qihao74 发表于 2025-1-7 15:20
hc32l136 Lpuart发生异常
当发送指令放置在接收中断时,一切正常。如果把发送中断移值主程序,偶尔就会出现发送指令不执行或延迟执行的现象 。//===================================// 初始化Lpuart//===================================void lpuart_init(void){    uint16_t u16Scnt = 0;    stc_gpio_config_t stcGpioCfg;    stc_lpuart_sclk_sel_t stcSclk;    stc_lpuart_config_tstcConfig;    stc_lpuart_irq_cb_t stcLPUartIrqCb;    stc_lpuart_multimode_t stcMulti;    stc_lpuart_baud_t stcBaud;     DDL_ZERO_STRUCT(stcConfig);    DDL_ZERO_STRUCT(stcLPUartIrqCb);    DDL_ZERO_STRUCT(stcMulti);    DDL_ZERO_STRUCT(stcBaud);    DDL_ZERO_STRUCT(stcGpioCfg);    DDL_ZERO_STRUCT(stcSclk);     Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);    Sysctrl_SetPeripheralGate(SysctrlPeripheralLpUart1, TRUE);     stcGpioCfg.enDir =GpioDirOut;    Gpio_Init(GpioPortA, GpioPin0, &stcGpioCfg); //TX    stcGpioCfg.enDir =GpioDirIn;    stcGpioCfg.enPuPd = GpioPu;    Gpio_Init(GpioPortA, GpioPin1, &stcGpioCfg); //RX     Gpio_SetAfMode(GpioPortA, GpioPin0, GpioAf2);    Gpio_SetAfMode(GpioPortA, GpioPin1, GpioAf2);     stcLPUartIrqCb.pfnRxIrqCb   = LPUartRxIntCallback;    stcLPUartIrqCb.pfnTxIrqCb   = NULL;    stcLPUartIrqCb.pfnRxFEIrqCb = NULL;    stcLPUartIrqCb.pfnPEIrqCb   = NULL;    stcLPUartIrqCb.pfnCtsIrqCb= NULL;    stcConfig.pstcIrqCb = &stcLPUartIrqCb;    stcConfig.bTouchNvic = TRUE;     stcConfig.enStopBit = LPUart1bit;    stcConfig.enRunMode = LPUartMode1;//    stcSclk.enSclk_Prs = LPUart4Or8Div;    stcSclk.enSclk_sel = LPUart_Rcl;    stcConfig.pstcLpuart_clk = &stcSclk;     stcMulti.enMulti_mode = LPUartNormal;    stcConfig.pstcMultiMode = &stcMulti;     LPUart_Init(LPUART1, &stcConfig);     LPUart_SetClkDiv(LPUART1, LPUart4Or8Div);    stcBaud.u32Sclk = LPUart_GetSclk(LPUART1);    stcBaud.enRunMode = LPUartMode1;    stcBaud.u32Baud = 9600;    u16Scnt = LPUart_CalScnt(LPUART1, &stcBaud);    LPUart_SetBaud(LPUART1, u16Scnt);     LPUart_EnableIrq(LPUART1, LPUartRxIrq);    LPUart_ClrStatus(LPUART1, LPUartRC);    LPUart_EnableFunc(LPUART1, LPUartRx);}//===================================// LPUART 中断服务函数//===================================void LPUartRxIntCallback(void){    Uartbuff = LPUart_ReceiveData(LPUART1);;     if(UartRX_dp >= 8)    {      if( (Uartbuff == PollAdd) || (Uartbuff == 0) )      {            if((Uartbuff == 3) || (Uartbuff == 6) || (Uartbuff == 8))            {                ISRcrc16 = ISRcal_crc16(Uartbuff, 6);                 if( (Uartbuff == ((uint8_t)ISRcrc16)) && ( Uartbuff == ((uint8_t)(ISRcrc16 >> 8))) )                {                  //准备发送                  UartHartrecok = 0x55;                   if((Uartbuff == 3) || (Uartbuff == 6))                        **.ReportSum** = 0;                   //                                        Rxreal**=0;                  UartRX_dp = 0;                }                 code16 = 0;            }            else if(Uartbuff == 0x10)            {                if(UartRX_dp >= (Uartbuff + 9))                {                  ISRcrc16 = ISRcal_crc16(Uartbuff, Uartbuff + 7);                   if( (Uartbuff + 7] == ((uint8_t)ISRcrc16)) && ( Uartbuff + 8] == ((uint8_t)(ISRcrc16 >> 8))) )                  {                        //准备发送                        UartHartrecok = 0x55;                                                **.ReportSum** = 0;                        //                        Rxreal**=0;                        UartRX_dp = 0;                  }                  code16 = 0;//20220419                }                else code16 = 0x55;                //未收完            }            else code16 = 0;      }       if( (UartHartrecok != 0x55) && (code16 != 0x55) )                                //数据不对,移除最旧的一个字节      {            uint8_t i;             for(i = 0; i < UartRX_dp - 1; i++)        Uartbuff = Uartbuff;             UartRX_dp -= 1;      }       if(UartHartrecok == 0x55)      {            MODBUSManagement();      }                                                            } }//===================================// LPUART发送命令处理函数//===================================void MODBUSManagement(void){    if(UartHartrecok == 0x55)    {      uint8_t UartTX_cn;      UartHartrecok = 0;      UartTX_cn = Uart_rx_deal(Uartbuff);       /*数据发送*/      for(uint8_t i = 0; i < UartTX_cn; i++)      {            LPUart_SendData(LPUART1, Uartbuff);      }    }}//===================================// 主函数//===================================int32_t main(void){     lpuart_init();    初始化while(1)    {      Wdt_Feed();       MODBUSManagement();       if((!**.M50** || Resetdly > 0) && Ovmagdly == 0)      {            //LCDLIB_PrintRSSI(4);//关闭信号强度显示            stcConfig.enSLEEPDEEP   = SlpDpEnable;            Lpm_Config(&stcConfig);            Lpm_GotoLpmMode();      }      else      {            stcConfig.enSLEEPDEEP   = SlpDpDisable;            Lpm_Config(&stcConfig);            Lpm_GotoLpmMode();      }    }}
356053261 发表于 2025-1-13 11:58
没遇到过,用这颗芯片几年了,也用了Modbus通信,一切正常
356053261 发表于 2025-1-13 12:02
我是Uart接收中断里只做接收处理,当接收数据空闲时间大于2mS后判断为接收数据结束,再解析缓存里的数据,校验CRC等
地瓜patch 发表于 2025-1-21 21:20
这种问题最难找
申小林一号 发表于 2025-1-22 08:57
学习一下
一点点0321 发表于 2025-4-30 22:31
在主程序中执行发送操作时,可能会受到其他任务或中断的干扰,导致发送操作的延迟。
页: [1]
查看完整版本: hc32l136 Lpuart发生异常
