N32WB452CEQ6单片机I2C异常
在多次使用I2C和从机通信中,发现经常会有单片机I2C开始条件执行过后,状态寄存器为0的异常情况,经抓过波形发现单片机确实没有发出开始条件,各位大佬,帮忙看看代码是不会有什么问题uint8_ti2c_master_recv(u8* pBuffer, uint8_t ReadAddr, uint16_t NumByteToRead){
if(NumByteToRead > 1)
/** Disable Acknowledgement */
I2C_ConfigAck(I2C2, ENABLE);
I2CTimeout = I2CT_LONG_TIMEOUT;
while (I2C_GetFlag(I2C2, I2C_FLAG_BUSY))
if((I2CTimeout --) == 0)
I2C_TIMEOUT_UserCallback(MASTER_BUSY);
return 0;
/** Send START condition */
// send start
// I2C_Enable(I2C2,DISABLE);
// I2C_Enable(I2C2,ENABLE);
I2C_GenerateStart(I2C2, ENABLE);
/** Test on EV5 and clear it */
while (!I2C_CheckEvent(I2C2, I2C_EVT_MASTER_MODE_FLAG))
I2C_TIMEOUT_UserCallback(MASTER_MODE);
return 0;
/** Send write address for write */
I2C_SendAddr7bit(I2C2, 0x40, I2C_DIRECTION_SEND);
/** Test on EV6 and clear it */
while (!I2C_CheckEvent(I2C2, I2C_EVT_MASTER_TXMODE_FLAG))
I2C_TIMEOUT_UserCallback(MASTER_TXMODE);
return 0;
I2C_Enable(I2C2, ENABLE);
I2C_SendData(I2C2, ReadAddr);
// /** Test on EV8 and clear it */
while (!I2C_CheckEvent(I2C2, I2C_EVT_MASTER_DATA_SENDED))
I2C_TIMEOUT_UserCallback(MASTER_SENDING);
return 0;
/** Send STRAT condition a second time */
// /** Test on EV5 and clear it */
return 0;
// /** Send EEPROM address for read */
I2C_SendAddr7bit(I2C2, 0x41, I2C_DIRECTION_RECV);
/* Test on EV6 and clear it */
while (!I2C_GetFlag(I2C2, I2C_FLAG_ADDRF))
I2C_TIMEOUT_UserCallback(MASTER_BYTEF);
return 0;
if(NumByteToRead == 1)
I2C_ConfigAck(I2C2, DISABLE);
(void)(I2C2->STS1); /// clear ADDR
(void)(I2C2->STS2);
I2C_GenerateStop(I2C2, ENABLE);
else
(void)(I2C2->STS1);
(void)(I2C2->STS2);
while(NumByteToRead)
/** Wait until RXNE flag is set */
while (!I2C_GetFlag(I2C2, I2C_FLAG_RXDATNE))
return 0;
/** Read data from DAT */
/** Read a byte from the EEPROM */
*pBuffer++ = I2C_RecvData(I2C2);
NumByteToRead--;
//I2C_GenerateStop(I2C2, ENABLE);
return 1;
主要是经常在通讯开始的第一个开始条件上,它没发出来,剩下的也不会执行 就是没有发出吧 昊430 发表于 2025-4-24 21:59就是没有发出吧
是的,单片机到这确实没发,多次执行发送启动条件也是没有发出,只能暂时通过重新初始化I2C解决这个问题 仿真查看寄存器值 建议还是用模拟I2C,硬件I2C大大小小都有些问题 I2C总线的硬件连接是否正确,包括SCL和SDA线的上拉电阻。 检查I2C时钟配置是否正确。 I2C_EVT_MASTER_TXMODE_FLAG是用于指示I2C控制器已进入发送模式的事件标志。确保从机地址和方向设置正确。 确保I2C_EVT_MASTER_MODE_FLAG是正确的事件标志,用于指示I2C控制器已进入主模式。 建议先用I2C例程测试。没问题再改造为自己的处理。 要想让硬件的I2C外设正常工作,需要很多设置。看看设置处理是否被执行了。 必要的话,在程序的每个分支中加入log输出,通过log,看看程序是否是按照你设想的逻辑顺序执行的。
页:
[1]
