huaimengzi 发表于 2024-12-26 18:38
GD32E230上电复位后,立马进入发送中断
   想写一个串口通信,利用串口收发中断来写,非DMA,发现上电按复位键调试,串口立马进入中断发送,是什么原因呢?求大家帮助指点一下
实验现象,上电即发送7,代码如下:
1. 串口GPIO初始化
static void Com0_Gpio_Init(void)
    /* enable COM GPIO clock */
    rcu_periph_clock_enable(BSP_USART0_PORT_RCU);
          /* connect port to USARTx_Tx */
    gpio_af_set(BSP_USART0_PORT, BSP_USART0_AF, BSP_USART0_TX_PIN);
    /* connect port to USARTx_Rx */
    gpio_af_set(BSP_USART0_PORT, BSP_USART0_AF, BSP_USART0_RX_PIN);
    /* configure USART Tx as alternate function push-pull */
    gpio_mode_set(BSP_USART0_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, BSP_USART0_TX_PIN);
    gpio_output_options_set(BSP_USART0_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, BSP_USART0_TX_PIN);
    /* configure USART Rx as alternate function push-pull */
    gpio_mode_set(BSP_USART0_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, BSP_USART0_RX_PIN);
    gpio_output_options_set(BSP_USART0_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, BSP_USART0_RX_PIN);
                /*5.配置RS485的Enable引脚*/
                rcu_periph_clock_enable(BSP_RS485EN0_RCU);                                                   //开启时钟
                gpio_mode_set(BSP_RS485EN0_PORT, GPIO_MODE_OUTPUT, GPIO_PUPD_PULLUP, BSP_RS485EN0_PIN);      //输出,上拉
                gpio_output_options_set(BSP_RS485EN0_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, BSP_RS485EN0_PIN);//配置为推挽输出
}2. USART0 配置初始化
static void Com0_Usart0_Init(uint32_t BaudRate)
    /* enable USART clock */
    rcu_periph_clock_enable(BSP_USART0_RCU);
    /* USART configure */
                usart_deinit(BSP_USART0);                                     //复位串口
                usart_baudrate_set(BSP_USART0, BaudRate);                     //设置波特率
                usart_parity_config(BSP_USART0,USART_PM_NONE);                //设置无校验
                usart_word_length_set(BSP_USART0,USART_WL_8BIT);            //配置数据位的长度8
                usart_stop_bit_set(BSP_USART0, USART_STB_1BIT);               //停止位1位
                usart_hardware_flow_rts_config(BSP_USART0, USART_RTS_DISABLE);//RTS流控关闭
                usart_hardware_flow_cts_config(BSP_USART0, USART_CTS_DISABLE);//CTS流控关闭
          /*打开RX,TX及串口的开关*/
                usart_transmit_config(BSP_USART0,USART_TRANSMIT_ENABLE);      //使能发送
                usart_receive_config(BSP_USART0, USART_RECEIVE_ENABLE);       //使能接收
                DIR_RX0;        //5.2 作为从机,初始状态设置为等待接收状态
                usart_enable(BSP_USART0);        //使能串口
          /* USART interrupt configuration */
                nvic_irq_enable(BSP_USART0_IRQn,0U);                        //在内核中打开串口及配置中断优先级
    usart_interrupt_enable(BSP_USART0, USART_INT_RBNE);         //读数据缓冲区非空中断和过载错误中断
          usart_interrupt_enable(BSP_USART0,USART_INT_TBE);         //发送缓冲区空中断
                /*6.把结构体进行初始化*/
                UART0.m_ReceiveBytes = 0;
                UART0.m_SendBytes = 0;
                UART0.ComInterruptFlag = 0;
                UART0.g_NoticeTimeOutCounterStartFlag = 0;
                UART0.g_TimeOutCounter = 0;
                UART0.g_RecTimeOverFlag = 0;
                UART0.p_RecBuff= (uint8_t *)UART0.RecBuff;   //将发送数据指针指向发送缓冲区头
                UART0.p_SendBuff = (uint8_t *)UART0.SendBuff;    //将接收数据指针指向接收缓存区头
}3. USART0中断服务函数   接收中断,发送中断
void USART0_IRQHandler(void)
                  if(usart_interrupt_flag_get(BSP_USART0, USART_INT_FLAG_RBNE) != RESET)    //接收缓冲区非空中断,表示里面有数据了
                                        led_setup(LED2,ON);
                                        data = usart_data_receive(BSP_USART0);   //将接收到的字节存储到缓冲区
                                        if(usart_interrupt_flag_get(BSP_USART0, USART_INT_FLAG_TBE)!= RESET)//发送缓冲区空中断
                                        usart_interrupt_flag_clear(BSP_USART0, USART_INT_FLAG_TBE);       //清除发送中断标志
                                  led_setup(LED3,ON);
                                        usart_data_transmit(BSP_USART0, 7);      //将数据写入USART_DR进行发送
4. 调试上电复位后,立马收到数字7
pidalu 发表于 2024-12-26 19:08
你开启了TXE中断,刚上电的时候,TX数据寄存器应该就是空的,那可不就是立即进入了TXE中断一次了嘛。
huaimengzi 发表于 2024-12-26 19:17
我中断接收如果是这样写,上电复位后 TX发给串口上百行乱码,是什么原因呢?
                                  led_setup(LED3,ON);
                                        // 3.1 如果还有待发送数据,则逐一发送出去
                                        if( --UART0.m_SendBytes> 0 )
                                                  led_setup(LED4,ON);
        usart_data_transmit(BSP_USART0, *(++UART0.p_SendBuff));      //将数据写入USART_DR进行发送
                                        else   //发送缓冲区字节数为0,即缓冲区空
                                               DIR_RX0;
Amazingxixixi 发表于 2024-12-27 11:11
直接协议处理
elephant00 发表于 2025-1-25 15:33
如果在USART的初始化过程中,错误地配置了中断使能位,例如使能了不必要的发送或接收中断,那么在复位后,MCU可能会因为这些配置错误而立即进入中断。
两只袜子 发表于 2025-1-25 16:00
在USART的初始化代码中,如果存在逻辑错误或配置不当,也可能导致复位后立即进入中断。
jcky001 发表于 2025-1-25 16:36
硬件连接错误或不稳定可能导致此类问题
cr315 发表于 2025-1-25 17:00
硬件连接问题?
laocuo1142 发表于 2025-1-25 18:00
USART的TX和RX引脚连接不正确,或者存在外部干扰,就可能导致复位后立即进入发送中断。
flycamelaaa 发表于 2025-1-25 19:26
固件或软件缺陷
powerantone 发表于 2025-1-25 20:00
中断处理函数中的bug,可能导致复位后立即进入中断。
probedog 发表于 2025-1-25 21:00
检查USART的初始化代码配置是否正确的。特别是中断使能位,应该只使能需要的中断。
classroom 发表于 2025-1-25 21:00
在中断服务函数中,确保正确地检查和清除中断标志位。这可以防止中断被反复触发。
梅花香自123 发表于 2025-2-28 16:11
如果发送缓冲区为空,USART0会进入发送缓冲区空中断。
页: [1]
查看完整版本: GD32E230上电复位后,立马进入发送中断
