一路向北lm 发表于 2025-3-15 19:26
运行STM32N6 的BSP外设综合测试
Demo:按键触摸
Demo:SD卡实验
Demo:摄像头实验
视频动图展示
一路向北lm 发表于 2025-3-15 19:29
摄像头camera代码部分
* @file    camera.c
* @authorMCD Application Team
* @brief   This example code shows how to use the camera features of the
*          stm32h7b3i_eval_camera driver
* @attention
* Copyright (c) 2024 STMicroelectronics.
* All rights reserved.
* This software is licensed under terms that can be found in the LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup STM32N6xx_HAL_Examples
/** @addtogroup BSP
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define WVGA_RES_X      800
#define WVGA_RES_Y      480
#define CAMERA_FRAME_BUFFER LCD_LAYER_1_ADDRESS
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static uint8_t MirrorFlipIndex = 0;
/* Camera resolutions */
uint8_tCameraMirrorFlip =
CAMERA_MIRRORFLIP_NONE,
CAMERA_MIRRORFLIP_FLIP,
CAMERA_MIRRORFLIP_MIRROR,
CAMERA_MIRRORFLIP_FLIP | CAMERA_MIRRORFLIP_MIRROR,
CAMERA_Capabilities_t Cap;
/* Private function prototypes -----------------------------------------------*/
static void Camera_SetHint(void);
static uint32_t Camera_ISP_IdleWait(uint32_t delay);
/* Private functions ---------------------------------------------------------*/
* @briefCamera demo
* @paramNone
* @retval None
void Camera_Demo (void)
Camera_SetHint();
UTIL_LCD_Clear(UTIL_LCD_COLOR_WHITE);
/* Display USB initialization message */
UTIL_LCD_SetBackColor(UTIL_LCD_COLOR_WHITE);
UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_DARKBLUE);
UTIL_LCD_SetFont(&Font24);
BSP_LCD_LayerConfig_t cam_layer;
cam_layer.Address = LCD_LAYER_1_ADDRESS;
cam_layer.PixelFormat = LCD_PIXEL_FORMAT_RGB565;
cam_layer.X0 = 0;
cam_layer.X1 = 800;
cam_layer.Y0 = 0;
cam_layer.Y1 = 480;
BSP_LCD_ConfigLayer(0, 1, &cam_layer);
BSP_LCD_SetColorKeying(0, 1, UTIL_LCD_COLOR_WHITE);
BSP_LCD_SetActiveLayer(0,1);
BSP_LCD_SetLayerAddress(0, 0, LCD_LAYER_1_ADDRESS);
BSP_LCD_SetLayerAddress(0, 1, LCD_LAYER_0_ADDRESS);
/* Initialize the Camera */
if(BSP_CAMERA_Init(0, CAMERA_R2592x1944, CAMERA_PF_RAW_RGGB10) != BSP_ERROR_NONE)
    UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_RED);
    UTIL_LCD_DisplayStringAt(20, 0, (uint8_t *)" NO CAMERA CONNECTED", CENTER_MODE);
else
    UTIL_LCD_DisplayStringAt(20, 35, (uint8_t *)"CAMERA CONTINUOUS MODE", CENTER_MODE);
    /* Wait for the camera initialization after HW reset*/
    HAL_Delay(100);
    BSP_CAMERA_GetCapabilities(0, &Cap);
    /* Start the Camera Capture */
    BSP_CAMERA_Start(0, (uint8_t *)CAMERA_FRAME_BUFFER, CAMERA_MODE_CONTINUOUS);
    Camera_ISP_IdleWait(5000);
    if(Cap.MirrorFlip != 1)
      UTIL_LCD_DisplayStringAt(0, 35, (uint8_t *)"Camera MirrorFlip feature not supported", CENTER_MODE);
      Camera_ISP_IdleWait(2000);
    else
      UTIL_LCD_DisplayStringAt(0, 35, (uint8_t *)"                                             ", CENTER_MODE);
      UTIL_LCD_DisplayStringAt(0, 70, (uint8_t *)"Camera Mirror/Flip", CENTER_MODE);
      /* Test Camera Mirror/Flip */
      while(MirrorFlipIndex < 4)
      BSP_CAMERA_SetMirrorFlip(0, CameraMirrorFlip);
      MirrorFlipIndex++;
      MirrorFlipIndex = 1;
    BSP_CAMERA_SetMirrorFlip(0, CAMERA_MIRRORFLIP_NONE);
BSP_CAMERA_Stop(0);
UTIL_LCD_FillRect(0, 0, 800, 480, UTIL_LCD_COLOR_WHITE);
BSP_LCD_ResetColorKeying(0, 1);
BSP_LCD_SetLayerAddress(0, 0, LCD_LAYER_0_ADDRESS);
BSP_LCD_SetLayerAddress(0, 1, LCD_LAYER_1_ADDRESS);
BSP_LCD_SetLayerVisible(0, 1, DISABLE);
BSP_LCD_SetActiveLayer(0,0);
UTIL_LCD_DisplayStringAt(20, 35, (uint8_t *)"CAMERA Demo done. press USR1 to continue", CENTER_MODE);
while (1)
    if(CheckForUserInput() > 0)
      ClearUserInput();
      BSP_CAMERA_DeInit(0);
      return;
* @briefDisplay Camera demo hint
* @paramNone
* @retval None
uint32_t x_size, y_size;
BSP_LCD_GetXSize(0, &x_size);
BSP_LCD_GetYSize(0, &y_size);
/* Clear the LCD */
/* Set Camera Demo description */
UTIL_LCD_FillRect(0, 0, x_size, 120, UTIL_LCD_COLOR_BLUE);
UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_WHITE);
UTIL_LCD_SetBackColor(UTIL_LCD_COLOR_BLUE);
UTIL_LCD_DisplayStringAt(0, 0, (uint8_t *)"CAMERA EXAMPLE", CENTER_MODE);
UTIL_LCD_SetFont(&Font12);
UTIL_LCD_DisplayStringAt(0, 30, (uint8_t *)"   Press User button for next menu   ", CENTER_MODE);
/* Set the LCD Text Color */
UTIL_LCD_DrawRect(10, 130, x_size - 20, y_size - 130, UTIL_LCD_COLOR_BLUE);
UTIL_LCD_DrawRect(11, 131, x_size - 22, y_size - 132, UTIL_LCD_COLOR_BLUE);
* @briefCamera demo idle loop
* @paramNone
* @retval None
static uint32_t Camera_ISP_IdleWait(uint32_t delay){
uint32_t initial_tick =HAL_GetTick();
while((HAL_GetTick() - initial_tick) < delay){
    int err = BSP_CAMERA_BackgroundProcess();
    if(err != BSP_ERROR_NONE){
      return err;
return 0;
一路向北lm 发表于 2025-3-15 19:30
LCD 部分代码:/**
* @file    lcd.c
* @brief   This example code shows how to use the LCD display feature in the
*          STM32H573I-DK driver
* @attention
#include "main.h"
/** @addtogroup STM32H5xx_HAL_Examples
/** @addtogroup BSP
uint32_tcolors = {UTIL_LCD_COLOR_BLUE , UTIL_LCD_COLOR_GREEN, UTIL_LCD_COLOR_RED, UTIL_LCD_COLOR_CYAN,
                        UTIL_LCD_COLOR_MAGENTA, UTIL_LCD_COLOR_YELLOW,UTIL_LCD_COLOR_LIGHTBLUE, UTIL_LCD_COLOR_LIGHTGREEN,
                        UTIL_LCD_COLOR_LIGHTRED, UTIL_LCD_COLOR_WHITE, UTIL_LCD_COLOR_LIGHTMAGENTA, UTIL_LCD_COLOR_LIGHTYELLOW,
                        UTIL_LCD_COLOR_DARKGREEN, UTIL_LCD_COLOR_DARKRED, UTIL_LCD_COLOR_DARKCYAN,UTIL_LCD_COLOR_DARKMAGENTA,
                        UTIL_LCD_COLOR_LIGHTGRAY, UTIL_LCD_COLOR_GRAY, UTIL_LCD_COLOR_DARKGRAY, UTIL_LCD_COLOR_DARKYELLOW,
                        UTIL_LCD_COLOR_BLACK, UTIL_LCD_COLOR_BROWN, UTIL_LCD_COLOR_ORANGE, UTIL_LCD_COLOR_DARKBLUE};
* @briefLCD demo
* @paramNone
* @retval None
void Lcd_Demo(void)
Point    triangle = {{0, 0}, {0, 0}, {0, 0}};
uint32_t colorIndex = 0;
uint32_t x;
uint32_t y;
uint32_ti, color_index;
UTIL_LCD_SetBackColor(UTIL_LCD_COLOR_ST_BLUE_DARK);
UTIL_LCD_FillRect(0, 0, 800, 40, UTIL_LCD_COLOR_ST_BLUE_DARK);
UTIL_LCD_DisplayStringAt(0, 15, (uint8_t *)" Test LCD", CENTER_MODE);
/* Display a grid of colored rectangles with each rectangle being 80x80 pixels in size.
   There are 8 rectangles per row and 3 rows, each with a color from the colors array */
for (color_index = 0; color_index < 24; color_index++)
    int x = 80 * ((color_index % 8) + 1);
    int y = 80 * (color_index / 8 + 2);
    UTIL_LCD_FillRect(x, y, 80, 80, colors);
HAL_Delay(1000);
UTIL_LCD_FillRect(0, 40, 800, 440, UTIL_LCD_COLOR_WHITE);
/* Display a grid of circles on an LCD screen */
for(color_index = 0; color_index < 4; color_index++)
    for(i = 0; i < 6; i++)
      UTIL_LCD_DrawCircle(150 + (100*i), 100*(color_index+1), 40, UTIL_LCD_COLOR_BLACK);
HAL_Delay(1000);
/* Display a grid of colored circles */
      UTIL_LCD_FillCircle(150 + (100*i), 100*(color_index+1), 40, colors);
      colorIndex++;
      HAL_Delay(50);
HAL_Delay(1000);
colorIndex = 0;
/* Display a grid of colored triangles */
for(color_index = 0; color_index < 6; color_index++)
    for(i = 0; i < 4; i++)
      triangle.X = 40*color_index;
      triangle.Y = 40 + 50*(i);
      triangle.X = 40*(color_index+1);
      triangle.Y = 65 + 50*(i);
      triangle.Y = 40 + 50*(1+i);
      UTIL_LCD_FillPolygon(triangle, 3, colors);
      if(colors == UTIL_LCD_COLOR_WHITE)
      UTIL_LCD_DrawPolygon(triangle, 3, UTIL_LCD_COLOR_BLACK);
      colorIndex++;
HAL_Delay(1000);
/* Draw bitmap */
UTIL_LCD_DrawBitmap(80, 130, (uint8_t *)st**);
HAL_Delay(500);
UTIL_LCD_DrawBitmap(240, 130, (uint8_t *)st**);
HAL_Delay(500);
UTIL_LCD_DrawBitmap(400, 130, (uint8_t *)st**);
HAL_Delay(500);
UTIL_LCD_DrawBitmap(560, 130, (uint8_t *)st**);
HAL_Delay(1000);
BSP_LCD_DisplayOff(0);
if (BSP_LCD_DeInit(0) != BSP_ERROR_NONE)
    Error_Handler();
BSP_LCD_InitEx(0, LCD_ORIENTATION_LANDSCAPE, LCD_PIXEL_FORMAT_RGB888, LCD_DEFAULT_WIDTH, LCD_DEFAULT_HEIGHT);
UTIL_LCD_SetFuncDriver(&LCD_Driver);
BSP_LCD_DisplayOn(0);
UTIL_LCD_DisplayStringAt(0, 100, (uint8_t *)"LCD RGB888", CENTER_MODE);
for (color_index = 0; color_index < 16; color_index++)
   x = 40 * ((color_index % 4) + 8) ;
   y = (40 * (color_index / 4 + 4));
    UTIL_LCD_FillRect(x, y, 40, 40, colors);
HAL_Delay(1000);
    Error_Handler();
BSP_LCD_InitEx(0, LCD_ORIENTATION_LANDSCAPE, LCD_PIXEL_FORMAT_ARGB4444, LCD_DEFAULT_WIDTH, LCD_DEFAULT_HEIGHT);
UTIL_LCD_DisplayStringAt(0, 100, (uint8_t *)"LCD ARGB4444", CENTER_MODE);
for (color_index = 8; color_index < 24; color_index++)
HAL_Delay(1000);
    Error_Handler();
if(BSP_LCD_Init(0, LCD_ORIENTATION_LANDSCAPE) != BSP_ERROR_NONE)
    Error_Handler();
一路向北lm 发表于 2025-3-15 19:31
触摸演示相关函数
* @file    touchscreen.c
* @brief   This example code shows how to use the touchscreen driver.
* @attention
#include "main.h"
/** @addtogroup STM32H7RSxx_HAL_Examples
/** @addtogroup BSP
#defineCIRCLE_RADIUS      40
#defineLINE_LENGHT          30
#defineCIRCLE_XPOS(i)       ((i * 480) / 5)
#defineCIRCLE_YPOS(i)       (272 - CIRCLE_RADIUS - 60)
/* Private Structures and Enumerations ------------------------------------------------------------*/
/* Possible allowed indexes of touchscreen demo */
typedef enum
TOUCHSCREEN_DEMO_1 = 1,
#if (USE_TS_MULTI_TOUCH == 1)
TOUCHSCREEN_DEMO_2 = 2,
TOUCHSCREEN_DEMO_3 = 3,
TOUCHSCREEN_DEMO_MAX = TOUCHSCREEN_DEMO_3,
#else
TOUCHSCREEN_DEMO_MAX = TOUCHSCREEN_DEMO_1,
#endif /* USE_TS_MULTI_TOUCH == 1 */
} TouchScreenDemoTypeDef;
/* Table for touchscreen event information display on LCD : table indexed on enum @ref TS_TouchEventTypeDef information */
char * ts_event_string_tab = { "None",
                                  "Press down",
                                  "Lift up",
                                  "Contact"};
/* Global variables ---------------------------------------------------------*/
uint16_t x_new_pos = 0, x_previous_pos = 0;
uint16_t y_new_pos = 0, y_previous_pos = 0;
TS_State_tTS_State;
TS_MultiTouch_State_tTS_MTState = {0};
extern uint32_t colors[];
/* Static variable holding the current touch color index : used to change color at each touch */
static uint32_t touchscreen_color_idx = 0;
TS_Init_t hTS;
static void   Touchscreen_SetHint_Demo(TouchScreenDemoTypeDef demoIndex);
static uint32_t Touchscreen_Handle_NewTouch(void);
static void TS_Update(void);
* @briefTouchscreen Demo1 : test touchscreen calibration and single touch in polling mode
* @paramNone
* @retval None
void Touchscreen_demo1(void)
uint16_t x1, y1;
uint8_t state = 0;
uint32_t ts_status = BSP_ERROR_NONE;
UserButtonPressed = 0;
hTS.Width = x_size;
hTS.Height = y_size;
hTS.Orientation = TS_SWAP_NONE;
hTS.Accuracy = 5;
/* Touchscreen initialization */
ts_status = BSP_TS_Init(0, &hTS);
if(ts_status == BSP_ERROR_NONE)
    /* Display touch screen demo description */
    Touchscreen_SetHint_Demo(TOUCHSCREEN_DEMO_1);
    Touchscreen_DrawBackground_Circles(state);
    while (1)
      /* Check in polling mode in touch screen the touch status and coordinates */
      /* of touches if touch occurred                                           */
      ts_status = BSP_TS_GetState(0, &TS_State);
      if(TS_State.TouchDetected)
      /* One or dual touch have been detected          */
      /* Only take into account the first touch so far */
      /* Get X and Y position of the first touch post calibrated */
      x1 = TS_State.TouchX;
      y1 = TS_State.TouchY;
      if ((y1 > (CIRCLE_YPOS(1) - CIRCLE_RADIUS)) &&
            (y1 < (CIRCLE_YPOS(1) + CIRCLE_RADIUS)))
          if ((x1 > (CIRCLE_XPOS(1) - CIRCLE_RADIUS)) &&
            (x1 < (CIRCLE_XPOS(1) + CIRCLE_RADIUS)))
            if ((state & 1) == 0)
            UTIL_LCD_FillCircle(CIRCLE_XPOS(1), CIRCLE_YPOS(1), CIRCLE_RADIUS, UTIL_LCD_COLOR_BLUE);
            HAL_Delay(1);
            state = 1;
          if ((x1 > (CIRCLE_XPOS(2) - CIRCLE_RADIUS)) &&
            (x1 < (CIRCLE_XPOS(2) + CIRCLE_RADIUS)))
            if ((state & 2) == 0)
            UTIL_LCD_FillCircle(CIRCLE_XPOS(2), CIRCLE_YPOS(2), CIRCLE_RADIUS, UTIL_LCD_COLOR_RED);
            HAL_Delay(1);
            state = 2;
          if ((x1 > (CIRCLE_XPOS(3) - CIRCLE_RADIUS)) &&
            (x1 < (CIRCLE_XPOS(3) + CIRCLE_RADIUS)))
            if ((state & 4) == 0)
            UTIL_LCD_FillCircle(CIRCLE_XPOS(3), CIRCLE_YPOS(3), CIRCLE_RADIUS, UTIL_LCD_COLOR_YELLOW);
            state = 4;
          if ((x1 > (CIRCLE_XPOS(4) - CIRCLE_RADIUS)) &&
            (x1 < (CIRCLE_XPOS(4) + CIRCLE_RADIUS)))
            if ((state & 8) == 0)
            UTIL_LCD_FillCircle(CIRCLE_XPOS(4), CIRCLE_YPOS(3), CIRCLE_RADIUS, UTIL_LCD_COLOR_GREEN);
            state = 8;
      } /* of if(TS_State.TouchDetected) */
      ClearUserInput();
      BSP_TS_DeInit(0);
      return;
      HAL_Delay(20);
} /* of if(status == BSP_ERROR_NONE) */
* @briefTouchscreen Demo2 : test touchscreen single and dual touch in polling mode
* @paramNone
* @retval None
void Touchscreen_demo2(void)
hTS.Width = x_size;
hTS.Accuracy = 0;
    /* Display touch screen demo2 description */
    Touchscreen_SetHint_Demo(TOUCHSCREEN_DEMO_2);
while (1)
    Touchscreen_Handle_NewTouch();
      ClearUserInput();
      BSP_TS_DeInit(0);
      return;
    HAL_Delay(100);
* @briefTouchscreen Demo3 : test touchscreen single touch in interrupt mode
* @paramNone
* @retval None
void Touchscreen_demo3(void)
uint16_t k, l;
hTS.Width = x_size;
hTS.Accuracy = 0;
BSP_TS_EnableIT(0);
for(k = 0; k < hTS.Width/40; k++)
    for(l = 0; l < hTS.Height/40; l++)
      UTIL_LCD_DrawRect(40*k, 40*l,40,40, UTIL_LCD_COLOR_BLACK);
while (1)
      ClearUserInput();
      BSP_TS_DisableIT(0);
      BSP_TS_DeInit(0);
      return;
void BSP_TS_Callback(uint32_t Instance)
TS_Update();
uint16_t i, j;
    x_new_pos = TS_State.TouchX;
    y_new_pos = TS_State.TouchY;
    for(i = 0; i < hTS.Width/40; i++)
      for(j = 0; j < hTS.Height/40; j++)
      if(((x_new_pos > 40*i) && (x_new_pos < 40*(i+1))) && ((y_new_pos > 40*j) && (y_new_pos < 40*(j+1))))
          UTIL_LCD_FillRect(x_previous_pos, y_previous_pos,40,40, UTIL_LCD_COLOR_WHITE);
          UTIL_LCD_DrawRect(x_previous_pos, y_previous_pos,40,40, UTIL_LCD_COLOR_BLACK);
          UTIL_LCD_FillRect(40*i, 40*j,40,40, colors[(touchscreen_color_idx++ % 24)]);
          x_previous_pos = 40*i;
          y_previous_pos = 40*j;
          break;
* @briefTouchscreen_Handle_NewTouch: factorization of touch management
* @paramNone
* @retval BSP_ERROR_NONE
#define TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS 15
#define TOUCH_INFO_STRING_SIZE                70
uint16_t x1 = 0;
uint16_t y1 = 0;
uint16_t x2 = 0;
uint16_t y2 = 0;
uint32_t drawTouch1 = 0; /* activate/deactivate draw of footprint of touch 1 */
uint32_t drawTouch2 = 0; /* activate/deactivate draw of footprint of touch 2 */
uint32_t colors = {UTIL_LCD_COLOR_BLUE, UTIL_LCD_COLOR_GREEN, UTIL_LCD_COLOR_RED, UTIL_LCD_COLOR_CYAN, UTIL_LCD_COLOR_MAGENTA, UTIL_LCD_COLOR_YELLOW,
                         UTIL_LCD_COLOR_LIGHTBLUE, UTIL_LCD_COLOR_LIGHTGREEN, UTIL_LCD_COLOR_LIGHTRED, UTIL_LCD_COLOR_LIGHTCYAN, UTIL_LCD_COLOR_LIGHTMAGENTA,
                         UTIL_LCD_COLOR_LIGHTYELLOW, UTIL_LCD_COLOR_DARKBLUE, UTIL_LCD_COLOR_DARKGREEN, UTIL_LCD_COLOR_DARKRED, UTIL_LCD_COLOR_DARKCYAN,
                         UTIL_LCD_COLOR_DARKMAGENTA, UTIL_LCD_COLOR_DARKYELLOW, UTIL_LCD_COLOR_LIGHTGRAY, UTIL_LCD_COLOR_GRAY, UTIL_LCD_COLOR_DARKGRAY,
                         UTIL_LCD_COLOR_BLACK, UTIL_LCD_COLOR_BROWN, UTIL_LCD_COLOR_ORANGE };
uint8_t lcd_string = "";
ts_status = BSP_TS_Get_MultiTouchState(0, &TS_MTState);
if(TS_MTState.TouchDetected)
    /* One or dual touch have been detected*/
    /* Erase previous information on touchscreen play pad area */
    UTIL_LCD_FillRect(0, 80, x_size, y_size - 160, UTIL_LCD_COLOR_WHITE);
    /* Re-Draw touch screen play area on LCD */
    UTIL_LCD_DrawRect(10, 90, x_size - 20, y_size - 180, UTIL_LCD_COLOR_BLUE);
    UTIL_LCD_DrawRect(11, 91, x_size - 22, y_size - 182, UTIL_LCD_COLOR_BLUE);
    /* Erase previous information on bottom text bar */
    UTIL_LCD_FillRect(0, y_size - 80, x_size, 80, UTIL_LCD_COLOR_BLUE);
    /* Deactivate drawing footprint of touch 1 and touch 2 until validated against boundaries of touch pad values */
    drawTouch1 = drawTouch2 = 0;
    x1 = TS_MTState.TouchX;
    y1 = TS_MTState.TouchY;
    if((y1 > (90 + TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS)) &&
       (y1 < (y_size - 90 - TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS)))
      drawTouch1 = 1;
    /* If valid touch 1 position : inside the reserved area for the use case : draw the touch */
    if(drawTouch1 == 1)
      /* Draw circle of first touch : turn on colors[] table */
      UTIL_LCD_FillCircle(x1, y1, TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS, colors[(touchscreen_color_idx++ % 24)]);
      UTIL_LCD_SetFont(&Font16);
      UTIL_LCD_DisplayStringAt(0, y_size - 70, (uint8_t *)"TOUCH INFO : ", CENTER_MODE);
      sprintf((char*)lcd_string, "x1 = %u, y1 = %u",x1, y1);
      UTIL_LCD_DisplayStringAt(0, y_size - 45, lcd_string, CENTER_MODE);
    } /* of if(drawTouch1 == 1) */
    if(TS_MTState.TouchDetected > 1)
      /* Get X and Y position of the second touch post calibrated */
      x2 = TS_MTState.TouchX;
      y2 = TS_MTState.TouchY;
      if((y2 > (90 + TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS)) &&
         (y2 < (y_size - 90 - TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS)))
      drawTouch2 = 1;
      /* If valid touch 2 position : inside the reserved area for the use case : draw the touch */
      if(drawTouch2 == 1)
      sprintf((char*)lcd_string, "x2 = %u, y2 = %u",x2, y2);
      UTIL_LCD_DisplayStringAt(0, y_size - 35, lcd_string, CENTER_MODE);
      /* Draw circle of second touch : turn on color[] table */
      UTIL_LCD_FillCircle(x2, y2, TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS, colors[(touchscreen_color_idx++ % 24)]);
      } /* of if(drawTouch2 == 1) */
    } /* of if(TS_MTState.TouchDetected > 1) */
} /* of if(TS_MTState.TouchDetected) */
return(ts_status);
* @briefDisplay TS Demo Hint for all touchscreen demos depending on passed
*         demoIndex in parameter.
* @paramdemoIndex : parameter of type @ref TouchScreenDemoTypeDef
* @retval None
BSP_LCD_SetLayerVisible(0,0, DISABLE);
if(demoIndex <= TOUCHSCREEN_DEMO_MAX)
    /* Clear the LCD */
    /* Set Touchscreen Demo1 description */
    UTIL_LCD_FillRect(0, 0, x_size, 80, UTIL_LCD_COLOR_BLUE);
    if(demoIndex == TOUCHSCREEN_DEMO_1)
      UTIL_LCD_DisplayStringAt(0, 0, (uint8_t *)"Touchscreen basic polling", CENTER_MODE);
      UTIL_LCD_DisplayStringAt(0, 45, (uint8_t *)"Please use the Touchscreen to activate the colored circle", CENTER_MODE);
      UTIL_LCD_DisplayStringAt(0, 60, (uint8_t *)"inside the rectangle, then press USER button", CENTER_MODE);
    else if (demoIndex == TOUCHSCREEN_DEMO_2)
      UTIL_LCD_DisplayStringAt(0, 0, (uint8_t *)"Touchscreen dual touch polling", CENTER_MODE);
      UTIL_LCD_DisplayStringAt(0, 45, (uint8_t *)"Please press the Touchscreen to activate", CENTER_MODE);
      UTIL_LCD_DisplayStringAt(0, 60, (uint8_t *)"single and dual touch, then press USER button", CENTER_MODE);
    else /* demoIndex == TOUCHSCREEN_DEMO_3 */
      UTIL_LCD_DisplayStringAt(0, 0, (uint8_t *)"Touchscreen dual touch interrupt", CENTER_MODE);
    UTIL_LCD_DrawRect(10, 90, x_size - 20, y_size - 100, UTIL_LCD_COLOR_BLUE);
    UTIL_LCD_DrawRect(11, 91, x_size - 22, y_size - 102, UTIL_LCD_COLOR_BLUE);
} /* of if(demoIndex <= TOUCHSCREEN_DEMO_MAX) */
BSP_LCD_SetLayerVisible(0,0, ENABLE);
* @briefDraw Touchscreen Background
* @paramstate : touch zone state
* @retval None
void Touchscreen_DrawBackground_Circles(uint8_t state)
uint16_t x, y;
switch (state)
    case 0:
      UTIL_LCD_FillCircle(CIRCLE_XPOS(1), CIRCLE_YPOS(1), CIRCLE_RADIUS - 2, UTIL_LCD_COLOR_WHITE);
      UTIL_LCD_FillCircle(CIRCLE_XPOS(2), CIRCLE_YPOS(2), CIRCLE_RADIUS - 2, UTIL_LCD_COLOR_WHITE);
      UTIL_LCD_FillCircle(CIRCLE_XPOS(3), CIRCLE_YPOS(3), CIRCLE_RADIUS - 2, UTIL_LCD_COLOR_WHITE);
      UTIL_LCD_FillCircle(CIRCLE_XPOS(4), CIRCLE_YPOS(3), CIRCLE_RADIUS - 2, UTIL_LCD_COLOR_WHITE);
      break;
    case 1:
      break;
    case 2:
      break;
    case 4:
      break;
    case 8:
      UTIL_LCD_FillCircle(CIRCLE_XPOS(4), CIRCLE_YPOS(4), CIRCLE_RADIUS, UTIL_LCD_COLOR_GREEN);
      UTIL_LCD_FillCircle(CIRCLE_XPOS(4), CIRCLE_YPOS(4), CIRCLE_RADIUS - 2, UTIL_LCD_COLOR_WHITE);
      break;
    case 16:
      UTIL_LCD_FillCircle(CIRCLE_XPOS(2), CIRCLE_YPOS(2), CIRCLE_RADIUS, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_FillCircle(CIRCLE_XPOS(3), CIRCLE_YPOS(3), CIRCLE_RADIUS, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_FillCircle(CIRCLE_XPOS(4), CIRCLE_YPOS(3), CIRCLE_RADIUS, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_DrawHLine(CIRCLE_XPOS(1)-LINE_LENGHT, CIRCLE_YPOS(1), 2*LINE_LENGHT, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_DrawHLine(CIRCLE_XPOS(2)-LINE_LENGHT, CIRCLE_YPOS(2), 2*LINE_LENGHT, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_DrawVLine(CIRCLE_XPOS(2), CIRCLE_YPOS(2)-LINE_LENGHT, 2*LINE_LENGHT, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_DrawHLine(CIRCLE_XPOS(3)-LINE_LENGHT, CIRCLE_YPOS(3), 2*LINE_LENGHT, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_DrawHLine(CIRCLE_XPOS(4)-LINE_LENGHT, CIRCLE_YPOS(4), 2*LINE_LENGHT, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_DrawVLine(CIRCLE_XPOS(4), CIRCLE_YPOS(4)-LINE_LENGHT, 2*LINE_LENGHT, UTIL_LCD_COLOR_BLUE);
      UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_BLUE);
      x = CIRCLE_XPOS(1);
      y = CIRCLE_YPOS(1) - CIRCLE_RADIUS - UTIL_LCD_GetFont()->Height;
      UTIL_LCD_DisplayStringAt(x, y, (uint8_t *)"Volume", CENTER_MODE);
      x = CIRCLE_XPOS(4);
      y = CIRCLE_YPOS(4) - CIRCLE_RADIUS - UTIL_LCD_GetFont()->Height;
      UTIL_LCD_DisplayStringAt(x, y, (uint8_t *)"Frequency", CENTER_MODE);
      break;
    case 32:
      UTIL_LCD_FillCircle(CIRCLE_XPOS(1), CIRCLE_YPOS(1), CIRCLE_RADIUS, UTIL_LCD_COLOR_BLACK);
      UTIL_LCD_FillCircle(CIRCLE_XPOS(2), CIRCLE_YPOS(2), CIRCLE_RADIUS, UTIL_LCD_COLOR_BLACK);
      UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_BLACK);
      UTIL_LCD_SetFont(&Font20);
      x = CIRCLE_XPOS(1) - 10;
      y = CIRCLE_YPOS(1) - (UTIL_LCD_GetFont()->Height)/2;
      UTIL_LCD_DisplayStringAt(x, y, (uint8_t *)"Up", LEFT_MODE);
      x = CIRCLE_XPOS(2) - 10;
      y = CIRCLE_YPOS(3)- (UTIL_LCD_GetFont()->Height)/2;
      UTIL_LCD_DisplayStringAt(x, y, (uint8_t *)"Dw", LEFT_MODE);
      break;
    case 64:
      UTIL_LCD_DrawVLine(CIRCLE_XPOS(3), CIRCLE_YPOS(3)-LINE_LENGHT, 2*LINE_LENGHT, UTIL_LCD_COLOR_BLUE);
      x = CIRCLE_XPOS(2);
      UTIL_LCD_DisplayStringAt(x, y, (uint8_t *)"Frequency", LEFT_MODE);
      break;
* @briefTouchScreen get touch position
* @paramNone
* @retval None
uint8_t TouchScreen_GetTouchPosition(void)
uint16_t x1, y1;
uint8_t circleNr = 0;
    /* Get X and Y position of the first */
      circleNr = 1;
      circleNr = 2;
      circleNr = 3;
      circleNr = 4;
    else
      if (((y1 < 220) && (y1 > 140)) &&
          ((x1 < 160) && (x1 > 100)))
      circleNr = 0xFE;   /* top part of the screen */
      else
      circleNr = 0xFF;
return circleNr;
一路向北lm 发表于 2025-3-15 19:32
SD卡相关操作:
* @file    sd.c
* @brief   This example code shows how to use the BSP SD Driver
* @attention
#include "main.h"
/** @addtogroup BSP
#define SD_START_ADDRESS       ((uint32_t)0x00000400U)   /* SD Address to write/read data */
#define NB_BLOCK_BUFFER      (BUFFER_SIZE*4) / BLOCKSIZE /* Number of Block (512b) by Buffer */
#define BUFFER_SIZE            ((uint32_t)1024)            /* 16Ko */
uint32_t aTxBuffer;
uint32_t aRxBuffer;
__IO uint32_t SDWriteStatus = 0, SDReadStatus = 0, SDDetectStatus = 0;
static void SD_SetHint(void);
static void Fill_Buffer(uint32_t *pBuffer, uint32_t uwBufferLenght, uint32_t uwOffset);
static uint8_t Buffercmp(uint32_t* pBuffer1, uint32_t* pBuffer2, uint32_t BufferLength);
* @briefSD Demo
* @paramNone
* @retval None
void SD_Demo (void)
int32_t SD_state;
uint32_t prev_status = 2;/* Undefined state */
SD_SetHint();
SD_state = BSP_SD_Init(0);
BSP_SD_DetectITConfig(0);
if(SD_state != BSP_ERROR_NONE)
    if (SDDetectStatus == SD_NOT_PRESENT)
      UTIL_LCD_DisplayStringAt(20, 100, (uint8_t *)"SD CARD NOT DETECTED", LEFT_MODE);
      UTIL_LCD_DisplayStringAt(20, 115, (uint8_t *)"SD shall be inserted before running test", LEFT_MODE);
      UTIL_LCD_DisplayStringAt(20, 130, (uint8_t *)"SD Test Aborted", LEFT_MODE);
    else
      UTIL_LCD_DisplayStringAt(20, 100, (uint8_t *)"SD INITIALIZATION : FAIL", LEFT_MODE);
      UTIL_LCD_DisplayStringAt(20, 115, (uint8_t *)"SD Test Aborted", LEFT_MODE);
else
    UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_GREEN);
    UTIL_LCD_DisplayStringAt(20, 100, (uint8_t *)"SD Initialization : OK", LEFT_MODE);
    UTIL_LCD_DisplayStringAt(20, 300, (uint8_t *)"   SD Connected", RIGHT_MODE);
    SDDetectStatus = SD_PRESENT;
    prev_status = SD_PRESENT;
    SD_state = BSP_SD_Erase(0,SD_START_ADDRESS, (SD_START_ADDRESS+BUFFER_SIZE));
    while(BSP_SD_GetCardState(0) != SD_TRANSFER_OK)
      UTIL_LCD_DisplayStringAt(20, 115, (uint8_t *)"SD ERASE : FAILED", LEFT_MODE);
    else
      UTIL_LCD_DisplayStringAt(20, 115, (uint8_t *)"SD ERASE : OK", LEFT_MODE);
      /* Fill the buffer to write */
      Fill_Buffer(aTxBuffer, BUFFER_SIZE, 0x22FF);
      SD_state = BSP_SD_WriteBlocks(0,(uint32_t *)aTxBuffer, SD_START_ADDRESS, NB_BLOCK_BUFFER);
      UTIL_LCD_DisplayStringAt(20, 130, (uint8_t *)"SD WRITE : FAILED", LEFT_MODE);
      UTIL_LCD_DisplayStringAt(20, 145, (uint8_t *)"SD Test Aborted", LEFT_MODE);
      else
      /* Wait until SD cards are ready to use for new operation */
      UTIL_LCD_DisplayStringAt(20, 130, (uint8_t *)"SD WRITE : OK", LEFT_MODE);
      SD_state = BSP_SD_ReadBlocks(0,(uint32_t *)aRxBuffer, SD_START_ADDRESS, NB_BLOCK_BUFFER);
          UTIL_LCD_DisplayStringAt(20, 145, (uint8_t *)"SD READ : FAILED", LEFT_MODE);
          UTIL_LCD_DisplayStringAt(20, 160, (uint8_t *)"SD Test Aborted", LEFT_MODE);
      else
          UTIL_LCD_DisplayStringAt(20, 145, (uint8_t *)"SD READ : OK", LEFT_MODE);
          if(Buffercmp(aTxBuffer, aRxBuffer, BUFFER_SIZE) > 0)
            UTIL_LCD_DisplayStringAt(20, 160, (uint8_t *)"SD COMPARE : FAILED", LEFT_MODE);
            UTIL_LCD_DisplayStringAt(20, 175, (uint8_t *)"SD Test Aborted", LEFT_MODE);
          else
            UTIL_LCD_DisplayStringAt(20, 160, (uint8_t *)"SD TEST : OK", LEFT_MODE);
UTIL_LCD_DisplayStringAt(20, 200, (uint8_t *)"SD Demo Done. Press the USR1 button to exit", CENTER_MODE);
while (1)
    /* Check if the SD card is plugged in the slot */
    if (SDDetectStatus != SD_PRESENT)
      if (prev_status != SD_NOT_PRESENT)
      prev_status = SD_NOT_PRESENT;
      UTIL_LCD_DisplayStringAt(20, 300, (uint8_t *)"SD NOT Connected", RIGHT_MODE);
    else if (prev_status != SD_PRESENT)
      ClearUserInput();
      if(SDDetectStatus != SD_NOT_PRESENT)
      BSP_SD_DeInit(0);
      return;
* @brief Tx Transfer completed callback
* @paramInstance SD Instance
* @retval None
void BSP_SD_WriteCpltCallback(uint32_t Instance)
SDWriteStatus = 1;
* @brief Rx Transfer completed callback
* @retval None
void BSP_SD_ReadCpltCallback(uint32_t Instance)
SDReadStatus = 1;
* @briefBSP SD Callback.
* @paramStatus   Pin status
* @retval None
void BSP_SD_DetectCallback(uint32_t Instance, uint32_t Status)
SDDetectStatus = Status;
* @briefDisplay SD Demo Hint
* @paramNone
* @retval None
/* Clear the LCD */
/* Set LCD Demo description */
UTIL_LCD_DisplayStringAt(0, 0, (uint8_t *)"SD", CENTER_MODE);
UTIL_LCD_DisplayStringAt(0, 45, (uint8_t *)"This example shows how to detect the presence of the card", CENTER_MODE);
UTIL_LCD_DisplayStringAt(0, 60, (uint8_t *)"and how to write and read data on the microSD", CENTER_MODE);
* @briefFills buffer with user predefined data.
* @parampBuffer: pointer on the buffer to fill
* @paramuwBufferLenght: size of the buffer to fill
* @paramuwOffset: first value to fill on the buffer
* @retval None
uint32_t tmpIndex = 0;
/* Put in global buffer different values */
for (tmpIndex = 0; tmpIndex < uwBufferLenght; tmpIndex++ )
    pBuffer = tmpIndex + uwOffset;
* @briefCompares two buffers.
* @parampBuffer1, pBuffer2: buffers to be compared.
* @paramBufferLength: buffer's length
* @retval 1: pBuffer identical to pBuffer1
*         0: pBuffer differs from pBuffer1
while (BufferLength--)
    if (*pBuffer1 != *pBuffer2)
      return 1;
    pBuffer1++;
    pBuffer2++;
return 0;
SD卡相关操作:
这芯片和开发板价格怎么样
地瓜patch 发表于 2025-4-16 17:00
请教楼主,在板卡的demo程序中,点击下图中的AI命令,会调用摄像头么?摄像头会打开,还是需要刷入其他相关demo程序才能打开摄像头?
这芯片和开发板价格怎么样
同问一下
请教楼主,在板卡的demo程序中,点击下图中的AI命令,会调用摄像头么?摄像头会打开,还是需要刷入其他相关 ...
会打开摄像头的
会打开摄像头的
我这边打不开摄像头,点AI黑屏,死机。需要拔掉type-c数据线。请问需要拨码么?
Chenyudie 发表于 2025-7-4 21:49
请教楼主,接入摄像头的电源怎么接啊,为什么我摄像头接上后板子就启动不了了,接上前能启动,开始以为另一端接电脑供电不行,结果接手机充电线也不行,也下了STLink v3,但还是不行
页: [1]
查看完整版本: 运行STM32N6 的BSP外设综合测试
