Haizangwang 发表于 2025-4-11 18:11
STM32 HAL库之GPIO示例代码
LED灯不断闪烁
GPIO初始化,main文件中的 MX_GPIO_Init(); 也就是在 gpio.c文件中
void MX_GPIO_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct = {0};
    /* GPIO Ports Clock Enable */
    __HAL_RCC_GPIOE_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    /*Configure GPIO pin Output Level */
    HAL_GPIO_WritePin(GPIOE, GPIO_PIN_5, GPIO_PIN_SET);
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_SET);
    /*Configure GPIO pin : PE5 */
    GPIO_InitStruct.Pin = GPIO_PIN_5;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
    /*Configure GPIO pin : PB5 */
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
查看gpio函数,在 stm32f1xx_hal_gpio.h 或 stm32f1xx_hal_gpio.c 中查看
业务逻辑代码 led.c
#include "stm32f1xx_hal.h"
#define LED_PIN GPIO_PIN_5
#define LED_PORT GPIOB
void led_on(void)
    HAL_GPIO_WritePin(LED_PORT, LED_PIN, GPIO_PIN_RESET); // 设置GPIOB的Pin5为高电平
void led_off(void)
    HAL_GPIO_WritePin(LED_PORT, LED_PIN, GPIO_PIN_SET); // 设置GPIOB的Pin5为低电平
void led_toggle(void)
    HAL_GPIO_TogglePin(LED_PORT, LED_PIN); // 切换GPIOB的Pin5电平
main.c
/* USER CODE BEGIN Header */
* @file         : main.c
* @brief          : Main program body
* @attention
* Copyright (c) 2025 STMicroelectronics.
* All rights reserved.
* This software is licensed under terms that can be found in the LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "led.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @briefThe application entry point.
* @retval int
int main(void)
    /* USER CODE BEGIN 1 */
    /* USER CODE END 1 */
    /* MCU Configuration--------------------------------------------------------*/
    /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
    HAL_Init();
    /* USER CODE BEGIN Init */
    /* USER CODE END Init */
    SystemClock_Config();
    /* USER CODE BEGIN SysInit */
    /* USER CODE END SysInit */
    MX_GPIO_Init();
    /* USER CODE BEGIN 2 */
    /* USER CODE END 2 */
    /* Infinite loop */
    /* USER CODE BEGIN WHILE */
    while (1)
      led_toggle();
      HAL_Delay(1000);
      /* USER CODE END WHILE */
      /* USER CODE BEGIN 3 */
    /* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
    RCC_OscInitTypeDef RCC_OscInitStruct = {0};
    RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
    /** Initializes the RCC Oscillators according to the specified parameters
   * in the RCC_OscInitTypeDef structure.
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
    RCC_OscInitStruct.HSEState = RCC_HSE_ON;
    RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
    RCC_OscInitStruct.HSIState = RCC_HSI_ON;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
    RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
      Error_Handler();
    /** Initializes the CPU, AHB and APB buses clocks
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
      Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @briefThis function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
    /* USER CODE BEGIN Error_Handler_Debug */
    /* User can add his own implementation to report the HAL error return state */
    __disable_irq();
    while (1)
    /* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @briefReports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @paramfile: pointer to the source file name
* @paramline: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
    /* USER CODE BEGIN 6 */
    /* User can add his own implementation to report the file name and line number,
       ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
轮询方式按键点亮LED灯
/*Configure GPIO pin : PE4 */
GPIO_InitStruct.Pin = GPIO_PIN_4;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_PULLUP;
业务逻辑代码 key.c
#include "Key.h"
uint8_t flag = 0;
uint8_t Key_Getflag(void)
    HAL_Delay(10);
    flag=0;
    if(HAL_GPIO_ReadPin(GPIOE,GPIO_PIN_4)==0)
      while (HAL_GPIO_ReadPin(GPIOE,GPIO_PIN_4)==0);
      flag=1;
    HAL_Delay(10);
    return flag;
main.c
* @file         : main.c
* @attention
#include "main.h"
#include "gpio.h"
#include "led.h"
#include "Key.h"
* @retval int
int main(void)
HAL_Init();
MX_GPIO_Init();
/* Infinite loop */
    while (1)
      if (Key_Getflag() == 1)
            led_toggle();
* @retval None
    Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    Error_Handler();
* @retval None
    __disable_irq();
    while (1)
#ifdefUSE_FULL_ASSERT
* @retval None
原文链接:https://blog.csdn.net/qq_65047384/article/details/147097130
页: [1]
查看完整版本: STM32 HAL库之GPIO示例代码
