lvsezhidu 发表于 2025-3-22 21:29
PIC12F675 单片机内存不足怎么办
笔者弄2路AD转换,采用2只74ls164驱动8只集成数码管显示2路AD转换结果,但提示内存不足,编译不通过,不知怎么办?Error    D:\desktop\PIC12F675_gai\main.c; 181. no space for auto/param AD_TMR0_ISR@Result_170
#include <pic.h>   //PIC12F675
//__CONFIG(0x2004);      //?????? //配置字要在头文件后 PROTEUS仿真也要有PIC12F675/629 手册9.1配置位P54
//bit13/12BG1:0=00最低/11最高带隙电压bit11:9空bit8 CPD=0使能/1禁止RAM保护
//bit7 CP=0使能/1禁止ROM保护bit6=1使能/0禁止欠压检测bit5MCLR=0/1GP3复位脚/GP3数字脚,内部复位
//bit4 PWRET使能上电延时定时器1=禁止,0=使能 bit3 看门狗使能位1=使能,0=禁止   手册14.1配置位
//bit2:0 FOSC2:0振荡器使能100=INTOSC振荡,GP4/GP5数字I/O口
#define_XTAL_FREQ 4000000UL
#define INT8U   unsigned char
#define INT16Uunsigned int
#define DAT GPIO2   //74LS164串行数据线
#define CLK GPIO3//74LS164串行时钟线
#define RST GPIO4//74LS164复位脚
//共阳数码管0~9的数字段码,最后一位为黑屏
const INT8U SEG_CODE ={0xC0,0xF9,0xA4,0xB0,0x99,
                         0x92,0x82,0xF8,0x80,0x90,0xFF};
//两路模拟转换结果显示缓冲,显示格式为:X.XX X.XX ,第4位和第8位不显示
//volatile INT8U Display_Buffer = {0,0,0,10,0,0,0,10};
volatile INT8U k = 0, j = 0;
volatile int Result = 0;
void ADC_int(void);            //ADC模块初始化
void Serial_Output(INT8U d);   // 模拟时序向74HC164串行输出1字节数据
        INT8U i;
        for(i = 0; i < 8; i++)                   //1个字节8位
          CLK = 0;                                            //时钟置0
          if(d&0x80)DAT = 1;                   //移出一位(高位优先)
      else DAT = 0;
      d <<= 1;
          CLK = 1;                                           //时钟置1,上升沿数据移入74HC164
void ADC_int(void)
    //手册P46 ANSEL - ADCS2 ADCS1 ADCS0 ANS3:0
    //        ADCS2=0;ADCS1=1;ADCS0=0;      //FOSC/32
    //ANS1=1;ANS0=1;                   //AN0/AN1模拟输入
    ANSEL = 0b10100011;
   //手册P45 ADCON0ADFM VCFG - - CHS1 CHS0 GO/DONE ADON
        //ADFM=1;          //1右对齐
    //VCFG=0;          //VDD参考电压,1=VREF参考电压
    //CHS1=0;CHS0=0;   //通道0
    //GODONE = 1;                        //启动AD转换
    ADCON0 = 0b10110010;
    __delay_ms(2000);       //启动AD转换后要延时,等待AD模块稳定
    PIE1 |= 0b01000000;      //ADIE = 1;       //使能AD转换中断
    PIR1 &= 0b10111111;   //ADIF= 0;    //AD转换中断标志清0
void main(void)
        //TRISIO2=0;TRISIO3=0;TRISIO4=0;
    TRISIO = 0b00000011;
    GPIO2=1;GPIO3=1;GPIO4=1;
   //以下配置用于TMR0定时器刷新数码管显示
    PSA = 0;                              //前分频给TMR0
        PS2 = 0; PS1 = PS0 = 1;               //16分频(OPTION低3位为011)
        TMR0 = (INT8U)(256 - _XTAL_FREQ / 4 / 16 * 0.002); //2ms定时
        T0IF = 0;                               //清TMR0中断标志
        T0CS = 0;                               //TMR0内部指令周期,工作于定时器
        T0IE = 1;                               //允许TMR0溢出中断
    PEIE = 1;                           //允许所有的未屏蔽的中断
    GIE = 1;                            //开全局中断
    ADC_int( );
   while(1);
// AD转换中断读数据,TMR0定时器溢出中断控制数码管刷新显示两路A/D转换结果
void interrupt AD_TMR0_ISR( )
   static INT8U Display_Buffer = {0,0,0,10,0,0,0,10};
   static INT8Uk = 0 ;
   static unsigned intResult = 0;
   if(ADIF&&(k==7)) //强制16ms获取一次AD转换中断结果,否则显示闪烁
   {               //也就是timer0中断8次,AD转换中断才发生一次
                     //从而提高显示的刷新率
      //读取转换结果,并转换为电压值
      //参考电压5v,所以转换结果*500/1023.0,使结果在000~500间
      unsigned int Result = (unsigned int)((ADRESL | (ADRESH << 8)) *500.0 / 1023.0);
      Display_Buffer = Result / 100;
          Display_Buffer = Result / 10 % 10;
          Display_Buffer = Result % 10;
         Display_Buffer=0;
         while(Result > 100){Result -= 100;Display_Buffer++;}
         while(Result > 10){Result -= 10;Display_Buffer++;}
         Display_Buffer = Result;
      //if(++j > 1)   j=0;
      CHS0 ^= 1;
      GODONE = 1;            //改变通道后要重新启动AD转换
      ADIF = 0;
   if(T0IF && T0IE)
      TMR0 = (INT8U)(256 - _XTAL_FREQ / 4 / 16 * 0.002);//位间延时间隔2ms
      RST = 0;                         //两只74HC164复位,输出为0
      RST = 1;                         //拉高复位脚,允许74HC164输出
                Serial_Output(0x01<<k);                             //先送扫描码
                Serial_Output(SEG_CODE]); //后送段码
          k =(k+1)&0x07;
Wxy8030 发表于 2025-3-22 22:20
换个内存大的呗
lvsezhidu 发表于 2025-3-23 09:20
关键是早期买的几块PIC12F675、PIC12F629一直没用,想利用一下,
资深技术 发表于 2025-3-23 11:41
依以前用这个芯片的感觉, 完成 “2路AD转换,采用2只74ls164驱动8只集成数码管显示2路AD转换结果” 这个需求,这个芯片的容量够了。看看程序能不能精简。
mbutterfly 发表于 2025-3-23 14:04
换大点的RAM的型号,要不就是精简程序,少用全局数组变量。
lvsezhidu 发表于 2025-3-23 14:08
把AD转换放主函数里也是显示内存小,编译不通过,我用的是H_TECH software编辑器,不知在哪设置代码优化级别,请前辈告知。
lvsezhidu 发表于 2025-3-23 14:15
C:\Users\Administrator\Desktop
lvsezhidu 发表于 2025-3-23 14:18
编译结果如下:
Build D:\desktop\PIC12F675_gai\main for device 12F675
Using driver C:\Program Files (x86)\HI-TECH Software\PICC\9.80\bin\picc.exe
Make: The target "D:\desktop\PIC12F675_gai\main.p1" is out of date.
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.80\bin\picc.exe" --pass1 D:\desktop\PIC12F675_gai\main.c -q --chip=12F675 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.80\bin\picc.exe" -omain.cof -mmain.map --summary=default,-psect,-class,+mem,-hex --output=default,-inhx032 main.p1 --chip=12F675 -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode)V9.80
Copyright (C) 2010 Microchip Technology Inc.
Serial number: HCPICP-111111 (PRO)
Error    D:\desktop\PIC12F675_gai\main.c; 182. no space for ___ftdiv temps (3)
********** Build failed! **********
xch 发表于 2025-3-23 17:10
代码框架没设计好。64字节内存足够了。
中断服务之中不需要做太多工作。做个标记清除中断即可。
在main 函数while 循环中根据标记做需要的操作。标记仅占用一个字节。但是中断中用到的寄存器系统以为都需要保护,会占用更多ram。
丙丁先生 发表于 2025-3-23 20:48
外接存储方法可行吗?FLASH里做RAM,好像在STC论坛AI8051U21课讲过。
丙丁先生 发表于 2025-3-23 20:49
原理一样,具体程序,我还没有细看。
GlenX 发表于 2025-3-24 20:38
减少全局变量,尽量使用局部变量。
banyai 发表于 2025-3-25 19:52
这段语句要优化,不要用浮点运算,大数的乘除法,尽量用移位和加减法取代:
这个在使用前定义就可以,不需要全局!
页: [1]
查看完整版本: PIC12F675 单片机内存不足怎么办
