819197207 发表于 2025-2-25 17:30
STMF103C8T6使用HAL ,UART无输出
#include "main.h"
#include<stdio.h>
#include<string.h>
UART_HandleTypeDef huart1;
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_USART1_UART_Init();
/* USER CODE BEGIN 2 */
char message[]="hello world";
while (1)
          HAL_UART_Transmit(&huart1, (uint8_t*)message, strlen(message), 100);
          HAL_Delay(100);
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
/* USER CODE END 3 */
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK;
RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
huart1.Instance = USART1;
huart1.Init.BaudRate = 115200;
huart1.Init.WordLength = UART_WORDLENGTH_8B;
huart1.Init.StopBits = UART_STOPBITS_1;
huart1.Init.Parity = UART_PARITY_NONE;
huart1.Init.Mode = UART_MODE_TX_RX;
huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart1.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOA_CLK_ENABLE();
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
   ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
data:image/png;base64,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**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**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**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***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**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**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***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**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**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***DmjUql6e3***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
xionghaoyun 发表于 2025-2-26 09:08
全发代码一看就是萌新宝宝 你先把正点原子视频看完先
我没看到GPIO没复用uart的代码
香水城 发表于 2025-2-26 11:36
如果你使用CubeMx进行配置,然后调用库 API,若无输出,重点检查硬件线路 及两端的UART 通信参数。
cooldog123pp 发表于 2025-2-26 17:15
没输出问题点很多啊,不光是软件的问题,还可能是硬件问题,也不一定是uart的问题也可能是你时钟没搞对也有可能。
页: [1]
查看完整版本: STMF103C8T6使用HAL ,UART无输出
