【AT-START-L021测评】硬件I2C/IIC 驱动OLED
先看效果:首先进行OLED初始化:
void OLED_Init(void)
delay_ms(1000);
WriteCmd(0xAE);//--turn off oled panel
WriteCmd(0x00);//---set low column address
WriteCmd(0x10);//---set high column address
WriteCmd(0x40);//--set start line addressSet Mapping RAM Display Start Line (0x00~0x3F)
WriteCmd(0x81);//--set contrast control register
WriteCmd(0xCF);// Set SEG Output Current Brightness
WriteCmd(0xA1);//--Set SEG/Column Mapping 0xa0���ҷ��� 0xa1����
WriteCmd(0xC8);//Set COM/Row Scan Direction 0xc0���·��� 0xc8����
WriteCmd(0xA6);//--set normal display
WriteCmd(0xA8);//--set multiplex ratio(1 to 64)
WriteCmd(0x3f);//--1/64 duty
WriteCmd(0xD3);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)
WriteCmd(0x00);//-not offset
WriteCmd(0xd5);//--set display clock divide ratio/oscillator frequency
WriteCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
WriteCmd(0xD9);//--set pre-charge period
WriteCmd(0xF1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
WriteCmd(0xDA);//--set com pins hardware configuration
WriteCmd(0x12);
WriteCmd(0xDB);//--set vcomh
WriteCmd(0x40);//Set VCOM Deselect Level
WriteCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
WriteCmd(0x02);//
WriteCmd(0x8D);//--set Charge Pump enable/disable
WriteCmd(0x14);//--set(0x10) disable
WriteCmd(0xA4);// Disable Entire Display On (0xa4/0xa5)
WriteCmd(0xA6);// Disable Inverse Display On (0xa6/a7)
OLED_Clear();
WriteCmd(0xAF); //Set display on added by sensoryoung
delay_ms(200);
然后刷新屏幕:
void OLED_Refresh(void)
uint8_t i,n;
for(i=0;i<8;i++)
WriteCmd(0xb0+i);
WriteCmd(0x00);
WriteCmd(0x10);
for(n=0;n<128;n++)
WriteDat(OLED_GRAM);
}这里有关键的两个函数:WriteCmd 与 WriteDat。实现如下:
Prototype : void WriteCmd(uint8_t IIC_Command)
Parameters : IIC_Command
return : none
Description : 写命令(通过HAL_I2C_WriteByte中的HAL_I2C_Master_Transmit
向0x00写入命令)
HAL_I2C_WriteByte(0x00, IIC_Command);
Prototype : void WriteDat(uint8_t IIC_Data)
Parameters : IIC_Data
return : none
Description : 写数据(通过HAL_I2C_WriteByte中的HAL_I2C_Master_Transmit
向0x40写入数据)
HAL_I2C_WriteByte(0x40, IIC_Data);
在调用I2C模块向总线发送数据之前,封装了一下:
I2C总线传出数据函数:
addr: 要写入的地址(OLED的地址一般为0x40;指令地址为0x00)
data: 要写入的数据
void HAL_I2C_WriteByte(uint8_t addr,uint8_t data)
//uint8_t TxData = {addr,data};
uint8_t TxData;
TxData = addr;
TxData = data;
if((i2c_status = i2c_master_transmit(&hi2cx, 0X78, TxData, 2, I2C_TIMEOUT)) != I2C_OK)
error_handler(i2c_status);
}实际效果还不错,完整代码如下:
/*Reference: https://blog.csdn.net/Reasally/article/details/126789505*/
#include "oled.h"
#include "stdlib.h"
#include "oledfont.h"
//For ARTEY ATL021
extern void error_handler(uint32_t error_code);
extern i2c_handle_type hi2cx;
extern i2c_status_type i2c_status;
#define I2C_TIMEOUT 0xFFFFFFF
uint8_t OLED_GRAM;
//���Ժ���
void OLED_ColorTurn(uint8_t i)
if(i==0)
WriteCmd(0xA6);
if(i==1)
WriteCmd(0xA7);
//��Ļ��ת180��
void OLED_DisplayTurn(uint8_t i)
if(i==0)
WriteCmd(0xC8);
WriteCmd(0xA1);
if(i==1)
WriteCmd(0xC0);
WriteCmd(0xA0);
//��ʱ
void IIC_delay(void)
uint16_t t=300;
while(t--);
I2C总线传出数据函数:
data: 要写入的数据
uint8_t TxData;
TxData = addr;
TxData = data;
return : none
向0x00写入命令)
return : none
向0x40写入数据)
//����һ���ֽ�
//mode:����/�����־ 0,��ʾ����;1,��ʾ����;
void OLED_WR_Byte(uint8_t dat,uint8_t mode)
if(mode){
//Send_Byte(0x40);
WriteDat(dat);
else{
//Send_Byte(0x00);
WriteCmd(dat);
//Send_Byte(dat);
//I2C_Stop();
//����OLED��ʾ
void OLED_DisPlay_On(void)
WriteCmd(0x8D);
WriteCmd(0x14);
WriteCmd(0xAF);
//�ر�OLED��ʾ
void OLED_DisPlay_Off(void)
WriteCmd(0x8D);
WriteCmd(0x10);
WriteCmd(0xAE);
//�����Դ浽OLED
uint8_t i,n;
for(i=0;i<8;i++)
WriteCmd(0xb0+i);
WriteCmd(0x00);
WriteCmd(0x10);
for(n=0;n<128;n++)
void OLED_Clear(void)
uint8_t i,n;
for(i=0;i<8;i++)
for(n=0;n<128;n++)
OLED_GRAM=0;//�����������
//x:0~127
//y:0~63
//t:1 ��� 0,���
void OLED_DrawPoint(uint8_t x,uint8_t y,uint8_t t)
uint8_t i,m,n;
i=y/8;
m=y%8;
n=1<<m;
if(t){OLED_GRAM|=n;}
else
OLED_GRAM=~OLED_GRAM;
OLED_GRAM|=n;
//x1,y1:�������
//x2,y2:��������
void OLED_DrawLine(uint8_t x1,uint8_t y1,uint8_t x2,uint8_t y2,uint8_t mode)
uint16_t t;
int xerr=0,yerr=0,delta_x,delta_y,distance;
int incx,incy,uRow,uCol;
delta_x=x2-x1; //������������
delta_y=y2-y1;
uRow=x1;//�����������
uCol=y1;
if(delta_x>0)incx=1; //���õ�������
else if (delta_x==0)incx=0;//��ֱ��
else {incx=-1;delta_x=-delta_x;}
if(delta_y>0)incy=1;
else if (delta_y==0)incy=0;//ˮƽ��
else {incy=-1;delta_y=-delta_x;}
if(delta_x>delta_y)distance=delta_x; //ѡȡ��������������
else distance=delta_y;
for(t=0;t<distance+1;t++)
OLED_DrawPoint(uRow,uCol,mode);//����
xerr+=delta_x;
yerr+=delta_y;
if(xerr>distance)
xerr-=distance;
uRow+=incx;
if(yerr>distance)
yerr-=distance;
uCol+=incy;
//x,y:Բ������
//r:Բ�İ뾶
void OLED_DrawCircle(uint8_t x,uint8_t y,uint8_t r)
int a, b,num;
a = 0;
b = r;
while(2 * b * b >= r * r)
OLED_DrawPoint(x + a, y - b,1);
OLED_DrawPoint(x - a, y - b,1);
OLED_DrawPoint(x - a, y + b,1);
OLED_DrawPoint(x + a, y + b,1);
OLED_DrawPoint(x + b, y + a,1);
OLED_DrawPoint(x + b, y - a,1);
OLED_DrawPoint(x - b, y - a,1);
OLED_DrawPoint(x - b, y + a,1);
a++;
num = (a * a + b * b) - r*r;//���㻭�ĵ���Բ�ĵľ���
if(num > 0)
b--;
a--;
//��ָ��λ����ʾһ���ַ�,���������ַ�
//x:0~127
//y:0~63
//size1:ѡ������ 6x8/6x12/8x16/12x24
//mode:0,��ɫ��ʾ;1,������ʾ
void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t size1,uint8_t mode)
uint8_t i,m,temp,size2,chr1;
uint8_t x0=x,y0=y;
if(size1==8)size2=6;
else size2=(size1/8+((size1%8)?1:0))*(size1/2);//�õ�����һ���ַ���Ӧ������ռ���ֽ���
chr1=chr-' ';//����ƫ�ƺ��ֵ
for(i=0;i<size2;i++)
if(size1==8)
{temp=asc2_0806;} //����0806����
else if(size1==12)
{temp=asc2_1206;} //����1206����
else if(size1==16)
{temp=asc2_1608;} //����1608����
else if(size1==24)
{temp=asc2_2412;} //����2412����
else return;
for(m=0;m<8;m++)
if(temp&0x01)OLED_DrawPoint(x,y,mode);
else OLED_DrawPoint(x,y,!mode);
temp>>=1;
y++;
x++;
if((size1!=8)&&((x-x0)==size1/2))
{x=x0;y0=y0+8;}
y=y0;
//��ʾ�ַ���
//x,y:�������
//size1:�����С
//*chr:�ַ�����ʼ��ַ
void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t size1,uint8_t mode)
while((*chr>=' ')&&(*chr<='~'))//�ж��Dz��ǷǷ��ַ�!
OLED_ShowChar(x,y,*chr,size1,mode);
if(size1==8)x+=6;
else x+=size1/2;
chr++;
//m^n
uint32_t OLED_Pow(uint8_t m,uint8_t n)
uint32_t result=1;
while(n--)
result*=m;
return result;
//��ʾ����
//x,y :�������
//num :Ҫ��ʾ������
//len :���ֵ�λ��
//size:�����С
void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size1,uint8_t mode)
uint8_t t,temp,m=0;
if(size1==8)m=2;
for(t=0;t<len;t++)
temp=(num/OLED_Pow(10,len-t-1))%10;
if(temp==0)
OLED_ShowChar(x+(size1/2+m)*t,y,'0',size1,mode);
else
OLED_ShowChar(x+(size1/2+m)*t,y,temp+'0',size1,mode);
//��ʾ����
//x,y:�������
//num:���ֶ�Ӧ�����
void OLED_ShowChinese(uint8_t x,uint8_t y,uint8_t num,uint8_t size1,uint8_t mode)
uint8_t m,temp;
uint8_t x0=x,y0=y;
uint16_t i,size3=(size1/8+((size1%8)?1:0))*size1;//�õ�����һ���ַ���Ӧ������ռ���ֽ���
for(i=0;i<size3;i++)
if(size1==16)
{temp=Hzk1;}//����16*16����
else if(size1==24)
{temp=Hzk2;}//����24*24����
else if(size1==32)
{temp=Hzk3;}//����32*32����
else if(size1==64)
{temp=Hzk4;}//����64*64����
else return;
for(m=0;m<8;m++)
temp>>=1;
y++;
x++;
if((x-x0)==size1)
{x=x0;y0=y0+8;}
y=y0;
//num ��ʾ���ֵĸ���
//space ÿһ����ʾ�ļ��
void OLED_ScrollDisplay(uint8_t num,uint8_t space,uint8_t mode)
uint8_t i,n,t=0,m=0,r;
while(1)
if(m==0)
OLED_ShowChinese(128,24,t,16,mode); //д��һ�����ֱ�����OLED_GRAM[][]������
t++;
if(t==num)
for(r=0;r<16*space;r++) //��ʾ���
for(i=1;i<144;i++)
for(n=0;n<8;n++)
OLED_GRAM=OLED_GRAM;
OLED_Refresh();
t=0;
m++;
if(m==16){m=0;}
for(i=1;i<144;i++) //ʵ������
for(n=0;n<8;n++)
OLED_Refresh();
//x,y���������
//sizex,sizey,ͼƬ����
//BMP[]��Ҫд���ͼƬ����
void OLED_ShowPicture(uint8_t x,uint8_t y,uint8_t sizex,uint8_t sizey,uint8_t BMP[],uint8_t mode)
uint16_t j=0;
uint8_t i,n,temp,m;
uint8_t x0=x,y0=y;
sizey=sizey/8+((sizey%8)?1:0);
for(n=0;n<sizey;n++)
for(i=0;i<sizex;i++)
temp=BMP;
j++;
for(m=0;m<8;m++)
temp>>=1;
y++;
x++;
if((x-x0)==sizex)
x=x0;
y0=y0+8;
y=y0;
//OLED�ij�ʼ��
delay_ms(1000);
WriteCmd(0x12);
WriteCmd(0x02);//
OLED_Clear();
delay_ms(200);
页:
[1]
