test09_v.py
from math import logfrom scipy.constants import Boltzmann, physical_constants
T = 300# TEMPERATURE (unit = K)
def builtin_voltage(
donor_conc: float,# donor concentration
acceptor_conc: float,# acceptor concentration
intrinsic_conc: float,# intrinsic concentration
) -> float:
This function can calculate the Builtin Voltage of a pn junction diode.
This is calculated from the given three values.
Examples -
>>> builtin_voltage(donor_conc=1e17, acceptor_conc=1e17, intrinsic_conc=1e10)
0.833370010652644
>>> builtin_voltage(donor_conc=0, acceptor_conc=1600, intrinsic_conc=200)
Traceback (most recent call last):
ValueError: Donor concentration should be positive
>>> builtin_voltage(donor_conc=1000, acceptor_conc=0, intrinsic_conc=1200)
ValueError: Acceptor concentration should be positive
>>> builtin_voltage(donor_conc=1000, acceptor_conc=1000, intrinsic_conc=0)
ValueError: Intrinsic concentration should be positive
>>> builtin_voltage(donor_conc=1000, acceptor_conc=3000, intrinsic_conc=2000)
ValueError: Donor concentration should be greater than intrinsic concentration
>>> builtin_voltage(donor_conc=3000, acceptor_conc=1000, intrinsic_conc=2000)
ValueError: Acceptor concentration should be greater than intrinsic concentration
if donor_conc <= 0:
raise ValueError("Donor concentration should be positive")
elif acceptor_conc <= 0:
raise ValueError("Acceptor concentration should be positive")
elif intrinsic_conc <= 0:
raise ValueError("Intrinsic concentration should be positive")
elif donor_conc <= intrinsic_conc:
raise ValueError(
"Donor concentration should be greater than intrinsic concentration"
elif acceptor_conc <= intrinsic_conc:
raise ValueError(
"Acceptor concentration should be greater than intrinsic concentration"
else:
return (
Boltzmann
* T
* log((donor_conc * acceptor_conc) / intrinsic_conc**2)
/ physical_constants["electron volt"]
if __name__ == "__main__":
import doctest
doctest.testmod()
不知道这个公式是从哪里来的,有没有相关的物理背景知识可以参考 这个脚本提供了一个计算pn结二极管内建电压的函数,使用了数学和物理常数。
页:
[1]
