【STM32C092RC 测评】+NUCLEO-C092RC开发板pwm+timer+控制呼吸
本帖最后由 yinxiangxv 于 2025-5-26 22:30 编辑采用工具进行相关的配置,选择好对应的封装?
这里开启了tim1,tim2对应的通道,同时进行相关参数的配置
根据时钟树的显示,这里面不再对时钟的频率进行修改,采用默认方式。
那么下面看看对应的关键配置,因为tim1是高级计时器,所以参数比较多,但是这里用到的比较有限
同理,tim2是一个普通计时器,只要简单正确配置就可以了
那么看看关键代码:
/* USER CODE BEGIN 2 */
// Start the PWM channels for both LEDs
// Note: Use the correct Timer handle and Channel defined by your configuration
if (HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2) != HAL_OK) // For LED on PC9
Error_Handler();
if (HAL_TIM_PWM_Start(&htim2, TIM_CHANNEL_1) != HAL_OK) // For LED on PA5
Error_Handler();
// --- Variables for breathing effect ---
// Set PWM_MAX_VALUE to your timer's ARR (Auto-Reload Register) value
// Assuming ARR was set to 999 for both timers in CubeMX for a 0-1000 range
uint32_t pwm_max_value = 999;
uint32_t brightness = 0;
int8_t step = 5; // How much to change brightness each step
uint8_t delay_ms = 10; // Delay between steps, controls breathing speed
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
// --- Fade In ---
for (brightness = 0; brightness <= pwm_max_value; brightness += step)
// Clamp brightness to max value in case step overshoots
if (brightness > pwm_max_value) {
brightness = pwm_max_value;
// Set the PWM duty cycle (Compare value) for both LEDs simultaneously
__HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_2, brightness); // LED on PC9
__HAL_TIM_SET_COMPARE(&htim2, TIM_CHANNEL_1, brightness); // LED on PA5
HAL_Delay(delay_ms); // Adjust delay for breathing speed
// Ensure brightness is exactly max value after loop
__HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_2, pwm_max_value);
__HAL_TIM_SET_COMPARE(&htim2, TIM_CHANNEL_1, pwm_max_value);
HAL_Delay(delay_ms * 10); // Optional: Pause briefly at full brightness
// --- Fade Out ---
// Start slightly below max to avoid issues with unsigned wrap-around if step doesn't divide evenly
for (brightness = pwm_max_value; brightness > 0; )
// Decrement first, then check bounds
if (brightness <= step) { // Prevent underflow for unsigned int
brightness = 0;
} else {
brightness -= step;
// Ensure brightness is exactly 0 after loop
__HAL_TIM_SET_COMPARE(&htim1, TIM_CHANNEL_2, 0);
__HAL_TIM_SET_COMPARE(&htim2, TIM_CHANNEL_1, 0);
HAL_Delay(delay_ms * 10); // Optional: Pause briefly when off
/* USER CODE END 3 */
/* USER CODE BEGIN 3 */
并且构建成功:
继续新的探索
PWM设置还是非常实用的 涵盖了STM32C092RC的基本特性、开发环境搭建、PWM和定时器的配置与使用 是否需要启用多个PWM通道或使用DMA同步? 如何选择合适的定时器和配置参数以实现最佳效果? 若LED在低占空比下出现闪烁,应如何调整PWM频率 这个初始化不是都是在MX里配置就行了吗,需要自己一步一步从头配置吗 可对比不同定时器(如TIM1与TIM3)的性能差异,为复杂应用提供参考。 对于高功率 LED ,如何设计外部驱动电路 提供了丰富的代码示例, 更好地理解和应用PWM、定时器和呼吸灯控制。 在配置PWM时,是否需要特别注意某些参数的设置? 当多个 PWM 通道同时工作时,如何避免通道间的干扰 如何选择预分频器(Prescaler)和自动重载值(ARR)以平衡PWM分辨率和频率? STM32C092RC的PWM模块与Timer的协同配置 控制多个LED的呼吸效果,如何分配定时器通道并避免资源冲突? 最大支持多大频率的PWM输出? 通过中断或主循环调整占空比,两者在实时性和资源占用上有何差异? 呼吸灯亮度变化采用线性增减还是非线性曲线 通过DMA自动更新PWM占空比 是否需要引入全局变量存储亮度状态 ?
页:
[1]
