TTL串口U盘模块,自适应波特率
TTL串口U盘模块,自适应波特率:一、模块功能介绍:
二、程序源代码片段:
* @brief USART1 Initialization Function
* @param None
* @retval None
static void MX_USART1_UART_Init(uint8_t mode)
huart1.Instance = USARTx;
huart1.Init.BaudRate = 460800;
huart1.Init.WordLength = UART_WORDLENGTH_8B;
huart1.Init.StopBits = UART_STOPBITS_1;
huart1.Init.Parity = UART_PARITY_NONE;
huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart1.Init.Mode = UART_MODE_TX_RX;
huart1.Init.OverSampling = UART_OVERSAMPLING_16;
/*##Configure the AutoBaudRate method */
huart1.AdvancedInit.AdvFeatureInit =UART_ADVFEATURE_AUTOBAUDRATE_INIT;
huart1.AdvancedInit.AutoBaudRateEnable = UART_ADVFEATURE_AUTOBAUDRATE_ENABLE;
switch(mode){
case 0:
huart1.AdvancedInit.AutoBaudRateMode =
UART_ADVFEATURE_AUTOBAUDRATE_ONSTARTBIT;
break;
case 1:
UART_ADVFEATURE_AUTOBAUDRATE_ONFALLINGEDGE;
break;
case 2:
UART_ADVFEATURE_AUTOBAUDRATE_ON0X7FFRAME;
break;
case 3:
UART_ADVFEATURE_AUTOBAUDRATE_ON0X55FRAME;
break;
default:
break;
if (HAL_UART_Init(&huart1) != HAL_OK){
Error_Handler();
* 功 能:USART1---自动波特率检测启动函数
* 入口参数:ni.
* 出口参数:nil
void AutoBaudRate_DetectStart(void)
char temp_buf;
uint32_t baudrateval;
/* Wait until Receive enable acknowledge flag is set */
while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_REACK) == RESET)
{vTaskDelay(1);}
/* Wait until Transmit enable acknowledge flag is set */
while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_TEACK) == RESET)
{vTaskDelay(1);}
/* Loop until the end of USART1_AutoBaudrate phase */
while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_ABRF) == RESET)
{vTaskDelay(1);}
/* If AutoBaudBate error occurred */
if (__HAL_UART_GET_FLAG(&huart1, UART_FLAG_ABRE)!= RESET){
Error_Handler();
}else{
/* Wait until RXNE flag is set */
while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_RXNE) == RESET)
{vTaskDelay(1);}
HAL_UART_Receive(&huart1, (uint8_t *)aTxBuffer, TXBUFFERSIZE,100);
/* Send acknowledgement message*/
if (HAL_UART_Transmit(&huart1, (uint8_t *)aTxBuffer, strlen((char *)aTxBuffer),100)!= HAL_OK){
Error_Handler();
while(__HAL_UART_GET_FLAG(&huart1,USART_FLAG_TC) == RESET)
{vTaskDelay(1);}
//计算波特率
baudrateval = HAL_RCC_GetSysClockFreq() / USART1->BRR;
sprintf(temp_buf,"\r\n检测到波特率为:%d \r\n",baudrateval);
HAL_UART_Transmit(&huart1, (uint8_t *)temp_buf, strlen(temp_buf),100);
{vTaskDelay(1);}
* 函 数 名: vTask_GetFiles_Data
* 功能说明: 获取文件命令数据任务
* 形 参: pvParameters 是在创建该任务时传递的形参
* 返 回 值: 无
static void vTask_GetFiles_Data(void *pvParameters)
#if AUTOBAUDRATE_All_TEST_EN>0
AutoBaudrate_AllParams_Test();
#else
MX_USART1_UART_Init(3); //初始化串口
AutoBaudRate_DetectStart(); //自动波特率检测
//使能串口1接收中断: 每接收1个字节,中断一次
HAL_UART_Receive_IT(&huart1,&sRcv_data,1);
vTaskDelay(200);
#endif
while(1)
if(UART1_received==1){ //set----接收数据包完成
taskENTER_CRITICAL();
UART1_received=0; //clear
taskEXIT_CRITICAL();
if(flag_UDisk_Ok==1){
Real_UDisk_WriteFiles();//U盘文件操作
HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_11);
vTaskDelay(10);
这段代码的主要目的是通过 USART1 进行数据传输,并利用自动波特率检测功能来动态调整通信速率 该函数用于启动 USART1 的自动波特率检测过程,并在检测完成后发送确认消息。
它会进入自动波特率检测阶段,直到检测完成或发生错误
如果宏定义 AUTOBAUDRATE_All_TEST_EN 大于0,则调用 AutoBaudrate_AllParams_Test 函数进行所有参数测试。
使用临界区保护全局变量 UART1_received 和 flag_UDisk_Ok,确保线程安全
初始的波特率是不能实现检测的吧
学习学习 感谢分享 辛苦 沁恒的串口桥接芯片了解一下,比这个应用简单。
页:
[1]
