputChannel = ADC_InputTs;
ADC_InitStructure.ADC_IN1.ADC_SampTime = ADC_SampTime390Clk;//内部温度
ADC_InitStructure.ADC_IN2.ADC_InputChannel = ADC_InputVref1P2;
ADC_InitStructure.ADC_IN2.ADC_SampTime = ADC_SampTime390Clk; //1.2V基准电压
ADC_InitStructure.ADC_SQREns = ADC_SqrEns0to2;
ADC_Init(&ADC_InitStructure);
REGBITS_SET(CW_ADC->CR, ADC_CR_BGREN_Msk);//使能BGR
ADC_SetTs(ADC_TsEnable);//使能内部温度
//ADC使能
ADC_Enable();
ADC_SoftwareStartConvCmd(ENABLE);
//g_sAppSmokeWork.adc_flag=true;
描述 : ADC检测转换
输入 :
输出 :
void app_smoke_adc_check(void)
//static u16 run_cnts=0;
//if(g_sAppSmokeWork.adc_flag && run_cnts++>500)
u16 adc_array={0};
// ADC_SoftwareStartConvCmd(DISABLE);
ADC_GetSqr0Result(&adc_array);
ADC_GetSqr1Result(&adc_array);
ADC_GetSqr2Result(&adc_array);
// run_cnts=0;
g_sAppSmokeWork.adc_flag=false;
for(u8 i=0; i<3; i++)
printf("adc_%d=%d\n", i, adc_array);
//电源电压计算
u16 volt_bgr=*((uint16_t*)0x001007D2);//基准电压值
float volt_vcc=volt_bgr*4095.f/adc_array/1000;
printf("volt_bgr=%.3fV, volt_vcc=%.3fV\n", volt_bgr/1000.f, volt_vcc);
//温度计算
float temp_val=ADC_GetTs(volt_vcc, adc_array);
printf("temp_val=%.1f C\n", temp_val);
串口调试内容
adc_0=0
adc_1=912
adc_2=3062
volt_bgr=1.199V, volt_vcc=1.603V
temp_val=-129.9 C
now_rtc_time=1624237630s
now_rtc_time=1624237635s
adc_0=0
adc_1=913
adc_2=3064
volt_bgr=1.199V, volt_vcc=1.602V
temp_val=-129.9 C
ADC初始化代码没有问题,但adc_2的值明显偏大,其真实值大约为15xx。
建议更新固件库,再debug一下,确定问 ...
昨天adc_2的值大概1300左右,算出来3.6V左右;后面重新插拔一下 1400左右,算出来3.3V左右;今天早上再测试下,变成1.6V了{:sad:} 本帖最后由 ypp240124016 于 2024-12-16 16:22 编辑
固件库最新版本是 哪个,我现在用的如下/**
* @file cw32l010_adc.c
* @author WHXY
* @brief
* @version 0.1
* @author WHXY
* @brief
* @version 0.1
* @date 2024-08-07
* @copyright Copyright (c) 2021
整个固件库好像是最新的了
CW32L010_StandardPeripheralLib_V1.0.3
用购买的核心板测试没有问题,代码一样,可以测出电压3.3V左右。自己布的板就时好时坏,按道理这也跟外围没多大关系吧,都是内部测量? ypp240124016 发表于 2024-12-16 17:08
用购买的核心板测试没有问题,代码一样,可以测出电压3.3V左右。自己布的板就时好时坏,按道理这也跟外 ...
请检查电源是否稳定?注意Vcore的电容值需1uF。 pssyx 发表于 2024-12-16 17:27
我用官方DAP 电源直接供电,应该问题不大。Vcore按照官方的470nF ypp240124016 发表于 2024-12-16 19:10
CW-DAPLINK内部使用了一个117(LDO),输出3.3V,再经过一个肖特基二极管,最终输出VDD电压约3.1V。
如果 ...
找到原因了,DAP的串口TX引脚是5V电平的,我直接跟MCU的RX连接了,干扰电源了,拔掉就正常了。 如果要用那个引脚的话需要串联电阻。 ADC_CR_BGREN_Msk 置一后后不需要等待稳定一会儿吗?
不建议这种直接排队ADC转换。你看看MCU有没有一个多余的ADC输入引脚。把多余引脚接地。然后在队列中加入对该引脚的转换。加在每个真正要ADC的转换之前,转换结果丢弃。信号源内阻为零采样时间可以减小些。
数据手册?用户手册? data:image/png;base64,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
xch 发表于 2024-12-17 17:36
感谢{:handshake:} 校准过了吗? 是不是内部基准的问题
页:
[1]
