[研电赛技术支持] GD32F3x0 官方PWM驱动正频宽偏小(定时不准)的问题
1487|3
 楼主| tpgf 发表于 2025-4-14 08:42 | 显示全部楼层 |阅读模式
1. 代码
#include "gd32f3x0.h"
#include <stdio.h>
#include "gd32f350r_eval.h"
void gpio_config(void);
void timer_config(void);
    \brief      configure the GPIO ports
    \param[in]  none
    \param[out] none
    \retval     none
    /*Configure PB3 PB10 PB11(TIMER1 CH1 CH2 CH3) as alternate function*/
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_3);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_3);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_10);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_10);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_11);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_11);
    gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_3);
    gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_10);
    gpio_af_set(GPIOB, GPIO_AF_2, GPIO_PIN_11);
    \brief      configure the TIMER peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    TIMER1 configuration: generate 3 PWM signals with 3 different duty cycles:
    TIMER1CLK is 1MHz
    TIMER1 channel1 duty cycle = (4000/ 16000)* 100  = 25%
    TIMER1 channel2 duty cycle = (8000/ 16000)* 100  = 50%
    TIMER1 channel3 duty cycle = (12000/ 16000)* 100 = 75%
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER1);
    timer_deinit(TIMER1);
    /* TIMER1 configuration */
#ifdef GD32F330
    timer_initpara.prescaler         = 83;
#endif /* GD32F330 */
#ifdef GD32F350
    timer_initpara.prescaler         = 107;
#endif /* GD32F350 */
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 15999;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER1,&timer_initpara);
    /* CH1,CH2 and CH3 configuration in PWM mode */
    timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
    timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;
    timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
    timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;
    timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
    timer_channel_output_config(TIMER1,TIMER_CH_1,&timer_ocintpara);
    timer_channel_output_config(TIMER1,TIMER_CH_2,&timer_ocintpara);
    timer_channel_output_config(TIMER1,TIMER_CH_3,&timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_1,3999);
    timer_channel_output_mode_config(TIMER1,TIMER_CH_1,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER1,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
    timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_2,7999);
    timer_channel_output_mode_config(TIMER1,TIMER_CH_2,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER1,TIMER_CH_2,TIMER_OC_SHADOW_DISABLE);
    timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_3,11999);
    timer_channel_output_mode_config(TIMER1,TIMER_CH_3,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER1,TIMER_CH_3,TIMER_OC_SHADOW_DISABLE);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER1);
    timer_enable(TIMER1);
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_periph_clock_enable(RCU_GPIOB);
    gpio_config();
    timer_config();
    while (1);
2. 分析
PWM频率=84MHz/(83+1)/(15999+1)= 62.5Hz
这样计算下来TIMER1 channel1 duty cycle = (3999/ 16000)* 100 = 24.99375%.
所以正确应该为
timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_1,4000);
在PWM频率很低时不容易发现这个问题,在10~100kHz时,用示波器可以明显发现正频宽偏小的问题。
原文链接:https://blog.csdn.net/lljss1980/article/details/125454905
暖心小太阳 发表于 2025-4-16 16:40 | 显示全部楼层
建议检查一下硬件连接是否正确,以及是否有其他干扰因素影响PWM信号。
elephant00 发表于 2025-4-17 11:13 | 显示全部楼层
通常由时钟源配置错误、分频系数设置不当或计数器模式错误引起。
两只袜子 发表于 2025-4-17 11:14 | 显示全部楼层
检查系统时钟配置。
