【AT-START-L021测评】0.96寸OLED驱动
OLED是常见的显示模块,本次是用雅特力AT-START-L021来驱动主控芯片为SSD1306的0.96寸OLED模块,使用的是IIC进行通信。首先是在新创建的工程中添加i2c_application.c(在BSP文件夹下)和at32l021_i2c.c和at32l021_dma.c(在FIRMWARE文件夹下)。其中at32l021_dma.c在i2c_application.c中引用,但是实际的工程中没有使用到,去掉编译会有问题。
其次是在main函数中调用IIC初始化相关函数,这里参考了IIC例程。在main.c中添加如下的IIC对应的GPIO口初始化函数
void i2c_lowlevel_init(i2c_handle_type* hi2c)
gpio_init_type gpio_init_structure;
if(hi2c->i2cx == I2Cx_PORT)
/* i2c periph clock enable */
crm_periph_clock_enable(I2Cx_CLK, TRUE);
crm_periph_clock_enable(I2Cx_SCL_GPIO_CLK, TRUE);
crm_periph_clock_enable(I2Cx_SDA_GPIO_CLK, TRUE);
/* gpio configuration */
gpio_pin_mux_config(I2Cx_SCL_GPIO_PORT, I2Cx_SCL_GPIO_PinsSource, I2Cx_SCL_GPIO_MUX);
gpio_pin_mux_config(I2Cx_SDA_GPIO_PORT, I2Cx_SDA_GPIO_PinsSource, I2Cx_SDA_GPIO_MUX);
/* configure i2c pins: scl */
gpio_init_structure.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
gpio_init_structure.gpio_mode = GPIO_MODE_MUX;
gpio_init_structure.gpio_out_type = GPIO_OUTPUT_OPEN_DRAIN;
gpio_init_structure.gpio_pull = GPIO_PULL_NONE;
gpio_init_structure.gpio_pins = I2Cx_SCL_GPIO_PIN;
gpio_init(I2Cx_SCL_GPIO_PORT, &gpio_init_structure);
/* configure i2c pins: sda */
gpio_init_structure.gpio_pins = I2Cx_SDA_GPIO_PIN;
gpio_init(I2Cx_SDA_GPIO_PORT, &gpio_init_structure);
/* config i2c */
i2c_init(hi2c->i2cx, 0x0F, I2Cx_CLKCTRL);
i2c_own_address1_set(hi2c->i2cx, I2C_ADDRESS_MODE_7BIT, I2Cx_ADDRESS);
} 在main中添加如下的宏定义
#define I2C_TIMEOUT 0xFFFFFFF
//#define I2Cx_CLKCTRL 0xF070F7F7 //10K
//#define I2Cx_CLKCTRL 0x60F06C6C //50K
#define I2Cx_CLKCTRL 0x60F03333 //100K
//#define I2Cx_CLKCTRL 0x20C02C4F //200K
//#define I2Cx_ADDRESS 0xA0
#define I2Cx_PORT I2C1
#define I2Cx_CLK CRM_I2C1_PERIPH_CLOCK
#define I2Cx_DMA DMA1
#define I2Cx_DMA_CLK CRM_DMA1_PERIPH_CLOCK
#define I2Cx_SCL_GPIO_CLK CRM_GPIOB_PERIPH_CLOCK
#define I2Cx_SCL_GPIO_PIN GPIO_PINS_6
#define I2Cx_SCL_GPIO_PinsSource GPIO_PINS_SOURCE6
#define I2Cx_SCL_GPIO_PORT GPIOB
#define I2Cx_SCL_GPIO_MUX GPIO_MUX_1
#define I2Cx_SDA_GPIO_CLK CRM_GPIOB_PERIPH_CLOCK
#define I2Cx_SDA_GPIO_PIN GPIO_PINS_7
#define I2Cx_SDA_GPIO_PinsSource GPIO_PINS_SOURCE7
#define I2Cx_SDA_GPIO_PORT GPIOB
#define I2Cx_SDA_GPIO_MUX GPIO_MUX_1 在main中添加对应的.h调用代码
#include "i2c_application.h" main函数中调用IIC初始化的代码如下
hi2cx.i2cx = I2Cx_PORT;
/* i2c config */
i2c_config(&hi2cx);
之后是添加OLED的驱动,这里是参考常用的OLED驱动,只是修改发送数据的代码,OLED.c的代码如下
#include "oled.h"
#include "oledfont.h"
i2c_handle_type OLEDhi2cx;
void OLED_WriteByte(uint8_t data, uint8_t mode);
void OLED_Clear(void);
void OLED_SetPos(uint8_t x, uint8_t y);
void OLED_DrawBMP(uint8_t x, uint8_t y, uint8_t sizex, uint8_t sizey, const uint8_t BMP[]);
函 数 名:OLED_WriteByte
功 能:发送一个字节
参数描述:data:发送数据
mode:模式选择 0:命令 1:数据
返 回 值:无
uint8_t u8Senddata = {0};
u8Senddata = mode;
u8Senddata = data;
i2c_master_transmit(&OLEDhi2cx,OLED_ADDR, u8Senddata, 2, 0xFF);
函 数 名:OLED_Clear
功 能:清屏
参数描述:无
返 回 值:无
uint8_t i,n;
for(i=0; i<OLED_PAGE_SUM; i++)
OLED_WriteByte (OLED_REG_PAGE_SET + i,OLED_SEND_CMD); /* 设置页地址(0~7) */
OLED_WriteByte (OLED_REG_LINE_L_SET,OLED_SEND_CMD); /* 设置显示位置—列低地址 */
OLED_WriteByte (OLED_REG_LINE_H_SET,OLED_SEND_CMD); /* 设置显示位置—列高地址 */
for(n=0; n<128; n++)
OLED_WriteByte(0,OLED_SEND_DATA);
}//更新显示
函 数 名:OLED_SetPos
功 能:坐标设置
参数描述:x:横坐标
Y:纵坐标
返 回 值:无
OLED_WriteByte(0xb0 + y, OLED_SEND_CMD);
OLED_WriteByte(((x & 0xf0) >> 4) | 0x10, OLED_SEND_CMD);
OLED_WriteByte((x & 0x0f), OLED_SEND_CMD);
函 数 名:OLED_DrawBMP
功 能:显示图片
参数描述:x, y:起始坐标
sizex, sizey:终止坐标
BMP:图像数据
返 回 值:无
uint16_t j=0;
uint8_t i, m, temp;
sizey = sizey / 8 + ((sizey % 8) ? 1 : 0);
for(i = 0; i < sizey; i++)
OLED_SetPos(x, i + y);
for(m = 0; m < sizex; m++)
temp = BMP;
OLED_WriteByte(temp, OLED_SEND_DATA);
//屏幕旋转180度
void OLED_DisplayTurn(uint8_t i)
if(i==0)
OLED_WriteByte(0xC8,OLED_SEND_CMD);//正常显示
OLED_WriteByte(0xA1,OLED_SEND_CMD);
else
OLED_WriteByte(0xC0,OLED_SEND_CMD);//反转显示
OLED_WriteByte(0xA0,OLED_SEND_CMD);
函 数 名:OLED_Init
功 能:OLED初始化
参数描述:无
返 回 值:无
void OLED_Init()
OLEDhi2cx.i2cx = I2C1;
OLED_WriteByte(0xAE,OLED_SEND_CMD);//--turn off oled panel
OLED_WriteByte(0x00,OLED_SEND_CMD);//---set low column address
OLED_WriteByte(0x10,OLED_SEND_CMD);//---set high column address
OLED_WriteByte(0x40,OLED_SEND_CMD);//--set start line addressSet Mapping RAM Display Start Line (0x00~0x3F)
OLED_WriteByte(0x81,OLED_SEND_CMD);//--set contrast control register
OLED_WriteByte(0xCF,OLED_SEND_CMD); // Set SEG Output Current Brightness
OLED_WriteByte(0xA1,OLED_SEND_CMD);//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
OLED_WriteByte(0xC8,OLED_SEND_CMD);//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
OLED_WriteByte(0xA6,OLED_SEND_CMD);//--set normal display
OLED_WriteByte(0xA8,OLED_SEND_CMD);//--set multiplex ratio(1 to 64)
OLED_WriteByte(0x3f,OLED_SEND_CMD);//--1/64 duty
OLED_WriteByte(0xD3,OLED_SEND_CMD);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)
OLED_WriteByte(0x00,OLED_SEND_CMD);//-not offset
OLED_WriteByte(0xd5,OLED_SEND_CMD);//--set display clock divide ratio/oscillator frequency
OLED_WriteByte(0x80,OLED_SEND_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
OLED_WriteByte(0xD9,OLED_SEND_CMD);//--set pre-charge period
OLED_WriteByte(0xF1,OLED_SEND_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
OLED_WriteByte(0xDA,OLED_SEND_CMD);//--set com pins hardware configuration
OLED_WriteByte(0x12,OLED_SEND_CMD);
OLED_WriteByte(0xDB,OLED_SEND_CMD);//--set vcomh
OLED_WriteByte(0x40,OLED_SEND_CMD);//Set VCOM Deselect Level
OLED_WriteByte(0x20,OLED_SEND_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
OLED_WriteByte(0x02,OLED_SEND_CMD);//
OLED_WriteByte(0x8D,OLED_SEND_CMD);//--set Charge Pump enable/disable
OLED_WriteByte(0x14,OLED_SEND_CMD);//--set(0x10) disable
OLED_WriteByte(0xA4,OLED_SEND_CMD);// Disable Entire Display On (0xa4/0xa5)
OLED_WriteByte(0xA6,OLED_SEND_CMD);// Disable Inverse Display On (0xa6/a7)
OLED_Clear();
OLED_WriteByte(0xAF,OLED_SEND_CMD); /*display ON*/
OLED_DisplayTurn(1);//0正常显示 1翻转180度显示
函 数 名:OLED_Init
功 能:OLED初始化
参数描述:无
返 回 值:无
void OLED_Test(void)
OLED_DrawBMP(0, 0, 128, 64, BMP1);
//在指定位置显示一个字符
//x:0~127
//y:0~63
//sizey:选择字体 6x88x16
void OLED_ShowChar(uint8_t x, uint8_t y,const uint8_t chr, uint8_t sizey)
uint8_t c = 0, sizex = sizey / 2, temp;
uint16_t i = 0, size1;
if (sizey == 8)
size1=6;
else
size1=(sizey/8+((sizey%8)?1:0))*(sizey/2);
c = chr - ' ';//得到偏移后的值
OLED_SetPos(x,y);
for(i = 0; i < size1; i++)
if(((i % sizex) == 0) && (sizey != 8))
OLED_SetPos(x,y++);
if( sizey == 8)
temp = asc2_0806;
OLED_WriteByte(temp,OLED_SEND_DATA);//6X8字号
else if(sizey == 16)
temp=asc2_1608;
OLED_WriteByte(temp,OLED_SEND_DATA);//8x16字号
else
return;
//显示一个字符号串
void OLED_ShowString(uint8_t x, uint8_t y,const char *chr, uint8_t sizey)
uint8_t j = 0;
while (chr != '\0')
OLED_ShowChar(x, y, chr, sizey);
if(sizey == 8)
x+=6;
else
x += (sizey / 2);
//m^n函数
uint32_t oled_pow(uint8_t m,uint8_t n)
uint32_t result=1;
while(n--)result*=m;
return result;
//显示数字
//x,y :起点坐标
//num:要显示的数字
//len :数字的位数
//sizey:字体大小
void OLED_ShowNum(unsigned char x,unsigned char y,unsigned int num,unsigned char len,unsigned char sizey)
uint8_t t,temp,m=0;
uint8_t enshow=0;
if(sizey==8)m=2;
for(t=0;t<len;t++)
temp=(num/oled_pow(10,len-t-1))%10;
if(enshow==0&&t<(len-1))
if(temp==0)
OLED_ShowChar(x+(sizey/2+m)*t,y,' ',sizey);
continue;
}else enshow=1;
OLED_ShowChar(x+(sizey/2+m)*t,y,temp+'0',sizey);
其中在OLED.c中定义了对应的IIC句柄
i2c_handle_type OLEDhi2cx; 在OLED_Init函数中添加了句柄的赋值
OLEDhi2cx.i2cx = I2C1; 主要是和main函数中初始化的IIC是一个IIC外设。
OLED发送函数使用i2c_application.c中的i2c_master_transmit函数,发送函数定义如下
u8Senddata = mode;
u8Senddata = data;
} 引脚连接图如下
实现效果如下
工程文件:
这是使用的图片显示吗 呐咯密密 发表于 2025-1-7 15:23
这是使用的图片显示吗
代码 用专门的工具把图片转换成显示的点的数组 我在用这种屏幕的时候经常会遇到部分位置乱码,特别是在不断更新的数据显示的时候。 0.96 寸 OLED 模块体积小巧。两者搭配能在有限的电路板空间内实现显示功能,对于小型化、便携式设备的开发十分有利 SSD1306 作为常见的 OLED 主控芯片,已有丰富的开源驱动代码和资料可供参考。 在新创建的工程中添加相关的I2C驱动文件和OLED驱动文件。这些文件包含了I2C初始化、OLED初始化、数据显示等函数,为实现OLED驱动提供了必要的软件支持。 该芯片具有ARM Cortex®-M0+内核,实现了高性能与低功耗的完美结合。 有完善的错误处理机制 这个0.96寸的OLED屏出镜率很高啊。 要确保上拉电阻的阻值合适(通常为4.7kΩ左右),以保证IIC信号的正常传输。 0.96寸的OLED屏幕尺寸有限,显示的信息量相对较少 虽然IIC通信速度相对较慢,但可以在一定范围内进行优化。 在干扰环境下,IIC通信是否可靠,是否有错误检测和重试机制。 便于扩展OLED的功能。 IIC 通信速率相对有限,在需要高速刷新屏幕内容或传输大量数据时,可能无法满足需求,导致显示出现延迟或卡顿现象。 IIC总线是一种常用的双向二线制串行总线,适用于连接低速的外围设备,如OLED显示器。它简化了硬件接口,降低了设计复杂性。 该设计充分利用了雅特力AT-START-L021开发板的高性能和丰富外设资源,通过IIC总线实现了对SSD1306主控芯片的OLED模块的驱动。 OLED模块的显示效果非常出色,对比度高,色彩鲜艳。通过SSD1306芯片的控制,我们能够实现各种图形和文字的显示,满足嵌入式系统的需求。 虽然 SSD1306 有开源驱动代码,但在实际应用中,可能需要根据 AT - START - L021 的特点和具体需求对代码进行优化,以提高显示性能和效率。
页:
[1]
