HC32F460 串口1DMA 只能收不能发 是什么问题
/*****************以下是串口1 配置 *******************//*
再次复位 DMA,防止假死
/* DMA definition */
#define RX1_DMA_UNIT (CM_DMA2)
#define RX1_DMA_CH (DMA_CH0)
#define RX1_DMA_FCG_ENABLE() (FCG_Fcg0PeriphClockCmd(FCG0_PERIPH_DMA2, ENABLE))
#define RX1_DMA_TRIG_SEL (AOS_DMA2_0)
#define RX1_DMA_TRIG_EVT_SRC (EVT_SRC_USART1_RI)
#define RX1_DMA_RECONF_TRIG_SEL (AOS_DMA_RC)
#define RX1_DMA_RECONF_TRIG_EVT_SRC (EVT_SRC_AOS_STRG)
#define RX1_DMA_TC_INT (DMA_INT_TC_CH0)
#define RX1_DMA_TC_FLAG (DMA_FLAG_TC_CH0)
#define RX1_DMA_TC_IRQn (INT042_IRQn)
#define RX1_DMA_TC_INT_SRC (INT_SRC_DMA2_TC0)
#define TX1_DMA_UNIT (CM_DMA2)
#define TX1_DMA_CH (DMA_CH1)
#define TX1_DMA_FCG_ENABLE() (FCG_Fcg0PeriphClockCmd(FCG0_PERIPH_DMA2, ENABLE))
#define TX1_DMA_TRIG_SEL (AOS_DMA2_1)
#define TX1_DMA_TRIG_EVT_SRC (EVT_SRC_USART1_TI)
#define TX1_DMA_TC_INT (DMA_INT_TC_CH1)
#define TX1_DMA_TC_FLAG (DMA_FLAG_TC_CH1)
#define TX1_DMA_TC_IRQn (INT043_IRQn)
#define TX1_DMA_TC_INT_SRC (INT_SRC_DMA2_TC1)
static void USART1_TxComplete_IrqCallback(void) //发送完成中断
USART_FuncCmd(CM_USART1, (USART_TX | USART_INT_TX_CPLT), DISABLE);
USART_ClearStatus(CM_USART1, USART_FLAG_TX_CPLT);
接收错误中断.
static void USART1_RxError_IrqCallback(void)
(void)USART_ReadData(CM_USART1);
USART_ClearStatus(CM_USART1, (USART_FLAG_PARITY_ERR | USART_FLAG_FRAME_ERR | USART_FLAG_OVERRUN));
int cnt;
char Dbuf1_T;
static void USART1_RxFull_IrqCallback(void) //中断方式接收数据
Dbuf1_T=CM_USART1->RDR;
if(cnt>50) cnt=0;
接收完成设定的字节中断
static void RX1_DMA_TC_IrqCallback(void)
DMA_ClearTransCompleteStatus(RX1_DMA_UNIT, RX1_DMA_TC_FLAG);
发送完成中断
int oy;
static void TX1_DMA_TC_IrqCallback(void)
USART_FuncCmd(CM_USART1, USART_INT_TX_CPLT, ENABLE);
DMA_ClearTransCompleteStatus(TX1_DMA_UNIT, TX1_DMA_TC_FLAG);
OUTCLRYAB1();
oy++;
static int32_t DMA_Config_UART1(void)
int32_t i32Ret;
stc_dma_init_t stcDmaInit;
stc_dma_llp_init_t stcDmaLlpInit;
stc_irq_signin_config_t stcIrqSignConfig;
static stc_dma_llp_descriptor_t stcLlpDesc;
/* DMA&AOS FCG enable */
RX1_DMA_FCG_ENABLE();
TX1_DMA_FCG_ENABLE();
FCG_Fcg0PeriphClockCmd(FCG0_PERIPH_AOS, ENABLE);
/* DMA1 FCG enable */
FCG_Fcg0PeriphClockCmd(FCG0_PERIPH_DMA2, ENABLE);//DMA1使能
/* AOS FCG enable */
/* USART1_RX_DMA 接收*/
(void)DMA_StructInit(&stcDmaInit);
stcDmaInit.u32IntEn = DMA_INT_ENABLE;//DMA 中断使能
stcDmaInit.u32BlockSize = 1UL;
stcDmaInit.u32TransCount = 500;// 尺寸
stcDmaInit.u32DataWidth = DMA_DATAWIDTH_8BIT; //数据宽度
stcDmaInit.u32DestAddr = (uint32_t)Dbuf1;//接收的寄存器
stcDmaInit.u32SrcAddr = (uint32_t)(&CM_USART1->RDR);//接收的 源地址
stcDmaInit.u32SrcAddrInc = DMA_SRC_ADDR_FIX;//源地址固定
stcDmaInit.u32DestAddrInc = DMA_DEST_ADDR_INC;//目标地址 加 1
i32Ret = DMA_Init(CM_DMA2,DMA_CH0, &stcDmaInit);
if (LL_OK == i32Ret) {
(void)DMA_LlpStructInit(&stcDmaLlpInit);
stcDmaLlpInit.u32State = DMA_LLP_ENABLE;
stcDmaLlpInit.u32Mode= DMA_LLP_WAIT;
stcDmaLlpInit.u32Addr= (uint32_t)&stcLlpDesc;
(void)DMA_LlpInit(CM_DMA2, DMA_CH0, &stcDmaLlpInit);
stcLlpDesc.SARx = stcDmaInit.u32SrcAddr;
stcLlpDesc.DARx = stcDmaInit.u32DestAddr;
stcLlpDesc.DTCTLx = (stcDmaInit.u32TransCount << DMA_DTCTL_CNT_POS) | (stcDmaInit.u32BlockSize << DMA_DTCTL_BLKSIZE_POS);;
stcLlpDesc.LLPx = (uint32_t)&stcLlpDesc;
stcLlpDesc.CHCTLx = stcDmaInit.u32SrcAddrInc | stcDmaInit.u32DestAddrInc | stcDmaInit.u32DataWidth |\
stcDmaInit.u32IntEn | stcDmaLlpInit.u32State | stcDmaLlpInit.u32Mode;
DMA_ReconfigLlpCmd(CM_DMA2, DMA_CH0, ENABLE);
DMA_ReconfigCmd(CM_DMA2, ENABLE);
AOS_SetTriggerEventSrc(RX1_DMA_RECONF_TRIG_SEL, RX1_DMA_RECONF_TRIG_EVT_SRC);
stcIrqSignConfig.enIntSrc = RX1_DMA_TC_INT_SRC;
stcIrqSignConfig.enIRQn= RX1_DMA_TC_IRQn;
stcIrqSignConfig.pfnCallback = &RX1_DMA_TC_IrqCallback;
(void)INTC_IrqSignIn(&stcIrqSignConfig);
NVIC_ClearPendingIRQ(stcIrqSignConfig.enIRQn);
NVIC_SetPriority(stcIrqSignConfig.enIRQn, DDL_IRQ_PRIO_DEFAULT);
NVIC_EnableIRQ(stcIrqSignConfig.enIRQn);
AOS_SetTriggerEventSrc(RX1_DMA_TRIG_SEL, RX1_DMA_TRIG_EVT_SRC);
DMA_Cmd(CM_DMA2, ENABLE);
DMA_TransCompleteIntCmd(CM_DMA2, RX1_DMA_TC_INT, ENABLE);
(void)DMA_ChCmd(CM_DMA2, DMA_CH0, ENABLE);
/* USART1_TX_DMA发送*/
stcDmaInit.u32TransCount = 1;
stcDmaInit.u32DestAddr = (uint32_t)(&CM_USART1->TDR);
stcDmaInit.u32SrcAddr = (uint32_t)Uar1PDMA;
stcDmaInit.u32SrcAddrInc = DMA_SRC_ADDR_INC;
stcDmaInit.u32DestAddrInc = DMA_DEST_ADDR_FIX;
i32Ret = DMA_Init(TX1_DMA_UNIT, TX1_DMA_CH, &stcDmaInit);
stcIrqSignConfig.enIntSrc = TX1_DMA_TC_INT_SRC;
stcIrqSignConfig.enIRQn= TX1_DMA_TC_IRQn;
stcIrqSignConfig.pfnCallback = &TX1_DMA_TC_IrqCallback;
AOS_SetTriggerEventSrc(TX1_DMA_TRIG_SEL, TX1_DMA_TRIG_EVT_SRC);
DMA_Cmd(TX1_DMA_UNIT, ENABLE);
DMA_TransCompleteIntCmd(TX1_DMA_UNIT, TX1_DMA_TC_INT, ENABLE);
(void)DMA_ChCmd(TX1_DMA_UNIT, TX1_DMA_CH, ENABLE);
return i32Ret;
void UART1_DMA_REST(void)
/* USART1_RX_DMA */
stcDmaInit.u32TransCount = 90;// 尺寸
DMA_Init(CM_DMA2, DMA_CH0, &stcDmaInit);
/************初始化串口*************/
void UART1_INIT(unsigned int Bua_dat)
stc_usart_uart_init_t stcUartInit;
stc_irq_signin_config_t stcIrqSigninConfig;
GPIO_SetFunc(GPIO_PORT_A,GPIO_PIN_02,GPIO_FUNC_32);//USART1-TX
GPIO_SetFunc(GPIO_PORT_A,GPIO_PIN_03,GPIO_FUNC_33);//USART1-RX
/* Enable USART1 clock */
FCG_Fcg1PeriphClockCmd(FCG1_PERIPH_USART1, ENABLE);//打开串口时钟
/* 初始化串口 参数 */
(void)USART_UART_StructInit(&stcUartInit);
stcUartInit.u32ClockSrc = USART_CLK_SRC_INTERNCLK;
stcUartInit.u32ClockDiv = USART_CLK_DIV64;
stcUartInit.u32Baudrate = Bua_dat;//USART_BAUDRATE;
stcUartInit.u32StopBit =USART_STOPBIT_1BIT;
stcUartInit.u32Parity = USART_PARITY_NONE;
stcUartInit.u32OverSampleBit = USART_OVER_SAMPLE_8BIT;
USART_UART_Init(CM_USART1, &stcUartInit, NULL);
/* Register TX complete IRQ handler. */
stcIrqSigninConfig.enIRQn = INT080_IRQn;
stcIrqSigninConfig.enIntSrc = INT_SRC_USART1_TCI;
stcIrqSigninConfig.pfnCallback = &USART1_TxComplete_IrqCallback;//发送完成中断 中断
(void)INTC_IrqSignIn(&stcIrqSigninConfig);
NVIC_ClearPendingIRQ(stcIrqSigninConfig.enIRQn);
NVIC_SetPriority(stcIrqSigninConfig.enIRQn, DDL_IRQ_PRIO_DEFAULT);
NVIC_EnableIRQ(stcIrqSigninConfig.enIRQn);
/* Register RX error IRQ handler. */
stcIrqSigninConfig.enIRQn = INT081_IRQn;
stcIrqSigninConfig.enIntSrc = INT_SRC_USART1_EI;
stcIrqSigninConfig.pfnCallback = &USART1_RxError_IrqCallback;//接收错误中断
stcIrqSigninConfig.enIRQn = INT082_IRQn;
stcIrqSigninConfig.enIntSrc = INT_SRC_USART1_RI;//INT_SRC_USART1_EI;
stcIrqSigninConfig.pfnCallback = &USART1_RxFull_IrqCallback;//接收错误中断
USART_FuncCmd(CM_USART1, (USART_TX | USART_RX ), ENABLE);//使能收发功能,并启用接收中断
//DMA发送数据
void TX1_DMA1_SEND(unsigned int len) //第一串口通道
DMA_SetSrcAddr(TX1_DMA_UNIT, TX1_DMA_CH, (uint32_t)Uar1PDMA);
DMA_SetTransCount(TX1_DMA_UNIT, TX1_DMA_CH, len);
USART_FuncCmd(CM_USART1,(USART_TX | USART_INT_TX_CPLT), ENABLE);
页:
[1]
